Go Back   IWSTI.com: Subaru STI Forums > Beyond Off Topic > Off Topic
View Poll Results: Do you park in gear?
YES 23 47.92%
NO 14 29.17%
WTH R U TALKING ABOUT? 1 2.08%
F*** Manual cars! 1 2.08%
Sometimes.... 9 18.75%
Voters: 48. You may not vote on this poll
Old 07-21-2008, 08:07 PM   #16
Car: 05 PSM STi - Sold
Fav Mod: V1
Default Re: L2park-in-gear.........
there are no hills in FL.
Late is offline   Reply With Quote
Old 07-21-2008, 08:19 PM   #17
Fav Mod: Flat 6
My gf's parent's house has a driveway that sits at a 70* angle or so, and I have to CRANK on the e-brake and leave it in gear for it not to move.
ACHAHockey is offline   Reply With Quote
Old 07-21-2008, 08:32 PM   #18
Car: 05 STi |STOCK|
Fav Mod: Not a post 07 sti fan
I only park in gear when on a hill. I also turn the wheel so that the car will go towards the curb should the ebrake fail.
chargedvette02 is offline   Reply With Quote
Old 07-21-2008, 09:09 PM   #19
Car: 06 Aspen white
Fav Mod: Surfboard in passenger seat
In gear and e-brake every time. If nose is uphill, i.e. car will roll backwards, I put it in reverse. Nose downhill, put it in 1st. Don't want to risk turning the motor backwards, but honestly I don't know if that would cause damage.
Track is offline   Reply With Quote
Old 07-21-2008, 10:10 PM   #20
Car: cars, pball and all
Send a message via AIM to awdrev
Originally Posted by disturbed1
There is no way the hand brake can fail unless it is not set properly.
funny actually.......
E-brake is simply a metal wire pushing two pads to hold the "entire weight of your car" how can it fail?
Wire can break
The car could be put in motion by strong winds and once the car is rolling your SUPER ebrake is going to do nothing.
The car could be put in motion by someone "tapping" you from behind OR front.
Someone towing your car can break the wire (neutral FTW now your car is a FREE machine!)...
etc etc etc
In conclusion, the e-brake + neutral parking is simply FAIL. One of my cousins almost killed herself when she had to go chasing for her car which BTW ended up crushing her leg between another car.
Parking in gear is 99.9% safer, makes it hard to steal and anyone that drives stick "properly" most likely does so....
now back to your "impossible to fail".... I wonder how my speakers failed, they were also setup properly....
awdrev is offline   Reply With Quote
Old 07-21-2008, 10:38 PM   #21
STI Guru
Car: 2001 Honda Accord EX
Fav Mod: STickers
Send a message via AIM to 305STi Send a message via MSN to 305STi Send a message via Yahoo to 305STi
Yea
305STi is offline   Reply With Quote
Old 07-22-2008, 11:03 AM   #22
First or second gear. Technically speaking, if you leave it in say 6th, it would be technically easier to push the car than in first, because the engine wouldn't need to turn as much per each actual wheel turn of the drive wheels.
In any case, any gear is enough to keep a car solid on even a hill.
Old 07-22-2008, 11:27 AM   #23
Car: 06 WRB STI
Fav Mod: getting out of the army
Just the ebrake. I have a TT so leaving it in gears means waiting 30secs everytime I get out. Also in FL as stated earlier, we have no hills.
Unclejesus is offline   Reply With Quote
Old 07-22-2008, 03:30 PM   #24
Car: 06 subaru wrx sti
Fav Mod: royal purple
Originally Posted by m3_arch View Post
My brother's 67' vw suffered the fate of a failed handbrake cable. Granted it is an old car, but things can go wrong. Regardless it rolled about 35 yards down a slight hill in my my cul de sac and met the rear of my father's delivery truck (rear lift). Needless to say, bug was totalled.
which is why the DMV hand books states to turn the wheel so that if the e-brake fails it will hit the curb.
disturbed1 is offline   Reply With Quote
Old 07-22-2008, 03:33 PM   #25
Not sure what the hell to do though in a driveway as there is no curb.
Old 07-22-2008, 04:59 PM   #26
Car: The Vroom-mobile
Fav Mod: JDM Gears
handbook tells you what to do in this scenario as well. Turn it so the car rolls off the road
