Go Back   IWSTI.com: Subaru STI Forums > Owners' Lounge > News & Rumors
Old 08-27-2006, 08:00 AM   #1
wdb
dances with roads
Default 2007 STI and STI Limited -- Only the FACTS
No conjecture, no commentary, no love it / hate it. Nothing but factual information. I will delete any drek.
I'll start things off with the spec sheet from SoA Media Center.
2007 Subaru Impreza<sup>®</sup> WRX<sup>®</sup> STI<sup>®</sup> Limited
Specifications
<table class="MsoNormalTable" style="border: medium none ; border-collapse: collapse;" border="1" cellpadding="0" cellspacing="0"> <tbody><tr style=""> <td style="border: 1pt solid windowtext; padding: 0in 5.4pt; width: 1.7in;" valign="top" width="163">
Engine
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0in 5.4pt; width: 4.95in;" valign="top" width="475">
4-cylinder, horizontally opposed (Boxer); specially reinforced die-cast aluminum block with semi-closed deck and integral cast iron cylinder liners; aluminum alloy cylinder heads
</td> </tr> <tr style="height: 18.4pt;"> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0in 5.4pt; width: 1.7in; height: 18.4pt;" valign="top" width="163">
Displacement
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0in 5.4pt; width: 4.95in; height: 18.4pt;" valign="top" width="475">
2,457 cc (150 cu. in.)
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0in 5.4pt; width: 1.7in;" valign="top" width="163">
Valvetrain
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0in 5.4pt; width: 4.95in;" valign="top" width="475">
Double overhead belt-driven camshafts (DOHC), 4 valves per cylinder, Subaru Active Valve Control System (AVCS) variable valve timing
Fuel/Induction/Engine management
Sequential multi-port fuel injection (MFI) with multi-spray injectors, Electronic Throttle Control (ETC) system, turbocharger and intercooler
Compression ratio
8.2:1
Max. boost pressure
14.5 psi (750 mm Hg)
Horsepower
293 @ 6,000 rpm (SAE Certified)
Torque
290 lb.-ft. @ 4,400 rpm (SAE Certified)
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0in 5.4pt; width: 1.7in;" valign="top" width="163"> </td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0in 5.4pt; width: 4.95in;" valign="top" width="475"> </td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0in 5.4pt; width: 1.7in;" valign="top" width="163">
Transmission
6-speed manual with transmission cooler
Symmetrical All-Wheel Drive system
Symmetrical All-Wheel Drive with DCCD (Driver Control Center Differential), 41:59 torque split, mechanical and electronic center limited-slip center differentials, helical limited-slip front differential and Torsen<sup>®</sup> limited-slip rear differential
Chassis
Unitized construction; 4-wheel independent inverted-strut suspension
</td> </tr> <tr style="height: 40.45pt;"> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0in 5.4pt; width: 1.7in; height: 40.45pt;" valign="top" width="163">
Front suspension
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0in 5.4pt; width: 4.95in; height: 40.45pt;" valign="top" width="475">
MacPherson-type inverted struts with aluminum-alloy lower L-arms and aluminum transverse links, liquid filled L-arm rear bushings, crossmember stiffener bar, coil springs, stabilizer bar and negative-scrub geometry
Rear suspension
MacPherson-type inverted struts with coil springs, crossmember stiffener plates, trailing arms, twin aluminum parallel links and stabilizer bar and negative-scrub geometry
Brakes
Power assisted 4-wheel disc with 4-channel, 4-sensor Super-Sport anti-lock brake system (ABS) with g-sensor; Electronic Brake-force Distribution (EBD)
Front
12.7 x 1.2-in., ventilated with four-piston fixed position calipers
Rear
12.3 x 0.8 in., ventilated with twin-piston fixed position calipers
Steering
Quick-ratio rack-and-pinion with engine-speed controlled variable power assist, load-sensing valve, variable-capacity power steering pump and power steering fluid cooler
Wheels
17 x 8JJ Enkei<sup> </sup>brand aluminum alloy
Tires
225/45ZR17 Bridgestone Potenza RE070 summer/directional
Dimensions
Wheelbase
99.4 in.
