Go Back   IWSTI.com: Subaru WRX STI Forums > Regional Forums > United States > Mid Atlantic
Old 07-04-2008, 10:47 AM   #1
IWSTI Addict since: Apr 2007
Default MD Inspection
Hey All,
Looking to find the exact guidelines for passing inspection in Maryland. I live right near VA, So I would hate to buy a car with an exhaust system that won't pass.
weil186 is offline   Reply With Quote
Old 07-04-2008, 10:48 AM   #2
Friendly Lurker
Car: 08 STI
Fav Mod: RCE Camber Plates
IWSTI Addict since: Mar 2008
Default Re: MD Inspection
Originally Posted by weil186 View Post
Hey All,
I think MD has a inspection checklist on the DMV site somewhere.
Old 07-04-2008, 11:10 AM   #3
Thanks. I took a look at the website and it is pretty vague with the check list. It just says it inspects exhaust and emmissions equipment. The car I'm looking at only has 1 high flowing cat and I know stock it comes with 2. This is where my concern is.
Old 07-04-2008, 11:21 AM   #4
Friendly Lurker
Car: 08 STI
Oh...MD has 2 inspections...the first is just safety so the exhaust shouldn't be a problem and the second is emissions and they just read your OBDII port. So as long as it still has both O2 sensors I think you should be fine. I recommend just calling a place that does inspections and asking them.
*This is not advice*
Old 07-04-2008, 11:25 AM   #5
The emissions test happens usually with in 2 years of owning the car, and as long as no CELS are on and it passes the smog hook up your good to go.
I thought when they 1st inspect it, before you can get tags and registration, they will check to see if the exhaust meets the specs.
Thanks for the input so far. I might try to call a dealership I used to work at.
Old 07-06-2008, 06:36 PM   #6
Car: 2005 Aspen White STI
Fav Mod: Buying it
IWSTI Addict since: Jun 2008
Go to the local tuner shop and ask them which shop to go to. I would not take it to a dealer. The local shop would be more liberal with the inspections.
Thisguy is offline   Reply With Quote
