Go Back   IWSTI.com: Subaru STI Forums > STi Owners' Lounge > Members' Journals
Old 05-01-2008, 10:47 PM   #346
Fav Mod: My name is Roy!
Send a message via AIM to Seventy STi
Default Re: Seventy's 07 STi - Advan RS Gold 18x10 +35 265s Is on! Check them out.
Originally Posted by subwrxkid View Post
I love it, I think I already said it on nasioc.
What's the section width on the 265? Tread width? I saw you replied about the camber, is there any chance you can find out how much front and rear? And was it neccessary to modify the camber plates on the coilovers to fit?
I know, so many questions. I want 18x10's now, but I think I may just stay with my 9.5's and make the car as low as possible with front having a lower offset than the rear. lol
No you didnt! haha now you did hehe.
Well the thing is I'm not sure where to measure it from for the tread width. The section width is 10.7 just like most of the 265s. So if you going to use Re01r im sure it will be fine. I will find out the camber when I do the alignment.
Well the thing about the stance camber plate is they add a little metal ring with the bolt thats why is blocking me to get them both close together. So as long as you take that ring out you are fine or just change to some different bolt to lock it. You can see it few post up.
9.5 is good. get lower offset like +22.. heheeheeeee
Oh btw if you didnt fit your 9.5 yet. Nojeebs 9.5 have to pull the rear fender and his fender edge are all cut but still rub with out pulling. He only pulled a little tho compare to mine.
Seventy STi is offline   Reply With Quote
Old 05-01-2008, 11:04 PM   #347
Holly siht you have Soooo much camber in the front! Can I borrow some?..And do you have like a sharpie line on yr rear fender where you pulled them, or is that just a shadow?
Old 05-02-2008, 03:50 AM   #348
Orwell was an optimist.
Fav Mod: Track time
How does the car drive when slammed like that?
Old 05-02-2008, 06:22 AM   #349
Car: 06' CGM STI
Fav Mod: Rustoleum Flat Black
Dayum! Nazioc would ban you! Almost as low as my Neon was...
Car is looking sick dude. Oh, and guess who fixed that piece you sent him? It came out great! Pics to follow my friend.
-G
grambo is offline   Reply With Quote
Old 05-02-2008, 06:25 AM   #350
Car: 06' CGM STI
Originally Posted by Seventy STi View Post
Thanks for the support.
When I first ordered the rim. Teh Clap was setting up bill using a 9" wheels with 235/40 tires and you can see it on his blog telling people how to do it. I step it up(so does many more ppl using 9.5 and such) and use 1" more on the wheel and I'm able to 3 sizes up the tires and my car is as low as most of the car. That was my goal to use as wide as possible on the rims and the tires on the stock body. Also lower the car as much as possible. Thats what so call aggressive fitments. Also I used +35 because I want less poke also but thats all the tires I can fit.
I also step up on what you other people want for the 17s with big bad wide tires also. I know how to do both but just not doing on the same car.
Starting to look like my garage...
Old 05-02-2008, 07:06 AM   #351
Car: 03 WRX
whats the name of the tires? I can look it up online.
I think I want a 255/35 summer tire, or maybe a less wide 265/35. I just want the car to be slammed. haha
So they took your rear flares off and pulled the fenders, then put the flares back on? I hate those rear flares on a bugeye, or else I would have gotten them, it looks 10x better on 04-07 stis for some reason. haha
I think I might just pull the rear a lil anyways.
subwrxkid is offline   Reply With Quote
Old 05-02-2008, 08:55 PM   #352
Nexen N3000 they dont show the tread width. I dont think you should put it too cause ppl will hate on you cause you using cheap tires this and that. I dont care cause I saved 600 bucks.
I did a basic alignment today. I told him not to adjust any thing for me because I want to see what the current camber are on the picture. The number are
3.1 Front (KW/w Cusco camber plate maxed to negative)
2.2 Rear (Stance /Stance plate maxed to negative and camber bolt maxed to full positive)
0 Toe
I will go back once my mount from stance are here so I can swap the front.
Old 05-02-2008, 09:05 PM   #353
The car looks real good, props for doing something fresh.
(Oh, I PM'd you too)
Spoolin415 is offline   Reply With Quote
Old 05-03-2008, 04:05 AM   #354
Fav Mod: Spankings....
that looks pretty sick.. I dont know if my eyes are playing tricks on me but the pic on your first post of the extreme close up of the rim and tire looks like the tire is on the wrong side, because it looks like it has the rotation arrow pointing backwards... looks killer either way though..Nice work
Old 05-03-2008, 07:39 AM   #355
Car: 07 wrx
Fav Mod: CG Lock!
Send a message via AIM to beevnessmonster
could you tell me the exact paint you used on your head lights they look sick.
beevnessmonster is offline   Reply With Quote
Old 05-03-2008, 11:23 AM   #356
HowTo Contributor
Fav Mod: Cobb Stg 2 - Wrapped DP
lol yeah, he already caught that and a few people already poked and prodded him for it, i think he said he already fixed it
Old 05-03-2008, 04:35 PM   #357
Dupli-color textured metallic coating
Got them of Kragen autopart.
Old 05-03-2008, 04:37 PM   #358
Yaya, fixed it long ago.. too bad huh that was a bad ass picture. I will take another picture just like that when I clean my car and nut lugs are here.
Thanks for pointing that out haha..
Old 05-03-2008, 04:57 PM   #359
Car: 03 WRX
stance coilovers maxed out at 2.2? How? I've seen kids get -2.6 with just camber bolts.
Old 05-03-2008, 04:59 PM   #360
need to use the camber bolt push back out to postive to clear the 18x10 +35 from hitting the strut.
So with out camber bolt it will hit the strut on +35. So +29 you wront hit it but than you just pull fender more. I guess... or maybe u can add a spacer haha...
