Old 02-26-2008, 04:29 AM   #1
HowTo Contributor
Car: 06 Aspen White STI
Send a message via AIM to Shakes Send a message via Yahoo to Shakes
Default REQ: Parking brake Adjust
Anyone about to do it that wants to make a DIY thread?
Shakes is offline   Reply With Quote
Old 02-26-2008, 05:06 AM   #2
Fav Mod: TBE
Default Re: REQ: Parking brake Adjust
Here's a section from my How-To for replacing your pads and rotors.
http://www.iwsti.com/forums/how-install/100740-how-replace-brake-pads-rotors.html
Step 7:
Now we're going to remove the rear rotor. You can try tapping it loose with a hammer but chances are that it's being held on there by the parking brake shoes. If this is the case then try these 2 options in order.
- First: Loosen the parking brake by turning the adjusting screw enough that the brake shoe moves away from the rotor. There is a rubber cover on the hole, just pull it out and you'll see the adjusting screw. When you loosen the screw count the number of teeth you moved it by because you are going to need to adjust it when you put the new rotor on!!!
Old 02-26-2008, 05:06 AM   #3
Fav Mod: TBE
If you have any questions you can PM me
