Old 10-22-2007, 03:56 PM   #1
Car: Silver 05 STi
Fav Mod: Driver License
Default Install plan needed for tons of parts
Ok, so I have a lot of parts that I need to install, and can't figure out where to start and what order to work in.
Already installed:
-TurboXS FMIC
-K&N typhoon
-HKS Hi-Power exhaust
-HKS turbo timer
Suspension stuff:
-Eiback springs
-Whiteline f/r sways and endlinks
Engine:
-APS turbo inlet
-Oil catch can
-Process West oil cooler
-Zero/sports coolthermo thermostat
-Maddad headers w/up pipe
-Nvidia downpipe
-Kartboy exhaust hangers
-Intake manifold spacers
-NGK 1 step colder plugs
-Cobb swaintech coated heat shield
-Samco radiator/ancillary hoses
-Stainless braided brake lines
Gauges:
-3gauge clock pod
-Autometer EGT
-Autometer Boost
-Autometer Oil pressure
-Subiegal single dash pod
-Autometer Fuel pressure
Paying P&L to install:
-Perrin V1 fuel rails
-Walbro fuel pump
-Power Enterprises 850cc injectors
-S.A.R.D. fp regulator
Any reccomendations will be greatly appreciated. Yeah I know I should do all of the suspension stuff at the same time, its mostly stuff like the inlet, plugs, spacers, headers, etc. I don't have a clue what order I should put everything on to make it all easier. Thanks in advance.
James
ihadmail is offline   Reply With Quote
Old 04-09-2008, 12:28 PM   #2
Car: 06 OBP STI
Default Re: Install plan needed for tons of parts
Well you have to pull the intake manifold for the APS inlet so why not do the fuel rails and injectors then?
Subysoli is offline   Reply With Quote
Old 04-09-2008, 12:42 PM   #3
Fav Mod: HKS CARBON TI
damn thats ALOT of stuff. Itd be ideal if you can have your car down for a few days or even a week or two. Id start with the suspension and while the wheels are off and car is in the air u can do the brake lines. Then move to the engine and while you have the intake out and manifold off, you can hook up all the gauge sensors and do all the engine work and then reassemble it in reverse
