Go Back   IWSTI.com: Subaru STI Forums > Owners' Lounge > News & Rumors
Old 06-17-2008, 06:28 AM   #1
Car: black 06 sti
Fav Mod: Turbo back
Default Interesting news about oil changes
Check this link is interesting.
The-3-000-Mile-Oil-Change-Myth- Yahoo! Autos Article Page--
sti777 is offline   Reply With Quote
Old 06-17-2008, 06:39 AM   #2
Car: UGM 2007 STi Limit
Fav Mod: Accessport
Default Re: Interesting news about oil changes
Interesting read, but not much we can do while under warranty. I think Subaru expects you to change your oil every 3,750 miles.
A turbocharged car is tough on oil, but modern synthetics are pretty good. We could probably go longer, but the cost of an individual oil change is low relative to a possible blown motor. BMW has very long service intervals, even in the new turbocharged motors.
I like this statement:
Oil doesn’t wear out
True to some extent, but the additives that give the oil its desirable properties do wear out over time.
I read an article once where the author had his oil analyzed at 3000 mile intervals and basically never changed it. However, his motor burned a quart or so every 3k (basically the motor changed the oil for you) and the additives in the new oil kept the old oil in decent shape. Not like I would try this approach in my car, but interesting nevertheless.
mckman is offline   Reply With Quote
Old 06-17-2008, 06:42 AM   #3
Car: 05 Subaru WRX STi
Fav Mod: EVO Recaro Seats
Send a message via AIM to IUSTi
this was posted just 21 mins prior to your post
The 3,000 mile oil change "myth"
IUSTi is offline   Reply With Quote
Old 06-17-2008, 07:39 AM   #4
Banned
Car: Blu Pearl 07 STi
Fav Mod: SPT Exhaust System
Thats just out right stupidity to run your oil over 3K. I have always changed my oil at 2500 miles with royal purple and a K&N oil filter, in all my vehicles. Oil changes are cheap insurance.
wrb07sti is offline   Reply With Quote
Old 06-22-2008, 02:19 PM   #5
Car: 07 STI LTD SWP
Fav Mod: Tuning by Jorge!
BMW has long oil change intervals for marketing reasons. The new turbo BMW and Mini engines eat oil at about 1 qt for every 2000 miles. If you never check it, by the time you are due for an oil change, there will be no oil in the engine.
Capn How is offline   Reply With Quote
Old 07-18-2008, 10:03 AM   #6
Car: WRC Blue 2005 STi
Problem with synthetic is Subaru doesn't want people using it. I've heard it's because it "doesn't break down right," problem is they don't say how. I just put Royal Purple in a couple of days ago, synthetic worked fine for my other cars. I'd still rather change the oil a bit more often if it meant that my engine didn't go boom.
davidmount is offline   Reply With Quote
Old 07-18-2008, 10:07 AM   #7
Car: obp 07 sti
Fav Mod: spt intake and exhaust for now
+1 on that
bcfsc is offline   Reply With Quote
Old 07-22-2008, 04:15 PM   #8
Originally Posted by bcfsc View Post
+1 on that
Realistically, if you run 100% synthetic, you could get your oil filtered (high pressure osmosis, etc) and reuse it forever. And it might come to this as the world becomes more "Green".
Thats not saying additives can't be added back in, but you get the point.
-Garrett
Garrett is offline   Reply With Quote
Old 07-22-2008, 04:20 PM   #9
Trader Rating: (14)
I change my oil when ever it gets dark brown and smells like crap. I attend quite a few track days, and drive my car the way its supposed to be drivin. So I'm changing my oil about every 1,300-1,850mi. I figure for like 40 bucks, why not. Plus my fumoto vlave makes things quite a bit quicker and cleaner
Old 07-22-2008, 04:25 PM   #10
STI Guru
Fav Mod: Whooshing sounds
If you look at the owner's manual, you'll see that Subaru says that you can use synthetic oil as long as you adhere to the proper oil change intervals and the correct viscosity.
Peleg is online now   Reply With Quote
Old 07-22-2008, 04:29 PM   #11
Car: blue 05 wrx sti
a buddy of mine used to work on some industrial gas and diesel engines that ran a steady rpm 24/7 they would never change oil just filters and top off oil took samples and when a sample returned critical oil was changed
mcbst is offline   Reply With Quote
Old 07-22-2008, 04:40 PM   #12
abracious
Fav Mod: Track time
Now THAT's probably overkill.
Why not send your oil to Blackstone and see what is actually going on? They'll tell you how long to safely run your oil.
Old 07-22-2008, 04:55 PM   #13
Car: White 08 STI
Fav Mod: Stage 1
I have gone really long time in some of my other vehicles between oil changes.
In fact in my vibe i went at least 20k one time hell not sure it wasn't more like 25kish. I put on roughly 94k miles in 2 years on it. Traded it in on a rsx.
In my last car which was a type s rsx i changed the oil about every 10k miles. I was pretty good about it too. Never went much over that. Put about 104kish in 3 years 2 months.
This one i plan to change it as called for in the book. For at least the first year then i'll go from their.
Man its just hard to have to change the oil that much on a modren car!!!
Elkwood is offline   Reply With Quote
Old 07-25-2008, 09:14 AM   #14
Modern day industrial compressors are another good example. At a previous employer I had to setup maintenance intervals on two 100hp Ingersoll Rand compressors. They used a synthetic oil that cost $125 / gallon and each required ~7-8 gallons. We monitored it with samples sent out for testing and once it reached a certain level changed it out. Those things ran 24/7 in a production environment and we rarely changed the oil out but maybe once every year.
shiplemw is online now   Reply With Quote
