Go Back   IWSTI.com: Subaru STI Forums > Owners' Lounge > News & Rumors
Old 07-21-2003, 05:39 AM   #16
hatin' ovals
Car: 04 subaru wrx sti
Send a message via AIM to 4MLA1FN
rookie question: how do you make big torque; i.e. how would you change our engine to make that kinda torque? change the bore&stroke? those car are "only" 2.0l. amazing machines.
4MLA1FN is offline   Reply With Quote
Old 07-21-2003, 06:23 AM   #17
Fav Mod: Subaru "Full of PooPoo" Salesdork
Yeah. They go no-holds on the WRC. They build the STi for us to hold up to the warranty and to mass-produce. They only make 40 or so per year of the WRC cars. Not concerned about how much CRAZY hp/tq #'s.
murley is offline   Reply With Quote
Old 07-21-2003, 06:42 AM   #18
Default Blue w/Gold WRX STI Available in Grand Rapids, MI
Well, they do it with an engine that can last (barely) one race and doesn't need to meet the emissions or noise regulations that we have to meet. Although, fun enough, the WRC cars are actually registered for road use in Europe (they drive on normal roads in between stages).
Several million dollars in R&D does wonders for your torque output.
RDiamond is offline   Reply With Quote
Old 07-21-2003, 06:51 AM   #19
Originally Posted by esopher
Pardon my ignorance, but why would Subaru make a "limited-edition production version of the Impreza World Rally Car" and give it MORE hp than the real thing?
You do know that the reason the WRC engine is limited to 300 HP is that there are regulations? There is an air restrictor that limits the volume or air to the engine. If they were unrestriced you would see in excess of 500 HP. Go back to about 83 or so with the Group B cars to see what happens without restriction.
prost893 is offline   Reply With Quote
Old 07-21-2003, 01:01 PM   #20
retired mod
Car: 99 WRX STi V5
Fav Mod: JDM Air Freshener
Send a message via AIM to eatV8 Send a message via MSN to eatV8
has anyone got a pic of the wrc engine? i have one somewhere, it actually shows the restrictor cup mounted on top of the turbo. i will post it if i find it.
eatV8 is offline   Reply With Quote
Old 11-10-2003, 09:15 PM   #21
the hyundai accent wrc3 has 300 hp and 384 ft lb torque... manages a
0-60 of 3.9 seconds (according to rally xs magazine)
now, subaru wrc has 300 hp but 434 ft lb torque... that should mean a better 0-60 although i dont knwo what it is... anyone know?
bartolommeff is offline   Reply With Quote
Old 11-10-2003, 09:30 PM   #22
Subaru WRC2003 Engine photo[/img]
Old 12-15-2003, 10:54 PM   #23
Best Car mag (12/26 ed.) fm. JPN. and it mentions of the following keypoints.
- Launch date: probably April '04, that's 2mos. later than the
anticipated Mitsu Evo8.5 MR (Al. roof).
- Rear wing: similar in apperance to the actual Rally Car except they
reduced the FINS (wing splitter) fm. 4 -> 2.
(sori dnt have scanner).
- Power Ratings: Evo MR STi8 STi (WR look alike).
* ps/rpm: 280/6500 280 280/6000
kgm/rpm: 40.8/3600 40.2 41.0/4500
[achieved by revised ECU]
- Tire size up: still 17" though. 235/45 R17. with improved hub-carrier
strength / rigidity.
- Revised suspension tuning.
- Revised front bumper (downward extension) for better aerodynamics
- No mention of Roll Cage
- and lastly Subaru promises even better handling than the orig 22B.
Note: '*' power are seriously underrated. actual 300+
parakitoJDM is offline   Reply With Quote
Old 12-15-2003, 11:07 PM   #24
retired mod
Car: 99 WRX STi V5
Default ADVAN RC2s
In a magazine article I have here, it says how because this is a car "tuned" by STi they dont have to keep to the 206kw(280ps) agreement rating... All the companies that have tuning arms (NISMO, RALLIART, TRD etc) are exempt from this power cap now as they are "tuning companies" not the manufactuer. However, the article says that the car should share the S202's powerplant which was rated at 235kw(320ps)
Old 12-16-2003, 02:35 PM   #25
It's only 300hp because of race restrictions and the engine's lower-end tuning for ralley situations. 300 isn't a ludicrous number, and with the extra weight of the street car, why NOT make it more powerful than the WRC car?
b0rf is offline   Reply With Quote
Old 02-09-2004, 04:09 PM   #26
Car: 2005 STi
Fav Mod: Big Turbo
The WRC cars are HP restricted but they pump in the 500lb/ft range torquewise. How satisfying would that be in the showroom car...
Antimullet is offline   Reply With Quote
Old 02-10-2004, 04:09 PM   #27
also doesn't weigh what a street car weighs. HP/WT ratio
WRXSTIsales is offline   Reply With Quote
Old 02-10-2004, 04:10 PM   #28
and 500ft/lbs would make brick fly.
Old 02-10-2004, 04:28 PM   #29
Car: 2005 STi
Fav Mod: Big Turbo
So,
Lets get technical, how the heck do they get that awesome amount of torue, then restrict the horsepower back down to the 300hp limit?
Is it like restricter plates in nascar? If so, how do they manage the gobs of torque while removing the hp?
Old 02-10-2004, 05:40 PM   #30
Rev
STI Guru
Car: 06 V70R
Send a message via AIM to Rev
I know they do have turbo inlet restrictors... maybe they have a special wastegate or something ...