</td> </tr> <tr style="height: 10.1pt;"> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0in 5.4pt; width: 1.7in; height: 10.1pt;" valign="top" width="163">
Length
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0in 5.4pt; width: 4.95in; height: 10.1pt;" valign="top" width="475">
175.8 in.
Width
68.5 in
Height
56.3 in.
Curb weight
3,351 lb.
</td> </tr> </tbody> </table>
Old 08-27-2006, 08:16 AM   #2
wdb
dances with roads
Default April 2006 Press Release
SUBARU UNLEASHES IMPREZA<sup>®</sup> WRX<sup>®</sup> STI<sup>®</sup> LIMITED FOR 2007
<!--[if !supportLists]-->·<!--[endif]-->Less Show, Same Go
<!--[if !supportLists]-->·<!--[endif]-->Leather Interior, Power Moonroof
<!--[if !supportLists]-->·<!--[endif]-->Only 800 Numbered Units Available
NEW YORK, <st1:date month="4" day="13" year="2006" w:st="on">April 13, 2006</st1:date> Subaru of America, Inc. today unveiled the 2007 Impreza WRX STI Limited model at the New York International Auto Show. The new edition of the road-conquering Impreza WRX STI packages creates greater comfort and refinement with subtler exterior styling, but does not sacrifice the performance of this street legend.
The WRX STI Limited will be available in the fall in a limited run of 800 numbered units, 400 in Satin White Pearl and 400 in Urban Gray Metallic.
The 2007 WRX STI Limited delivers all the power and performance of the standard model. This new limited-edition version adds a layer of refinement and design detail enhancements targeted at a new group of driving enthusiasts looking for supercar performance but with an understated demeanor. Designed by Subaru Tecnica International (STI), the high-performance and motorsports subsidiary of Fuji Heavy Industries Ltd., the WRX STI Limited is descended from the Subaru WRC Rally car.
The WRX STI redefined the performance car category when it was introduced in 2004. We know some enthusiasts have resisted the temptation to buy one simply because they want more everyday driving comfort and refinement, along with less aggressive styling, said Fred Ad****, executive vice president, Subaru of America. Now, with the STIs reputation for pure performance unquestioned, we recognized an opportunity to broaden the cars appeal.
Less Show, Same Go
The 2007 WRX STI Limited stands apart from the standard model with an appearance thats more low-key, and even stealthy. A new trunk-mounted lip spoiler replaces the standard models large dual-plane rear spoiler, and the black
--more--
aluminum roof vane spoiler is deleted. A new, deep front lip spoiler further distinguishes the WRX STI Limited from the standard model.
New Enkei wheels with high-luster paint replace the BBS<sup>®</sup> wheels, keeping the same 17 x 8-in. size and 225/45 ZR17 Bridgestone Potenza RE070 directional performance tires. Behind the new wheels, black Brembo<sup>®</sup> brake calipers with white lettering have a more reserved appearance than the gold and red-painted calipers on the standard WRX STI.
All WRX STI Limited models feature distinctive black gloss B-pillar paint and high luster paint for the exterior mirrors, and this special edition model includes standard fog lights.
New Refined Interior Keeps the Focus on Performance
The interior of the 2007 Impreza WRX STI Limited balances the performance-directed design and attitude with a dose of refinement. Most notably, the WRX STI Limited replaces the perforated blue high-grip Alcantara<sup>®</sup> fabric seating surfaces with leather and new dark gray metallic bezels and interior trim.
For the first time in a WRX STI, the performance-design front seats are heated for all-season comfort. Also enhancing all-season driving pleasure, the 2007 WRX STI Limited features the first-ever power glass moonroof on this model. Beyond the changed interior appearance, additional features include new carpeting with improved sound insulation materials, an auto-dimming compass rear view mirror and an audio system input jack for an iPod or other digital music player. Finally, each car in this series gets a sequential number plate.
