Old 06-22-2006, 01:34 PM   #1
Car: 06 sti
Fav Mod: METH!!!!
Default installing gauges...feul pressure??
im installing my tyriple pillar with boost, feul press, and a/f mix...i got the boost done, im pretty sure ill be alright with the a/f, now with the feul pressure, i hooked one up before but on my trans am, b4,on my feul rail there was a test port for a check pressure gauge, i just tapped into there...is there one of those on our cars?? i gotta 06...its a autometer electronic one with the sender unit...??also where did you guys tap into for the light source??? is there a FP regualtor somewhere or something i can get o or one of those pressure checks im talking about?? thanks
JT's06sti is offline   Reply With Quote
Old 06-22-2006, 02:58 PM   #2
The easy way of getting all the connections is from the OEM boost gauge plug and fromthe radio harness plug. The OEM boost gauge plug has the regulated ground so you will be able to dim the gauges with the stock dimmer. The other connections can be tapped on the radio harness, just use a test light to find needed connections.
wjc04wrx is offline   Reply With Quote
Old 06-23-2006, 11:36 AM   #3
Car: 06 sti
Fav Mod: METH!!!!
boost gauge plug???? i do have the factory boost gauge but i wanst aware of a plug>?? thanks , i did manage aleardey with the light source i was just wondering where the ideal place was.... im stuck at the FP...its the only one not connected at the moment...does anyone know where to connect it in at?? is there a sttock FPR???or the test port like i said above??
Old 06-23-2006, 03:41 PM   #4
Yes, where the wire connectors for your factory boost gauge connect. If you don't have a factory boost gauge, such plug will be taped up on the stereo harness. That plug provides the regulated ground in order to be able to dim the gauges with the entire cluster.
Did you set them up in order for them to dim?
Old 06-25-2006, 09:25 AM   #5
Ok, this is great news, but to verify, are you saying this plug for the boost gauge is behind the stereo on the wiring harness? How many wires does it have and/or what does it look like?
I tapped an EGT gauge into my old WRX wagon through the clock, but this time around I want to stay away from the clock and get a regulated ground.
Your help is appreciated,
Chris
CFar is online now   Reply With Quote
Old 06-25-2006, 11:11 AM   #6
Yes, the plug where the OEM boost gauge connects is taped to the stereo harness. It only has two wires, purple and orange w/ white stripe. It is just a two male prong plug.
To tap onto the clock is a pain in the arse.
***Note: I installed two electronic gauges yesterday tapping into the same place, but I guess these gauges don't like the regulated ground and would lose power when being dimmed.
Old 06-25-2006, 11:32 AM   #7
Hmm, I may end up just going through the clock again as it wasn't too difficult. Easier to get to IMO. Why did you think it was a pain in the butt?
Chris
Old 06-27-2006, 09:11 AM   #8
Car: 06 sti
Fav Mod: METH!!!!
ok thanks, ill use that for the dimming...still no help with the feul pressure???? where can i tap in for that???
