Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Private For Sale Classifieds > Misc. Accessories & Non-Automotive Stuff
Old 11-15-2007, 04:39 AM   #1
I Has a Turbo Timer
Fav Mod: Every single one!
Trader Rating: (27)
Default Parkzone FW-190 Ready To Fly RC Airplane with Extras!!
Brand New In Box PLUS EXTRAS!!!
$230 plus shipping
Sold at Hobby Shops for $180 + tax + The Extras = MORE than asking price
Dubbed the “Butcher Bird,” the Focke-Wulf 190 was the Luftwaffe’s most potent piston-engine fighter of WWII. Experience the thrill of flying this warbird legend on a smaller scale with ParkZone's aerobatic RTF reproduction.
Overview:
Getting it airborne is about as simple as it gets. Just attach the wing and tail, connect the battery to the charger and in as little as 40 minutes, you’re flying. Prolific park flying fans will also be pleased to know that the receiver/ESC module and two servos can be removed and used in other speed 370 or 400-class electric aircraft. That includes V-tails and delta wings, thanks to selectable control mixing in the receiver. You can also adjust the speed control’s auto-cutoff to work with 3-cell Li-Po packs. And, with minor modification, you can set it up for exciting aerial combat using the X-Port™ adapter that’s included.
Charge-and-Fly convenience, outstanding flight performance and exciting scale realism—with the ParkZone Focke-Wulf 190, you get it all.
The ParkZone Promise:
ParkZone Charge-and-Fly aircraft are for experienced RC pilots who want a high-performance park flyer without the hassle of having to build one. You get everything you need to go from box to sky in as little time as it takes to charge a battery pack. No gluing. No painting. No radio installation. No hassles. Just fly.
Specs:
Wing Span: 39.5"/1000mm
Overall Length: 33.5"/850mm
Flying Weight: 28 oz./790 g
Motor Size: 480 Power with gear reduction
Radio: 3 channel FM proportional (27MHz)
Servos: 2 PKZ 5 wire
Trim Scheme Colors: light gray, dark gray, red, black, white, and yellow
CG (center of gravity): approximately 5 3/4" (146mm) forward from trailing edge
Prop Size: 10 x 8
Aileron: proportional
Elevator: proportional
Rudder: no
Throttle: proportional
Approx. Flying Duration: 10-12 minutes with stock Ni-MH, 15-20 minutes with optional 3S 2200mAh LiPO pack
Gear Ratio: 3:1
Transmitter Range: 2500 ft
Available Frequencies: 6 channels on 27 MHz
X-Port: Equipped with X-Port, but no external port
Charger: 1.2 Amp 5-10 cell Variable Rate DC Peak Charger
Landing Gear: none
PLUS EXTRAS!!! LOOK!!!!
With this purchase of this great R/C warbird, you get:
-3 EXTRA 9-Cell 10.8V 1000mAh Ni-MH Battery Packs. That means you get a total of 4 Battery packs which lets you fly for 3 times longer than if you just had one!
-2 EXTRA 1.8A variable rate DC Peak Charger. That means you get a total of 3 battery chargers, since one is included in the kit. You can get the wall charger adaptor from your local hobby store to be able to charge at home well!
-2 EXTRA Propellers. That means you get a total of 3 Propellers, since 1 extra (one on plane, one as extra) is included in the kit.
-2 EXTRA Li-Po Battery Connectors
-2 EXTRA X-Port Extensions.
-1 EXTRA Screwdriver.
-2 EXTRA CG weighted prop nut.
TOTAL WORTH OF EXTRAS: $135.00!!!!!!!!!!!!!!!!
Needed to Complete:
You won't need anything else to get your ParkZone Focke-Wulf 190 up in the air. Because it's a ready-to-fly, everything required to head to the skies is included in the box. A one box purchase means - No gluing. No painting. No radio installation. No hassles. JUST FLY! That's the beauty of ParkZone. Any problems, ParkZone has great customer service and warranty. They will work with you to get any problems sorted out fast and painless!
This whole package is all packed up and ready for shipping!!!!
This is what comes with the kit:
These are all the extras you get on top of that!
Old 11-17-2007, 04:05 PM   #2
I Has a Turbo Timer
Trader Rating: (27)
Default Re: Parkzone FW-190 Ready To Fly RC Airplane with Extras!!
Bump!
Old 11-18-2007, 02:11 PM   #3
I Has a Turbo Timer
Trader Rating: (27)
Bump.....
Old 11-26-2007, 04:33 AM   #4
I Has a Turbo Timer
Trader Rating: (27)
Bumps
HTML code is On
