Go Back   IWSTI.com: Subaru WRX STI Forums > GD Series STi Discussion (2003/4-2007) > GD-Marketplace > Vendor Classifieds > Archived Vendor Classified Threads by Vendor > Rallysport Direct
Old 10-19-2004, 02:39 PM   #1
Car: STI's ;)
Fav Mod: Coolest Vendor Ever
IWSTI Addict since: Aug 2003
Send a message via AIM to RallySportDirect Send a message via Yahoo to RallySportDirect
We just got a huge shipment of the brand new Defi BF Series Amber gauges. These gauges are sweet and have a very cool opening and closing sequence. Check out the pictures:
When the gauges are off they hide the display giving you the ultimate show look.
Defi BF Amber Series Boost Gauge - 264.00 SHIPPED
Defi BF Amber Series Oil Pressure Gauge - 297.00 SHIPPED
Defi BF Amber Series EGT Gauge - 297.00 SHIPPED
Defi BF Amber Series Oil Temperature Gauge - 221.00 SHIPPED
These gauges are some of the most accurate gauges available. Made with the highest quality posible they will not give false reading like many of the cheaper gauges. Why trust your motor with anything but the best!!!!
The Defi-Link Control Unit II is a necessary controller to install Defi-Bf Meters It displays up to 7 gauges and displays can be connected and controlled by one Control Unit II. The name of the connection system is "Defi-Link System."
Defi-Link System allows gauges and displays to be attached to Defi-Link Control Unit II with a single "DAISY CHAIN" wiring system.
More features of the control unit:
Driving data can be stored and can be replayed up to 3 minutes.
Pause, speed play, forward, and rewind function can be applied during playback.
Double Warning function by a meter's LED lamp and a beep
The switch panel is embossed and buzzer sounds by pushing the buttons.
The characters and the rings on the switch panel are illuminated in white at nighttime. It makes operation in the dark easy.
Defi control Unit II(required to install gauges) - 116.99 Shipped
Need a way to mount your gauges????? We have a couple different options.
The ATi pod is one of the best on the market. It replaces the clock piece above the radio and is already matched to the color of the dash. It can hold 52mm or 60mm Gauges and you can use your choice of faeplates(Chrome, Carbon Fiber, or World Rally Blue)
ATI pod w/o faceplate- 139.99 Shipped
ATI pod with your choice of faceplate 145.99 Shipped
Perrin Steering Column Pod - 143.99 Shipped
Let me know if you have any questions.
Ben
801.619.1779
parts@rallysportdirect.com
aim: rallysportdirect
www.rallysportdirect.com
RallySportDirect is offline   Reply With Quote
HTML code is On
