| | Thread Tools |
| Technical Contributor Level 1 Feedback Score: 0 reviews Car: 05 Subaru Sti Fav Mod: Twin Turbo | Saab and others have done it. Variable Compression Engine <<< Animation Variable Compression 2000 February: Saab showed a prototype variable compression engine at the Geneva Motor Show. This engine tries to solve the problem of being both a small, fuel-efficient engine and a large, powerful engine by changing its geometry. Devised by Per Gillbrand 20 years ago, the Saab Variable Compression (SVC) engine can vary its compression ratio between 8.0:1, for wide throttle, high-power settings and 14.0:1, for light throttle, fuel efficient operation. The trick is made possible by tilting the "monohead" (head and cylinders) by up to 4° about an axis on the left of the engine (in the diagram). This changes the distance of the cylinder head from the crank by a few millimetres - enough to change the cylinder volume at top dead centre by nearly a factor of two. By itself, lowering the compression ratio would not increase power at all but it enables the super-charger to switch to a higher boost pressure without any danger of pre-ignition. Squeezing more air into the cylinders allows more fuel to be burned - more power. The 1.6 litre, 5-cylinder prototype delivers 168kW of power and 305Nm of torque. Boost pressure varies up to a maximum of 2.8 bar. In effect, the engine can behave like a 1.6-litre motor out of a shopping trolley or like a 3+ litre engine on demand. (e.g. The 3.2 litre V6 in the 1999 Mercedes ML320 produces 160kW.)
![]() Buzz up!![]() ![]() Increasing Engine Efficiency and Power Most of us are probably anxious to get rid of internal combustion engines (ICE) and move on to electric motors. Unfortunately, refining a technology until it is affordable and performs well enough for the mass market takes a while (read up on the history of computers or cell phones), and we might not have electric cars for a few more years. In the meantime, engineers are trying to squeeze more life out of ICEs (see 5 technologies to improve ICEs). One promising technique is the use of variable compression ratios. Read on for details. ![]() How Variable Compression Ratio Engines Work In an internal combustion engine, the compression ratio tells you what the ratio is between the biggest and smallest volumes of the combustion chamber in the cylinder. The concept of modifying that ratio is very old (around the 1920s), but very few cars have actually used it (SAAB was working on it before GM took over, but that project has been shelved as far as I know).The benefits of having a variable compression ratio is that you can control much more precisely combustion and adjust the variable to get the best performance for each situation (acceleration, cruising, deceleration, etc). It becomes especially potent - in theory - when combined with other technologies like turbochargers, direct injection, variable valve timing and lift, etc. From a green point of view, this mean you could downsize an engine quite a bit while still getting enough power and achieving high thermal efficiency. It might even help with the use of (cellulosic) ethanol (which has different characteristics from gasoline), or to reduce emissions by optimizing combustion. ![]() MCE-5's Prototype Variable Compression Ratio Engine From Green Car Congress: At the upcoming 79th International Motor Show in Geneva, France-based MCE-5 Development will showcase its first vehicle application (a Peugeot 407) of a prototype 1.5-liter MCE-5 VCRi (variable compression ratio) gasoline engine. The four-cylinder 1.5L VCRi, equipped with a two-stage turbocharger, develops 220 hp (164 kW) of power (comparable to that of a 3.0L V6 engine), and 420 Nm (310 lb-ft) of torque at 1,500 rpm (comparable to a V8 gasoline engine). Fuel consumption on the NEDC is 6.7 L/100 km (35 mpg US) with 158 g CO2/km. The technology can be applied to smaller displacements, MCE-5 notes.What's interesting is that this prototype is not "equipped with GDI (gasoline direct injection) or optimized combustion chambers." The 2010 version of the engine should have these improvements and bring fuel economy to 6.0 L/100 km (39 mpg US) while producing 50 hp more! Imagine a small car that doesn't need 200+ hp. A 0.8-liter version (or whatever) could probably get very good MPG, possibly running on cellulosic ethanol made from agricultural waste. Not a silver bullet, but this technology would certainly be an improvement on the engines that we have now. ![]() Is all this just to complex to be mass produced, cost effective and reliable? |
| | #2 |
| IWSTI Clan Chairman Feedback Score: 11 reviews Fav Mod: Buying a jeep | A car that gets 35MPG and puts out over 200 HP sounds like fun to me! Here's hoping they build and bring it to market.
__________________ 2008 Lightning Red STI - Traded February 2010 Now I drive a - 2010 Jeep Wrangler Sport |
| | #3 |
| resigned Feedback Score: 9 reviews | IDK... Sounds like something that's just going to spend a lot of time borked and cost a mint to build/repair to me... Innovative but impractical design, IMO. |
| | #4 |
| Developing Technical Mastery Feedback Score: 1 reviews Car: 04 WRB STi Fav Mod: Me! | Looks like a lot of parts to break.
__________________ James 04 Blue/Silver STi 92 Ducati 900SS 1972 Mustang Mach 1 "Brakes are the enemy of speed." "Fear causes hesitation, and hesitation will cause all of your worst fears to come true." |
| | #5 |
| Developing Technical Mastery Feedback Score: 0 reviews | |
| | #6 |
| Technical Contributor Level 1 Feedback Score: 0 reviews Car: 05 Subaru Sti Fav Mod: Twin Turbo | If car companies want to make more fuel efficient cars, this is one of many thing to at least look at. |
| Thread Tools | |
Similar Threads | ||||
| JDM Engines In Stock EJ257 STi $3500-EJ255 FXT $2500-EJ205 $2000- VF48 In Stock | Gruppe-S | Engine/Power/Exhaust | 31 | 11-11-08 03:46 PM |
| JDM Engines Just Arrived EJ207 STi Spec.C/EJ20 Twin Turbo/EJ25 FXT/EZ30/EZ36 | Gruppe-S | Engine/Power/Exhaust | 6 | 09-22-08 03:22 PM |
| Engines Back In Stock! VF34-Helix DP-Gruppe-S Manifold-Turbo Back Combos-Free Dampers | Gruppe-S | Engine/Power/Exhaust | 13 | 10-08-07 05:42 PM |
| *Discussion* Why has a higher compression ratio been a bad idea on a turbo car? | modaddict | 2.5 Liter/Litre Factory Motor | 17 | 03-26-07 02:10 PM |
| Sti compression ratio and why its good | dlowman | Drivetrain Components | 23 | 05-01-03 11:27 PM |
