Old 02-08-2008, 04:56 PM   #1
Car: 07 Fanboi blue STI
Default STRI Boost Gauge for 07 STI
I was wondering if anyone had any how-to's for STRI boost gauges. I've searched and looked on the last 2-3 pages and couldnt find anything.
Thanks
302@12psi is offline   Reply With Quote
Old 02-08-2008, 05:07 PM   #2
i eat cones
Fav Mod: 18x8
Trader Rating: (18)
Default Re: STRI Boost Gauge for 07 STI
it is very easy to do. i think there is a write up on scoobymods for boost gauge.
Old 02-08-2008, 05:48 PM   #3
Fav Mod: cylinder #4...
Thanks
i would imagine boost gauge install to be the same regardless of band. do a search on "boost gauge" alone, thats what i did, i found more than enough info. g'luck
Old 02-08-2008, 10:17 PM   #4
Anyone have this stuff bookmarked?
My searching is yeilding no results.
Old 02-10-2008, 09:29 AM   #5
Car: 06 Subaru WRX STi
Fav Mod: Valentine 1
Send a message via AIM to shan mann
taken from : boost gauge installation - Life In American
RidinLow
03-22-2001, 02:13 PM
I don't think this has been posted before, so I'll go ahead & do it. http://www.i-club.com/ubb-files/smilies/smile.gif
I used an Autometer Carbon Fiber 2 5/8" vac/boost gauge, part #4801. It comes with a very thin tubing and you'll need to buy your own T fitting.
Here's a brass 1/4" NPT T fitting (A):
<IMG SRC="http://www.garrickgoh.com/impreza/boostgauge/IMAGE001.jpg" border=0>
You'll need 2 1/4" NPT nipples that fit the particular vacuum hose that you want to tap. For the one I used, I believe it was 1/8". These are parts B in the above picture. Part C is included with the Autometer gauge and is used to connect the thin tubing to this T we've made. Don't forget to use Teflon tape on the threads to seal everything!
This is the hose I tapped:
<IMG SRC="http://www.garrickgoh.com/impreza/boostgauge/IMAGE002.jpg" border=0>
Go into the passenger footwell and find this hole in the firewall. Run the thin cable through the hole.
<IMG SRC="http://www.garrickgoh.com/impreza/boostgauge/IMAGE003.jpg" border=0>
Note: If you're planning on mounting the gauge on the driver's side, find a grommet there as the thin tubing isn't long enough to run from the passenger footwell to the driver's side.
Here's where it protrudes on the other side.
<IMG SRC="http://www.garrickgoh.com/impreza/boostgauge/IMAGE006.jpg" border=0>
Since this is DIRECTLY above the turbo and its pre-cat, make sure you ziptie the tubing away from that and any other hot spots.
Hmm, guess I didn't take a pic of the T fitting installed, but you can figure that out. Just snip the vacuum hose in two & slide the T in between it and connect the thin tubing! http://www.i-club.com/ubb-files/smilies/smile.gif
It works!!! (Gauge in temporary location)
<IMG SRC="http://www.garrickgoh.com/impreza/boostgauge/IMAGE007.jpg" border=0>
The gauge doesn't really look that carbon-fibery, the flash just brings that out. It's real c/f, so if you know what that looks like, it's quite subdued.
Here's a better pic:
<IMG SRC="http://www.garrickgoh.com/impreza/boostgauge/IMAGE008.jpg" border=0>
[This message has been edited by RidinLow (edited March 22, 2001).]
shan mann is offline   Reply With Quote
Old 02-11-2008, 06:03 AM   #6
Thanks for the help.
I'm more concerned with the wiring part as it's probaly going to be an electrical gauge I go with.
