Go Back   IWSTI.com: Subaru STI Forums > IWSTI Featured Members > Power Bragging
Old 03-30-2008, 07:33 AM   #1
BWG
Car: Blue 04 STI
Default 2004 STi - 322whp/364wtq
04 STI with 41k on the clock.
Power mods
Invida DP
Greedy EVO 2 cat back
K&N short ram intake
GM 3 port
Cobb ver 1 protune
The blue line is the old GST pro tune, Jorge at P&L did a hell of a job with this tune.
The bad, clutch was slipping on all the runs so he had to bump the power band up 500rpm or so as he was worried the clutch would die on the way home. Also the stock injectors got maxed out at 20.5psi, still running at 98% from 6700 - 7000 rpm at 20psi.
I'm replacing the clutch/flywheel and putting in bigger injectors/fuel pump and getting retuned. Jorge said these are the highest numbers he's seen on his dyno for a stage 2 STI and there is still more to have out of it.
BWG is offline   Reply With Quote
Old 04-01-2008, 01:02 PM   #2
Default Re: 04 Sti 322whp/364wtq
very nice. must be fun stuff on the street.
8cd03gro is offline   Reply With Quote
Old 04-01-2008, 02:44 PM   #3
BWG
Car: Blue 04 STI
Yeah I think i need new tires, so much torque the thing is all over the place around the corners. Even in a straight line traction is lost near the top of first and sometimes second.
Old 04-17-2008, 11:00 PM   #4
Fav Mod: Advan RS 18x9. TurboXS downpipe.
Do you have a boost log? Is the 3 port allowing you to hold more boost towards redline (would explain more power?)
paikman is offline   Reply With Quote
Old 04-18-2008, 07:01 PM   #5
BWG
Car: Blue 04 STI
makes 20psi peak and tapers to 15psi at redline.
Old 04-18-2008, 07:14 PM   #6
Car: 06 STI, 08 GSXR 750
Fav Mod: 8cm 20g
Nice numbers.
Hitman83 is offline   Reply With Quote
Old 04-18-2008, 07:57 PM   #7
Car: 05 obp sti
Fav Mod: Invidia G200
Sweet numbers man! I have similar mods and Jorge also tuned my car.
coolhandluke is offline   Reply With Quote
Old 04-18-2008, 09:05 PM   #8
Car: Blue 04 Wrx STi
Send a message via AIM to MidniteTunez
On pump gas>?
MidniteTunez is offline   Reply With Quote
Old 04-19-2008, 12:25 PM   #9
BWG
Car: Blue 04 STI
Yeap on pump gas with a slipping clutch and maxed out injectors. Had to pull the tune back a little as the injectors were running at 101.5%.
Here is the dyno run vid.
YouTube - STI final dyno
Old 04-19-2008, 12:33 PM   #10
Car: '05 Aspen White STi
Fav Mod: EQ Tuning tune
Jesus. Those are some insane numbers from a Stage 2 STi.
Old 04-23-2008, 07:03 AM   #11
Car: 04 Subaru WRX STI
Send a message via AIM to 1STI2NV
Default Re: 2004 STi - 322whp/364wtq
nice # u got there mine only put down 295whp 315wtq on stage 2 only 18psi tho
1STI2NV is offline   Reply With Quote
Old 04-23-2008, 07:06 AM   #12
Fav Mod: Bride
Send a message via AIM to Mayhem13
damn i didn't really think a stg2 sti w/protune n minimal mods would make numbers like that...u got a unicorn there bud. good stuff
Mayhem13 is offline   Reply With Quote
Old 04-23-2008, 09:25 AM   #13
BWG
Car: Blue 04 STI
Yeah that's what Jorge said, must have been a wednesday car.
Old 04-23-2008, 11:25 AM   #14
Car: 07 SWP STI
Fav Mod: Tim Bailey Protune
dynojet tho
ItalianStallion is offline   Reply With Quote
Old 04-23-2008, 02:10 PM   #15
BWG
Car: Blue 04 STI
Avarage stage 2 makes 290 - 300hp and 320 - 330tq on this dyno. Andysti has the same mods as me and dyno 305hp/331tq with a 05 STI 2 weeks before on the same dyno. Also remember there is more to be had out of this setup with bigger injectors. Only three tunning runs were made as my clutch was on the verge of failing.
