Go Back   IWSTI.com: Subaru STI Forums > STi Owners' Lounge > Power Bragging
Closed Thread
Old 05-01-2008, 08:21 PM   #1
Car: 07 Ltd. STG4 445/485
Send a message via AIM to John@Precision
Default 2007 STI - 446hp/443tq
Numbers
Dyno: Dynojet
Tuner: John(me) Precision Tuning
Wheel HP: 446
Wheel TQ: 443
Ambient Temp:
Elevation: Sea Level
Car Info
Year: 2007 STi 37,000miles
Engine Management: Open Source
Turbo: Blouch DOm3R
Intercooler: Perrin Stealth
Meth Kit: Aquamist HFS-5
Injectors: PE 800
Intake/Inlet: APS Inlet/ TXS Intake
Headers: GT SPec
Uppipe:GT SPec
Downpipe: HKS
CBE: HKS
MODS: STOCK BLOCK 25PSi tapering to 21, Blouch Dominator 3R, HKS EVC, GT Spec Headers, HKS TBE, TXS Intake, PE800cc, Aquamist HFS-5, APS Fuel Rails, APS Inlet, Walbro255, Perrin FMIC, suspension goodies
OTHER/NOTES: I was forced to tune this OpenSource, as the Cobb AP is not working with my car at this time. I am very eager to work out the bugs and use the AP though. I think the comparison will be interesting.
This is my car, so I was able to try quite a few different things on it to see how they work out. This was after about 10 runs, so the motor was pretty hot...The chart you see shows 2 very interesting things...
1.The Synapse 50mm Wastegate is AMAZING! it holds boost perfectly. I am really impressed with the gate vs. the Tial 44mm, but I wated to see if it was the HKS EVC holding the boost so smoothly, so we swapped in a Turbosmart Boost 'T'. Let me tell you... the gate, worked flawlessly! Both runs use the same timing curve... the red run falls off a bit after 6k... the car was really hot, and we have a small fan...LOL, its probably the small intake(need a big MAF).
2. The HKS EVC allows the car to bulid boost almost 1k sooner. The HKS really spools the turbo nicely! HKS EVC FTW. ...I stopped the MBC run because the results were there, no need to beat the car on the Dyno.
A note..I have logs to show the HKS runs, and all of them show the stock MAP sensor reading 23.5 PSI(stock Sensor maxes over 24psi), not the 25PSI the AEM 5BAR on the Dyno showed. This is consistent from other SUbies we have tested. So, is the stock sensor inaccurate after 20 PSI, or is the AEM slightly off? Not too sure, but based on my other runs with the SZ49, I think the AEM is a little high, and the stocker does lose resolution too.
Finally, the HP/TQ numbers are a little low, but I stopped adding timing...it was late. The timing curve goes from 13 tapering up to 25 by redline. I want to fatten it up around 6K. I think that will get done at the track though.
Thakns for looking.
John
John@PrecisionTuning.com
John@Precision is offline
Old 05-02-2008, 03:12 AM   #2
Fav Mod: BOV and MBC
Default Re: 2007 Sti: 446hp-443tq
Awesome numbers John. Love you car!!. Your lookin like a great canditate for my permanent tuner.
BillFromTR is offline
Old 05-02-2008, 08:07 AM   #3
Car: 06 Aspen White w. Go
Fav Mod: teH Muff
That is ridiculos. Sick job!
Next time Im at precision I want a ride!
uncle lewie is offline
Old 05-02-2008, 08:08 AM   #4
Car: UGM 07 Limited STi
Fav Mod: pro tune
like what im going for just im looking to do it without meth! nice numbers man!
limited777 is offline
Old 05-02-2008, 10:45 AM   #5
Car: 06 Aspen white STI
Send a message via MSN to whitestar
you are da man John!! I want a ride next time i go there.
whitestar is online now
Old 05-02-2008, 10:53 AM   #6
Car: 05 WRB "STI"
Fav Mod: hugeee turboooO!
nice numbers! i just went a week ago and i had a tuned to precision tuning! but i haven't scanned my graph yet! john is great guy and great tuner!
STInoel18 is offline
Old 05-02-2008, 01:23 PM   #7
Car: 06 STI / STG 4
Fav Mod: DOM 3.0R + METH!!!!
Nice #'s dude... I am gonna have to check out that WG 50mm..... Cant wait for next week when you tune the DOM 3R on my ride...
STI-LOS is offline
Old 05-02-2008, 02:45 PM   #8
Car: UGM 07 STI
Fav Mod: Driver
Was this on the original block/pistons? If so, that would be even more impressive and proves that the 07 pistons aren't weak!
atanarus is offline
Old 05-02-2008, 03:39 PM   #9
Car: 06 STI / STG 4
Yeah that is on the stock block.. When tuned right like John does the motor well be safe. He is a great tuner...
STI-LOS is offline
Old 05-02-2008, 05:19 PM   #10
Sure is, completely STOCK motor. The 07 pistons are fine, the problem was the tunes that were being done to the MY07 Sti. If you do not know how the logic works, you can accidently add timing in places where you don't mean to.... that is never a good thing.
Thanks for the kind words guys.
As always, feel free to PM/ask me any questions...I am always available.
John
Old 05-02-2008, 05:37 PM   #11
Car: Blue 07 WRX STi
Fav Mod: Stage 2
John
Thats awesome number . STOCK PISTON ? Whats the manufacturing date for the STI 07?
subaru_sti293 is offline
Old 05-02-2008, 05:58 PM   #12
Yup stock pistons. Not sure, but it is a Limited STi Number 486.
Thx.
John
Old 05-02-2008, 07:30 PM   #13
Car: '07 STi Limited #482
Bodes well for my #482.
Ive been telling ppl that forever but they all want to blame the pistons. That timing advance B table has probably claimed quite a few stock blocks by now.
WRX4ME LE 482 is offline
Old 05-02-2008, 08:02 PM   #14
I have an Invidia DP for sale if u want it...noticed your sig.
J
Old 05-04-2008, 12:13 AM   #15
Car: 06 STi
Good #'s John. Do you think that turbo setup has anything more in it if you were to go BigMaf? Just curious. Like to see you on 28psi-30psi with the 07 heads and all. 450whp on a DD is crazy fast. Would you recommend doing the HKS EVC over the Prodrive ebcs when comparing the differences in how long it takes to build boost as well as holding it/controlling its taper? Which would be more consistent? I'll be having you tune my car again soon as my intake is made up(yes, still waiting) and if you like the HKS EVC that much more, I'll ditch the prodrive for it. Your car is BAD!
neverendingmods is offline
Closed Thread