The standard automatic climate control system integrates cabin air filtration. SIRIUS Satellite radio availability enhances the versatility of the standard 120-watt AM/FM premium stereo, which includes a 6-disc in-dash CD changer and six speakers.
Rally Tested and Road Ready
All Impreza WRX STI models are powered by a turbocharged and intercooled 2.5-liter DOHC Boxer engine producing 293 horsepower at 6,000 rpm and 290 lb.-ft. of peak torque at 4,400 rpm. The Subaru Active Valve Control System (AVCS) variable valve timing technology helps provide strong torque characteristics throughout the engines operating range. A manually operated water spray feature helps to bolster intercooler efficiency during spirited driving.
All WRX STI models are exclusively equipped with a 6-speed manual transmission that features carbon-plated double-cone synchronizers on 4th, 5th and 6th gears to help ensure durability.
Driver Controlled Center Differential (DCCD) <st1:street w:st="on">All-Wheel Drive<
From its launch, the WRX STI has been equipped with one of the most advanced and most performance-directed <st1:street w:st="on"><st1:address w:st="on">All-Wheel Drive</st1:address></st1:street> systems on the market, regardless of vehicle segment. The Driver Control</st1>lace> Differential (DCCD)
--more--
<st1:street w:st="on"><st1:address w:st="on">Symmetrical All-Wheel Drive</st1:address></st1:street> system uses a planetary-type center differential to provide a 41:59 torque split, with automatic and manual differential modes.
Center differential lock-up is controlled by both a mechanical limited-slip type differential and an electronically controlled limited-slip differential. The mechanical limited-slip differential activates and operates initially in response to changes in engine torque, improving overall vehicle stability when accelerating or decelerating. In automatic mode, the electronic limited-slip differential controls the differential lock-up by evaluating the amount of lock-up in the mechanical limited-slip. The total amount of lock-up is based on the combination of both differentials. A steering sensor input improves torque transfer response by more accurately relaying the cars cornering situation.
Set in automatic mode, the DCCD system can vary the torque distribution ratio as needed in response to vehicle acceleration, deceleration, steering angle, cornering force and wheel slippage.
In manual mode, DCCD allows the driver to select center differential lock-up to optimize <st1:street w:st="on"><st1:address w:st="on">All-Wheel Drive</st1:address></st1:street> performance for varying driving conditions. The driver first selects manual mode with a console-mounted button and then turns a thumbwheel on the center console to select from among six levels of lock-up. Increasing the locking factor keeps more power at the front wheels (max. 50:50 torque split with 100 percent lock-up selected), which the driver might want in certain driving conditions or on particular road surfaces.
A helical-type limited-slip front differential and Torsen<sup>®</sup> limited-slip rear differential help to optimize power distribution side-to-side, helping to prevent the inside wheels from slipping during cornering.
Competition-Bred Chassis
A super-stiff Ring Frame Reinforced body structure with a hydroformed front subframe provides the foundation for the high-integrity Impreza platform. Compared to the standard WRX models, the WRX STI models are lowered by 0.4-inch to help lower the center of gravity.
The 4-wheel independent suspension inherits its inverted-strut technology from the Impreza WRC competition car. Aluminum front suspension lower control arms and aluminum rear suspension lateral links reduce unsprung vehicle weight. A quick-ratio steering system yields 2.6 turns lock-to-lock, and the steering rack uses a cannon mount for greater rigidity that improves on-center response.
The powerful Brembo Performance Brake System employs front discs measuring 12.7 inches in diameter and 1.2-inch thick and utilizing 4-piston, fixed-position calipers. The rear discs are 12.3 inches in diameter and 0.8-inch thick and use 2-piston, fixed-position calipers.
--more--
A combination of Electronic Brake-force Distribution (EBD) and the Super Sport Anti-lock Braking System (ABS) helps to reduce stopping distances and understeer compared to conventional ABS systems. EBD provides precise control of braking pressure between the front and rear wheels based on the vehicle load to improve stability and stopping distances. Super Sport ABS, using input from a lateral-g sensor, can control the braking forces at each rear wheel independently, optimizing the braking ability during hard cornering to help reduce understeer.
