Old 04-22-2008, 03:24 PM   #1
Default Cobb SS Install help
I have a question about installing the Cobb SS. How did you guys modify the metal frame so that the SS has room to shift? I simply have the basic tools wrenches and what not so sure what to do on how to trim/cut the metal. I reviewed the HSPN install, but they never showed how they cut it, simply that it needs to be modified. Any help appreciated!!
Thanks
empfl is offline   Reply With Quote
Old 04-22-2008, 03:52 PM   #2
Car: 04 SUBARU WRX sti
Fav Mod: JDM FOGS
Default Re: Cobb SS Install help
honestly i used a dremel and a cut off wheel. This was able to trim it back a bit. these tools can be purchased at home depot
Old 04-22-2008, 03:54 PM   #3
thanks for the tip!
Old 04-24-2008, 11:38 AM   #4
anybody else?
Old 04-24-2008, 11:52 AM   #5
abracious
Fav Mod: Track time
i used a dremel, but a $5 hack saw would probably cut it. pun intended.
Old 05-31-2008, 05:57 PM   #6
Car: 05 WRX STI OBP
Fav Mod: learning how to heel toe
i used a wizard wheel or aka cutoffwheel its an airpowered tool if u have access to a aircompresor use it at all times makes life 10x easier
Old 05-31-2008, 07:59 PM   #7
wdb
dances with roads
A $5 hacksaw will definitely do the job.
Old 06-01-2008, 12:10 AM   #8
thanks for the feedback guys.. ended up using a hacksaw.. took a while, but definely worth the price compared to the dremel *since i don't really have too much use for one*
Old 06-01-2008, 04:19 AM   #9
The Stig II
Fav Mod: Meth protune 323+/380+
+1
jnprn2003 is offline   Reply With Quote
