Old 12-19-2007, 04:13 AM   #1
Car: 07 Subaru WRX STi
Default Line Output Converter
Does anyone know how to install a line output converter to the headunit? I need to hook up RCA cables to the stock headunit with this converter, but don't know how to install it.
raSTi is offline   Reply With Quote
Old 12-24-2007, 07:45 AM   #2
Car: 05 WRX STI OBP
Fav Mod: factory shift light!!! beep beep
Default Re: Line Output Converter
ok real simple you hook up the two negatives on the line output converter to a negative side of the speaker take the two positives and hook them up to the positive side of the speaker there should be two extra wires those are grounds you shouldnt need them unless you have ground noise. and sorry for the crappy drawing best i could do on a laptop. any other questions just ask
Old 12-24-2007, 08:04 AM   #3
The Stig II
Fav Mod: EFI Logics tune
If you will be using a sub then above will work...you will need to wire left and right +/- if you will be running your front and /or rear speakers.
jnprn2003 is offline   Reply With Quote