All Impreza, WRX and WRX STI models are equipped as standard with the Subaru Advanced Frontal Air bag system and front seat head/chest side impact air bags (SRS). The drivers side air bag deploys according to the drivers proximity to the steering wheel, as measured by a sensor on the seat track. In the passenger side front seat, a sensor module detects weight on the passenger seat first determining if its occupied, and if so by a child or adult to control air bag deployment.
For additional information about Subaru of America, Inc. and Subaru vehicles, visit the media website at www.media.subaru.com.
About Subaru of America, Inc.
Subaru of America, Inc. is a wholly owned subsidiary of Fuji Heavy Industries Ltd. of Japan. Headquartered in Cherry Hill N.J., the company markets and distributes All-Wheel Drive Subaru vehicles, parts and accessories through a network of nearly 600 dealers across the United States. Subaru is the only car company that offers Symmetrical All-Wheel Drive as standard equipment on every vehicle in its product line.
Old 09-01-2006, 05:17 AM   #3
wdb
dances with roads
The original post can be found here:
Is the 07 STI Limited suspension really going to be different????
Originally Posted by czechsmix
The following was taken directly from the Subaru 2007 New Model Update document available on the Subaru Technical Information System. I have the complete pdf file for anyone who wants it.
2007 IMPREZA
ENGINE
2.5L SOHC: (NON-TURBO)
Horsepower: 173 HP @ 6000 RPM
Torque: 166 LB-FT @ 4400 RPM
2.5L INTERCOOLED TURBO
Horsepower: 224 HP @ 5600 RPM
Torque: 226 LB-FT @ 3600 RPM
2.5L INTERCOOLED HIGH-OUTPUT TURBO
Horsepower: 293 HP @ 6000 RPM
Torque: 290 LB-FT @ 4400 RPM
The WRX STI and WRX STI Limited now utilize solid rubber engine mounts
The Sodium filled exhaust valves have been deleted from the WRX STI and WRX STI Limited
The WRX STI and WRX STI Limited now have a revised cylinder head design to improve cooling
EMISSIONS
The WRX STI and WRX STI Limited now comply with the LEV 2 emissions rating
The WRX STI and WRX STI Limited now have a secondary air pump to improve emissions
TRANSMISSION
The WRX STI and WRX STI Limited now have new gear ratios in the 2nd, 3rd, and 4th gear for
improved fuel economy and drivability
ELECTRICAL
The WRX STI and WRX STI Limited now utilize a 110A alternator
AWD SYSTEM
The WRX STI and WRX STI Limited now utilize a TORSEN Limited Slip Rear Differential in the for enhanced performance
WHEELS
17 inch 10-spoke aluminum-alloy wheels with 225/45R17 tires are standard on all WRX STI Limited models
SUSPENSION: ALL WRX SEDAN
Front:
Aluminum alloy lower L-Arms have been changed to steel on the front suspension of the WRX sedan
Rear:
Aluminum alloy lower parallel links have been changed to steel on rear suspension of the WRX sedan
SUSPENSION: STI AND STI LIMITED
Front:
The high caster settings used in 2006 have been changed to normal caster settings for 2007
Rear:
The 20mm rear stabilizer bar for 2006 has been changed to a 19mm stabilizer bar for 2007
WHEELBASE:
The wheelbase of the WRX STI and WRX STI Limited is 99.4 due to the normal castor settings of the suspension
BRAKES
The WRX STI Limited has black Brembo brake calipers with white lettering
AERODYNAMICS
The WRX STI Limited has a new trunk lip spoiler
INSTRUMENT PANEL
The WRX STI Limited has new Dark Gray metallic trim on the audio bezel, center HVAC vents and side HVAC vents
The WRX STI Limited has new red hazard button
The ashtray has been replaced with a storage pocket on 2.5i, WRX TR, and Outback Sport models
The ashtray has been replaced with an auxiliary audio input on WRX, WRX Limited, WRX STI, WRX STI Limited, and Outback Sport Special Edition
The lighter socket has been replaced with a standard power outlet on all Impreza models
SEATS
The WRX STI Limited models have Anthracite Black Perforated Leather Trimmed Seating with Embroidered Gray STI Logo in Front Seat
The WRX STI and WRX STI Limited models now have a rear seat center armrest with trunk passthrough as standard equipment
AUDIO SYSTEM
The WRX, WRX Limited, WRX STI, and WRX STI Limited receive the following new audio system:
120 watt AM/FM Premium Audio System including 6-disc In-Dash CD Changer
6 Upgraded Speakers
Auxiliary Audio Input
MP3/WMA capability for the CD player
SIRIUS Satellite Radio Capability
Volume Memory when switching between audio modes
The Outback Sport Special Edition audio system includes all of the items listed above with the
addition of the following items:
120 watt Subwoofer
SIRIUS Satellite Radio Receiver (Port Installed)
<!-- / message -->
Old 09-01-2006, 06:09 AM   #4
Car: 2007 STI Ltd.
