Go Back   IWSTI.com: Subaru WRX STI Forums > IWSTI Featured Members > Power Bragging
Old 06-04-2009, 08:54 AM   #1
Feedback Score: 6 reviews
Car: Silver 04 WRX STi
Fav Mod: HFS-6
IWSTI Addict since: Mar 2008
Default 2004 STI - 353whp/399wtq
Numbers
Dyno: Dynomite
Tuner: Jon@HB Speed
Wheel HP: 353
Wheel TQ: 399
Ambient Temp: 65
Elevation: sea level
Car Info
Year: 2004
Engine Management: stock
Turbo: stock
Intercooler: stock
Meth Kit: HFS-6 with 50/50 mix
Injectors: stock
Intake/Inlet: AEM CAI/APS 3" hard inlet
Headers: Vibrant UEL
Uppipe: Helix flex
Downpipe: APS catted (full 3" aps tbe)
CBE: APS 3"
Other Power Mods: Walbro fuel pump, 1 step colder plugs, TGV delete w/3mm phenolic spacers, IZIX A/O separator and CC breather with PCV delete
EDIT** and (obviously) a boost solenoid
91 OCT only map:
91 OCT map
This was part of my build plan to max out the stock turbo using the HFS-6 aquamist kit. The kit came a bit late, and I missed my window at HB Speed, so I have a couple of weeks with this setup untill I get the meth kit in place. There is no baseline dyno because I was previously tuned at a different (unknamed) shop, and the tune knocked so bad that I basically couldn't go more than about 7lbs boost. The tune went awesome last night, but I am having the dreaded ABS/DCCD issues this morning....
Edit**
DCCD fixed- it was just an ABS wheel speed sensor that was disconnected. 2 minutes, $0.
***UPDATE***
Meth map:
wackbards is offline   Reply With Quote
Old 06-04-2009, 10:57 AM   #2
Car: 05 Subaru STI
IWSTI Addict since: Jul 2005
Default Re: 2004 STI - 335whp/379wtq
man i shed a little tear each time I see a stock turbo dyno with a 40-50 hp drop from peak to redline. I really wish subaru had a better designed head/motor/turbo that made decent power to fuel cut from the factory.
Nice #'s though 21 psi on craptaine (91) seems a bit high, i guess the car liked it there though.
Illusive is offline   Reply With Quote
Old 06-04-2009, 11:11 AM   #3
Fav Mod: HFS-6
yeah, the VF39 is like an ADD kid with a gallon of Kool-aid in him- like a bat out a hell at first, then comatose. That's what the HFS-6 kit is for on the 12th of this month...
As far as 91 octane goes, judging by how much oil the A/O separator eliminated from the intake, there is some real room for improving the actual octane in the combustion chamber by eliminating the oil.
Old 06-04-2009, 02:53 PM   #4
Car: UGM 07 STi
Fav Mod: APS R2 + tune
IWSTI Addict since: Feb 2008
How do you know how much oil is being removed from the intake?
Any review of the A/O separator?
tegan_ca is offline   Reply With Quote
Old 06-04-2009, 02:56 PM   #5
IWSTI Club Level 1
Feedback Score: 5 reviews
Fav Mod: realtime
IWSTI Addict since: Jan 2006
I think those are the highest numbers I've seen for straight 91oct
Old 06-04-2009, 03:11 PM   #6
Car: 05 Subaru STI
tbh they are running higher than average boost (21 psi) and the hp tapers off pretty large as boost drops to 14psi post 6,000 rpms.
the large HP number is a result of parts and boost, as you can see once boost falls hp follows suit.
at fuel cut they are making roughly 280 hp which is about what other stage 2 sti's make at that rpm.
Old 06-04-2009, 03:16 PM   #7
IWSTI Club Level 1
Fav Mod: realtime
I see that It's very hard to push that much boost with the vfxx on 91octane and keep the knock sensor happy. It's very hard to tune on 91oct in general. 91oct and ignition timing are worst enemies.
Old 06-04-2009, 04:25 PM   #8
IWSTI Addict since: Apr 2007
Hey Wackbards, I was the guy with the 07 loud black sti on the dyno before your car. nice number bro. get that meth injection in.
steve619sd is offline   Reply With Quote
Old 06-04-2009, 04:48 PM   #9
Visiting NASIOC Timeout
Feedback Score: 2 reviews
Car: 05 STi + 08 OBXT
My StuffSubaru Parts
Fav Mod: baby seats!
IWSTI Addict since: May 2004
Agreed. Nothing against the car or the tune, but 335 on a stock turbo with those mods is much higher than average.
So tell us, how does the car feel to drive?
Datadatum is online now   Reply With Quote
Old 06-04-2009, 07:37 PM   #10
Fav Mod: HFS-6
^^BWAHAHAHAHAHA!!!
Oh, God...
(nintey-nine is just a fine, nintey-nine is just a fine...)
Yes sir, I like it.
the HFS-6 meth kit is going on in a couple weeks, and that should help keep the boost up closer to redline.
As far as oil in the intake, I did a before/after check on the intake manifold, and it makes a big difference. I was actually really supprised because the IM had more oil in it than I anticipated based on what was in the IC- that little overflow line blowing oil straight into the TB is the stupidest thing man... I just deleted the PCV similar to what Crawford recommends (here is the thread IXIZ air/oil separator installed: Short review, pics, and question...).
I want to give a big thanks again to Jon and the crew at HB Speed- they really run a class act. Jon even put up with me when I called and *****ed about my ABS problem this morning! (a connector had come loose, and I thought the car may have got twanged on the dyno) He was professional, and told me no way. He was right, I learned, and the car is happy again.
IF YOU ARE IN SOCAL, GO TO THIS SHOP.
Will update after I get meth on it.
Now, I need suspension upgrades...
Similar Threads
HEAVY STi Shift Knob! (Stainless Steel Sphere) WC LATHE WERKS Vendor Announcements & Project Buildups 168 05-12-2008 06:31 PM
Hot Deals on ebay for STI vehicles as of 1/18 12 PM (auctions expiring now) Kevin Cars For Sale 0 01-18-2008 11:50 AM
2004 STI Norcal over 10k in mods!!! BEEZ Part Outs / Multiple Parts 4 08-20-2006 07:11 PM
SoCal: 2004 Blue WRX ("STi") Wagon For Sale - SOLD Ben Part Outs / Multiple Parts 18 02-19-2006 05:50 PM
2004 STI Part Out greysave Part Outs / Multiple Parts 12 01-21-2006 10:07 AM
Privacy Policy
