Old 03-11-2008, 08:43 AM   #1
Car: 07 Subaru WRX STi
Default How to install the V-limited Rubber Protector?
OK, I have the rubber protector taped with the supplied sticky strip onto the V Limited lip (uninstalled). The next step is to drill holes into the lip to push in the plastic fasteners to secure the rubber protector.
My question is how easy is it to drill into the lip? I am thinking the lip may crack. Anyone else with experience drilling into the V limited? How did you do it? I am thinking of placing a wood block underneath the area I plan to drill.
Anyone?
wchow16 is offline   Reply With Quote
Old 03-11-2008, 09:50 AM   #2
Fav Mod: Hatchback!
Default Re: How to install the V-limited Rubber Protector?
Anyone?
Just drill it, i used a metal drill bit and ran the drill at slow/med speed, no support underneath. no worries, the plastic is way flexible and shouldnt crack. just keep a strong guide hand on the drill.
Oh, and you might want to use nuts& bolts at a few key points for extra strength, i did that on both my 05 & 08, coz those plastic clips didnt seem to be worth sht.
Post pics when you're done!
S'poreSTI is offline   Reply With Quote
Old 03-11-2008, 09:57 AM   #3
Thanks for the tips.
Old 05-23-2008, 02:07 PM   #4
Car: 07 Subaru WRX STI
Fav Mod: ACPT Carbon Fiber Driveshaft
Send a message via AIM to Spider96
You guys happen to know what size drill bit to use?
Spider96 is offline   Reply With Quote
Old 05-23-2008, 03:41 PM   #5
All the info is on this document.