Send a message via MSN to czechsmix Send a message via Yahoo to czechsmix
Here are some of the first pictures of the STI Limited Edition.
Seems people are taking delivery in California. Mine is projected to be in by 9-8-2006. I'm excited as heck!!!
czechsmix is offline   Reply With Quote
Old 09-02-2006, 08:55 AM   #5
Photos....
http://www.subiegal.com/gallerymain/...ti_limited.htm
they are arriving
Jamie
SubieGal is offline   Reply With Quote
Old 09-08-2006, 10:43 AM   #6
I posted this on Nasioc:
Here listed are the mph at 7,000 RPM's on the 2007 STi's.
For all of you drag racers out there, look at 4th gear
1st / 2nd / 3rd / 4th / 5th / 6th
35.4 / 57.6 / 84.6 / 113.2 / 132.5 / 170.2
And for those who will be able to trap at speed 114+, the shift to 5th will be less of a drop than before... Much better gearing in almost everyway.
Borti is offline   Reply With Quote
Old 09-08-2006, 02:44 PM   #7
Originally Posted by cndxrs
can anyone confirm if the limited will also be offered in canada? i have seen nothing on the website as of early this week... odd that some dealers are already seeing delivery and there is noting available here yet... i suppose they could be imported the same
No-go on Canada. 800 only to the USA.
Have to import them..............
Old 09-20-2006, 06:59 PM   #8
Edmunds.com has posted info about the '07 Impreza trims including the non-limited and limited STI. It still needs some work though. For instance 2 blatant errors I saw with http://www.edmunds.com/new/2007/suba...20/colors.html are it only shows SWP and WRB as the exterior colors and "Anthracite Black cloth, leather" for the non-limited STI http://www.edmunds.com/new/2007/subaru/impreza/100796920/options.html
shows SWP, OBP, UGM, CGM and WRB fog lamp trim covers which seems plausible for the exterior.
wrxcelent is offline   Reply With Quote
Old 10-26-2006, 01:02 AM   #9
Car: 06 STI
Fav Mod: the driver
can someone spell out all the EXACT differences between the 2006 sti and the 2007 sti, like you guys did last year for the 2005 Vs. 2006 thread ??
gearing, new stricter emissions,
the 2nd roof wing is still on the reg. sti, but not on the ltd sti
jason bouchard is offline   Reply With Quote
Old 11-01-2006, 02:46 AM   #10
Car: 06 STI
Fav Mod: the driver
new type injector clips ( gold) top feed injectors, older ones were side feeds . new bigger wastgate port on turbo, much safer/ smarter/ faster ECU,
new gear ratios that enable you to go to 114 mph in 4th ( important for the drag racers)
this can all be checked with doug over at topspeed
Old 11-08-2006, 07:29 AM   #11
Car: CGM 07 STi Stage 1
Fav Mod: Gabedude Stage 1 Flash
Here is the list I got from my dealer (I talked to several and this is the only guy who knew of any changes, they are one of the better Chicago dealers):
-Base Price is up $500
-Gear ratios have changed for improved in town drivability (see above)
-Helical type TORSEN limited slip rear differential (as noted earlier)
-Rear center armrest with trunk pass-thru
-Secondary exhaust emissions air pump that complies with LEV2 emissions ratings
-Revised cylinder head design for improved cooling
-110 amp alternator
Hope that helps
stlb5 is offline   Reply With Quote
Old 12-06-2006, 11:53 AM   #12
From the "Subaru Drive Performance" magazine "Version 3.2".
