Go Back   IWSTI.com: Subaru WRX STI Forums > Beyond Off Topic > Off Topic
Old 07-28-2008, 07:52 PM   #1
Car: 06 BLACK STI!!!
Fav Mod: Annual Bonus!!
IWSTI Addict since: Jul 2006
Send a message via AIM to all4bspinnin
Default Can anyone here explain the valve technology in F1 cyclinder heads?
I have been reading the the pneumatic valves, rotary valves etc, and im trying to find a clear simple explanation of what exactly is going on...
any car guru's car to help...
thanks
all4bspinnin is offline   Reply With Quote
Old 07-28-2008, 10:45 PM   #2
Hungry Hungry Hoodscoop
IWSTI Addict since: Apr 2006
Trader Rating: (23)
Default Re: Can anyone here explain the valve technology in F1 cyclinder heads?
Here's a good, brief, simple explanation of pneumatic valve return systems:
23 How do pneumatic valve return systems work ?
Some good diagrams here to give a good visual. they're old drawings from when they first started using pneumatic valves but they're still pertinent as their basic function remains the same: F1 Engines _ Valve technology
Electro hydraulic valves are said to be the future in F1 but I haven't any really good articles detailing them. all i've been able to find is very basic info.
Old 07-29-2008, 12:11 AM   #3
Car: 07 Subaru Impreza 2.
Fav Mod: Lights!(headlight, gauge, etc)
IWSTI Addict since: Aug 2005
Send a message via AIM to STidriver12
hmm, so that pneumatic valves is similar to shock damper?
also its allow to rev more higher rpm like f1's engine that went over 10k rpm?
STidriver12 is offline   Reply With Quote
Old 07-29-2008, 05:27 AM   #4
yea, they have all sorts of crazy stuff going on... i was researching it for an hour or so last night... i was able to find a few places, like the one posted above.... i have an understanding of whats happening... i guess i just need to read a little better...
Old 07-29-2008, 05:36 AM   #5
And then,.... my favorite... the rotary valve... simple yet amazing...
The Coates Spherical Rotary Valve Engine is the most advanced in the world, with the most positive valving system ever built. The breathing capabilities of the system are almost double that of a poppet valve. For instance: a static test of a five-litre poppet valve engine on an airflow machine produced a reading of 133 cubic feet per minute (CFM) with valve fully opened. The five-litre Coates Spherical Rotary Valve Engine on the same machine, however, produced a reading of 319 CFMs fully opened; a colossal advantage in airflow comparison. A five-litre poppet vavle engine tested on a dynomometer under the same loads and conditions at 5500 produced 480 BHP and 454 foot pounds of torque. The maximum RPMs on the poppet valve engine were 5700 RPMs; the Spherical Rotary Valve Engine in comparison reached 14,850 RPM's, The Coates Spherical Rotary Valve comprises two spherical rotary valves assembled on two separate shafts - one for inlet and one for exhaust. They rotate on ceramic carbon bearing with no oil lubrication, the spheres do not make contact with any part of the housing. The seals are a floating type and are also made of a ceramic material. They have two piston rings and are floating in a small cylinder-type chamber, they are activated by the compression and the combustion strokes of the engine which allows 100 percent sealing effectiveness, when compressed.
Because the valves rotate away from the combustion chamber and are vented and charged on the opposite side of each sphere, this creates a lower combustion chamber temperature, allowing for higher compression ratios to be used thus creating an extremely efficient engine. Some of the Coates Spherical Rotary Combustion Engines are at 12 to 1, 13 to 1, 14 to 1 and 15 to 1 compression ratios depending on the application.
Old 07-29-2008, 11:29 AM   #6
never heard of that kind of valve... but its awesome! wow
what if subaru use this rotary valve, there will be any improve powers as higher CFM?
Old 07-29-2008, 11:32 AM   #7
Trader Rating: (23)
from my understanding, it is expensive, difficult to tune, and currently has poor low speed (idling) characteristics similar to a high duration/lift cam.
Old 07-29-2008, 11:50 AM   #8
hmm sucks, but at least its still awesome valves
Old 07-29-2008, 12:50 PM   #9
Car: 06 WRB STi
Fav Mod: moar boost
IWSTI Addict since: Dec 2006
I did some research on these Coates valves in college and according to my prof, Coates' claims are not backed up with facts and is considered a bit of a hack in the research community. At least to my understanding. It looks really cool though.
mEnTaL is offline   Reply With Quote
Old 07-29-2008, 12:53 PM   #10
Im going to email the company when i get home and see what they say about doing some heads on a boxer motor and possibly a forced injection version...
Btw, snorky... where did you get your info from?
Old 07-29-2008, 01:02 PM   #11
here's some more info
http://home.people.net.au/~mrbdesign...utoTechBRV.pdf
Old 08-01-2008, 08:53 AM   #12
Car: 05 STi, OBP
Fav Mod: Agile Protune
Send a message via AIM to xlsupreme
yeppers. found the same thing to be true. It's not in production anywhere, and you won't find a car with it, even as a test bench. I wish it hadn't have flopped, it looks like a winner, but who knows...
xlsupreme is offline   Reply With Quote
Old 08-04-2008, 03:05 PM   #13
GT R US
IWSTI Addict since: Dec 2003
nice find.
Old 08-05-2008, 05:14 AM   #14
Originally Posted by Neanderthal Racing View Post
nice find.
interesting read huh...
i didnt think f1 banned new technology...
