Old 11-22-2007, 09:04 PM   #1
Fav Mod: Greddy T-ic
Send a message via AIM to sti_nguyen
Default How to: Remove rear bumper?
Noob question.. But how do i remove the rear bumper? where do i start? what kind of tools will i need? And yes i searched but could'nt find nothing
sti_nguyen is offline   Reply With Quote
Old 11-22-2007, 09:09 PM   #2
Car: 06 STI, 08 GSXR 750
Fav Mod: WC Lathe Werks Shift Knob
Default Re: How to: Remove rear bumper?
I once saw a guy remove his by backing into something. I'm pretty sure it was accidental and wouldn't recommend trying it. Sorry this isn't any help but thought I'd share.
Hitman83 is offline   Reply With Quote
Old 11-22-2007, 09:15 PM   #3
Car: 07 Subaru WRX STI
Fav Mod: The key, in the ignition.
Originally Posted by sti_nguyen View Post
Noob question.. But how do i remove the rear bumper? where do i start? what kind of tools will i need? And yes i searched but could'nt find anything
I'm sorry. I just couldn't resist.
I have not removed an STI bumper but on other cars that I have done it to you just need a socket set and wrenches. If you can get your hands on a service manual, there should be exploded views of the car that will give you an idea of how and where to start.
Crash1973 is offline   Reply With Quote
Old 11-22-2007, 09:16 PM   #4
dex
Car: 07 CGM STi
Fav Mod: Stage 2
Send a message via AIM to dex
.. LOL
dex is offline   Reply With Quote
Old 11-23-2007, 07:11 AM   #5
Teh Other White Meat
Trader Rating: (22)
remove the taillights. there's 3 poppets on each side under there. in the rear wheel well, there's 1 screw and a clip. there's three poppets on the underside of the bumper connected to the body. loosen the 4 nuts that hold the bumper beam on. These are inside the trunk, under the trim. disconnect the license plate light. lift up and the bumper should come off.
Old 11-25-2007, 04:40 PM   #6
Authorized Member-Vendor
Fav Mod: Being IWSTI's Pawn Shop, lol
Trader Rating: (52)
Remove the 5 nuts and clips that hold the rear lights in. Remove the all the clips and bolts that hold the bumper on. Just remove as many as you can find, and try removing it. If it doesnt budge, your missing one, find it, and try again. Thats What i did. I removed my rear bumper beam, took me about 45 minutes to remove it and re-install just the bumper.
Crewchief is offline   Reply With Quote
Old 11-26-2007, 01:05 AM   #7
Fav Mod: JDM STi Performance Muffler
Crewcheif and snorky pretty much nailed it. Start by removing the headlights and work your way around the around the bumper. IIRC theres a few bolts and a bunch of those pop rivits. It's not hard at all and could probably be done in under an hour.
300hp@6000rpm is offline   Reply With Quote
Old 11-26-2007, 08:10 AM   #8
Trader Rating: (52)
Oh and If your removing rear bumper beam like I did. Get some zip ties, because thats how the bottom of your bumper is going to be held on by, lol. It uses the bumper beam for support on the bottom with out, I needed another sorce to hold it.
