TopSpeed Motorsports | DOM 1.5 TESTING COMPLETE!!!
260K views 317 replies 81 participants last post by  SlowInFastOut
#1 · (Edited)
Today we finished the testing on our 2011 STI with the Blouch Dom 1.5 Turbo. We have done countless Blouch 20g XT builds here at TopSpeed, but no one had ventured out to try the ball bearing Dom 1.5. We were honestly floored with the results!
What we look for in a stock location turbo is something that we can keep drive pressures down on, still spools quickly. A lot of the bigger stock location turbos do not appeal to use because of the high drive pressures and laggy nature. We feel that you have to give up so much power curve most of the time that its better to stay with either the smaller stock location, or just bite the bullet and go rotated.
This turbo however surprised us! We are very happy with the curve, power, spool and top end performance. This test was done using an 8cm hotside, however we will be swapping to the 10cm to see how much power band we give up. I would recommend this turbo to anyone looking for great power, and a huge broad power band!
TopSpeed Motorsports 2011 STI Project Car:
Numbers
Dyno: Dyno Jet
Tuner: Douglas Wilks
Wheel HP: 377.61
Wheel TQ: 415.01
Ambient Temp: 85.47 F (23% Humidity)
Elevation: 1000ft (EST.)
Boost: 21PSI Peak
Fuel: 93oct Pump Gas
Car Info
Year: 2011
Engine Management: Cobb AP
Turbo: Blouch Dom 1.5
Intercooler: Stock
Meth Kit: None
Injectors: Injected Dynamics 1000cc
Intake/Inlet: Stock Air Box/Perrin Inlet
Headers: Invidia Race Headers
Uppipe: Invidia
Downpipe: Invidia
CBE: Invidia
TopSpeed Tuner Review
http://www.iwsti.com/forums/review-sti-tuners/95024-top-speed-ga-61.html
Future plans:
- testing 10cm Hotside
Thanks for looking, feel free to ask any questions.
~Cicio
GRAPH OVERLAID WITH THE STOCK TURBO PLOT
*EDIT
Here is an overlay of the Dom1.5 8cm & a 20gXT 10cm
#7 ·
The 20G XT-R is a great turbo as well for sure.
The Dom3 doesn't spool near as quick, in our opinion that turbo is too big for a stock location configuration. Drive pressures are just too high. If you don't want to go with a rotated setup and you are dead set on a big turbo though, the big Blouchs are as good as it gets.
~Cicio
#11 ·
I do have a question about the 10cm Cicio.
What are you expecting spool wise from it? I know it will increase flow, but will any more lag come with that?
#14 ·
Subscribed!
#56 ·
**First post updated
This will be a better compairison once we do the 10cm testing on the Dom1.5, but this will give you guys an idea.
As you can see the 10cm barely outflows the 8cm up top with the 1.5, while the 8cm 1.5 kills it until 6k RPM
More to come guys.
~Cicio
Does the 20g car also run the invidia race monifold?
#37 ·
Here is the graph compared against the 20gxt. Both cars are dual avcs sti's with the exact same setup.. header, downpipe, tmic, etc.. Both cars were run on E85 at 25psi avg. You can see from the graph the dom1.5 spools much faster giving you over 70ft/lbs of tq more down low.
Red run is the Dom 1.5 with 8cm housing
Blue run is the 20gxt with 10cm housing
We were having some fueling issues, the car needs a FPR with that high flow Aeromotive pump so were weren't able to pull 4th gear on the dyno....just in case your wondering what the difference in spool is from the original pump gas graph....thats why.
~Cicio
#45 ·
There is no trickery going on at all. This graph was a comparison, I just exported it in whatever setting it was on at the time.
I will be happy to show you it in SAE.
Thats the nice thing about a dynojet...there is NO WAY to play with numbers. There are two or three correction factors, and the end user can always see them...its great.
Oh yea that turbo is happening on my car.
At my pro-tune appointment I will be discussing this with you Cicio. :D
Awesome! Looking forward to it.
Peak hp is a little too far left for my liking on e85. Looks like the 8cm housing is running out of steam, looks like the 10 will be required at those levels. The 8 might still work out well for a real conservative e85 tune though, good stuff. This turbo is looking like a winner imo.
I assume once you get the 10cm housing you will do a 20 and 25 psi tune on it as well to give the full picture? That is really the only decision atm to be made imo.
I agree that on E85 the 10cm is going to make better/broader power. I will be happy to do a 20 and 25 PSI tune to show you guys. We have a completely booked week, so its probably going to be the end of the week before I can get the car back on the dyno with the new hotside.
~Cicio
