Old 04-08-2008, 08:18 PM   #1
07 OBP STi Owner
Car: 07 OBP WRX STi
Fav Mod: The ones I install myself!
Default Coilover install / properly aligning and balancing
Hello again everyone,
Just received my Tein Flex Coilovers and EDFC, Tein Strut tower bars and Cobb Sway bars w/Kartboy endlinks. Install all these items is for the most part going to be easy maybe time consuming though. I am looking for a how-to or advice on the coilover set up after the install.
I would like to know about reasonable Castor, Camber, and Toe settings for the STi. I plan on lowering the car 1.8 inches front, 1.0 back. Still using 17x8.5 rims. I would like to also know what respective numbers for the balancing are. 50/50 left to right, but what about front to back. I saw the video on the MY00 using 60/40 f/b. I plan on having an alignment done but need to know what to tell them for the castor/camber settings. Any other info would help, thanks.
-Dirk
Rasz's STi is offline   Reply With Quote
Old 04-08-2008, 08:28 PM   #2
Fav Mod: Zzyzx Coilovers
Default Re: Coilover install / properly aligning and balancing
here's some info: How To: Setup your Street alignment the right way. » t3h_Clap’s Wheel33tist Blog
Old 04-08-2008, 08:46 PM   #3
07 OBP STi Owner
Car: 07 OBP WRX STi
Thanks JD_STI!
Old 04-09-2008, 11:57 AM   #4
Wheel33tist Whore
if you're doing corner balancing you want Front Left + Rear Right = Front Right + Rear Left
hope the little article was helpful
Old 04-09-2008, 07:52 PM   #5
07 OBP STi Owner
Car: 07 OBP WRX STi
Thanks T3h_Clap!
