Go Back   IWSTI.com: Subaru WRX STI Forums > IWSTI Engine & Drivetrain > How-To / Install
Old 06-02-2008, 06:20 PM   #16
Car: CGM 05
Fav Mod: IAG 38mm EWG
IWSTI Addict since: Mar 2008
Send a message via AIM to 1loudsti
Default Re: cleaning intercooler?
Originally Posted by importfanatic17 View Post
Did you get a bunch of crud out?
more oil than i would like to admit lol....it worked really well....the ideal way to do it would be cap off one end and fill it with gas then dump it out then use brake cleaner to get the residue since the brake cleaner evaporates quickly
1loudsti is offline   Reply With Quote
Old 06-02-2008, 06:37 PM   #17
i eat cones
Fav Mod: 18x8
IWSTI Addict since: Oct 2006
Trader Rating: (21)
nice. needa do this.
Old 06-04-2008, 08:39 AM   #18
Car: Pearl Wht 07 STI
Fav Mod: SR56 turbo & Rays 18"
I recently did my FMIC. I used gas, that should be the best option to used because it'll break up the oil after you move it around in there then let sit w/ one side up until all the oil comes out and the repeat the process and let it sit on the other side up.
STi Str8 Beast is offline   Reply With Quote
Old 06-05-2008, 06:05 PM   #19
I'm Jim Halpert
Fav Mod: EWG
IWSTI Addict since: Apr 2006
so is there any consensus on the best way to clean the intercooler?
Old 06-06-2008, 12:29 AM   #20
Car: CGM 05
it appears that gas complete with a cap for one end is the best
Old 06-06-2008, 07:59 AM   #21
-Cap it off w/ gas inside and shake it up
-Let it sit on it's side if FMIC or on the only opening it has face down and let it drain.
-Repeat as necessary
Note: You may want to clean out the throttle body & IC piping while your at it
Old 06-06-2008, 08:16 AM   #22
i eat cones
Fav Mod: 18x8
Trader Rating: (21)
thanks, gonna have to do this soon!
car should run better...