Revisions for all 2007 STI's:
Engine:
  • Cylinder heads redesigned (improved cooling)
  • Alternator - from 90 to 110 amps
  • Power output specs revised (293 hp vs. prior 300hp, specs only output is identical to prior years)
  • Deletion: sodium-filled exhaust valves
Transmission:
  • Revised second, third, and fourth gear ratios (improved fuel economy and drivability):
    • First: 3.636
    • Second: 2.235
    • Third: 1.521
    • Fourth: 1.137
    • Fifth: 0.971
    • Sixth: 0.756
Mechanical:
  • Solid rubber engine mounts
  • TORSEN limited-slip rear differential
  • Steel lower front L-arms and rear parallel links (replaces aluminum alloy)
  • Rear stabilizer bars - from 20mm to 19mm
Exterior:
  • Four-light headlights
  • Combination taillights
  • Wheel-base from 100.0" to 99.4" (caster from high to normal)
Interior:
  • Audio jack replaces ashtray
  • Power outlet replaces lighter socket
  • Rear center armrest with trunk pass-through
  • 120-watt AM/FM premium audio system including six-disc in-dash CD changer:
    • Six upgraded speakers
    • Aux audio jack
    • MP3/WMA capability for CD player
    • SIRIUS Sat radio capability
    • Volume memory when switching between audio modes
Revisions for 2007 STI Limited:
Exterior:
  • 17" x 8.0" 10-spoke aluminum-alloy wheels painted High Luster Silver
  • Trunk lip-spoiler
  • Projector-beam halogen fog lights
  • High mount stop light on rear shelf
  • Black gloss B-pillar
  • Power moonroof
  • Black front lip spoiler with STI logo
  • Driver/passenger fender liner
  • Deletions:
    • STI door decal
    • roof vane spoiler
Interior:
  • Heated front seats with embriodered Gray STI logos
  • Carpet with increased sound insulation
  • Dark Gray Metallic interior trim
  • Dark Gray HVAC controls with silver trim rings
  • Red hazard button
  • Anthracite Black perforated leather-trimmed seating
  • Dark Gray floor mat surging
  • Commemorative number plate
  • Auto-dimming compass mirror
Mechanical:
  • Brembo black calipers, white lettering
Loterbol is offline   Reply With Quote
Old 12-09-2006, 03:34 PM   #13
Car: 07 UGM STI 121
Fav Mod: Trooper convention, somewhere else
This is incorrect. I took a magnet to the lower arm as well as the front sway. The magnet sticks to the sway but not the Lower arm. The lower arm end is also machined.
Red Rocket is offline   Reply With Quote
Old 02-28-2007, 10:33 AM   #14
Car: Gray 08 STi
Fav Mod: Nut behind wheel
Transmission:
    • First: 3.636
    • Second: 2.235
    • Third: 1.521
    • Fourth: 1.137
    • Fifth: 0.971
    • Sixth: 0.756
I'm particularly interested in the tranny changes since my 06 hits the rev limiter in 4th coming out of T4 at MAM, which is an ugly place to hit it and will get uglier when I'm using sticky tires that'll let me carry more speed into the turn.
Does anyone have a list of the ratios in the 06 or their 7k-rpm speeds so I can analyze the two boxes side-by-side and further convince myself the tranny is enough reason to trade in?
bytor is offline   Reply With Quote
Old 03-07-2007, 06:15 PM   #15
Car: 06' Evo 9 SE 360 whp
Fav Mod: booost
^^i second that
NoTn41 is offline   Reply With Quote
