Go Back   IWSTI.com: Subaru STI Forums > IWSTI Featured Members > Power Bragging
Old 04-29-2008, 06:23 PM   #1
Car: 07 STI Limited
Default 2007 STI - 288whp/345wtq
2007 Limited
Numbers
Dyno: Dynojet
Tuner: Scott Seigel- Topspeed
Wheel HP: 288 (93oct)
Wheel TQ: 345 (93oct)
Ambient Temp: 60 F
Elevation: Sea Level
Car Info
Year: 2007
Engine Management: Cobb AP v2
Turbo: Stock
Intercooler: Stock
Injectors: Stock
Intake/Inlet: Stock/ Drop in K&N
Headers: Maddad Coated
Uppipe: Maddad Coated
Downpipe: Cobb catted
CBE: Stock
Other Power Mods: Walbro 255
forced03 is offline   Reply With Quote
Old 04-29-2008, 06:34 PM   #2
Fav Mod: CarComfortDesign@Gmail.com
Default Re: 07 STI - 288whp/345wtq
is it me or does that seem low....
JZeezSTi is offline   Reply With Quote
Old 04-29-2008, 06:42 PM   #3
Car: 07 STI Limited
Seems a little low to me too. The car drives much better than before but I was hoping for some more on their dyno. The boost tapers to around 13lbs up top! I was told that's the worst he's seen...
Not sure what to say. I've got a little bit of an odd setup with headers/up and stock catback.
The first dyno was with Cobb 1.04 ots map. Just over 5,000 miles on the car.
Old 04-29-2008, 10:39 PM   #4
Fav Mod: Advan RS 18x9. TurboXS downpipe.
Your setup pretty much explains the healthier torque figures vs hp. Tuned + TBE should net you towards the 300whp goal
paikman is offline   Reply With Quote
Old 05-01-2008, 07:07 AM   #5
Car: Your STi ;)
Fav Mod: Everything
Default Re: 2007 STI - 288whp/345wtq
The headers kept it happy through the middle and made great tq, but it had maxed the wastegate before 6k rpm and only made 12.7 psi at 6700 rpm... The stock airbox and catback may have been holding it back a bit, but these turbos vary wildly on what they'll hold to redline. If it had held 15 psi to redline it would have made 305+whp...
Siegel
Siegel Racing is online now   Reply With Quote
Old 05-02-2008, 07:31 AM   #6
wow... I have stock header and up-pipe, with just a Titek Catless Bellmouth DP. to the Stock STI catback. running the Stage II OTS Cobb. I wonder what I can expect to put down on the Dyno. Anyone care to chime in with a guess.
Old 05-02-2008, 07:39 PM   #7
Car: '07 STi Limited #482
That's weird how some ppl cant hold boost to redline. I have mine taper to 16 psi by redline and I think im close to 17 at 6k.
Maybe it's all that increased exhaust flow with the stock turbo making this one taper so bad.
