View Poll Results: Caliper Decal Color
Battleship Grey 3 13.04%
Black 3 13.04%
Brushed Aluminum 12 52.17%
Cherry Blossom 5 21.74%
Voters: 23. You may not vote on this poll
Old 01-26-2008, 11:54 AM   #46
Car: blue 05 WRX STi
Default Re: (My 2005) 1/24 - Brembo Refinishing Progress Pics (VHT Bright Blue)
you should def do a how to on this. i want to do that to mine someday. but dont exactly know how...so a how to im sure would be great for evryone.
Calikid is offline   Reply With Quote
Old 01-27-2008, 07:55 AM   #47
Fav Mod: Do Luck CF
Very nice, a how to would be excellent!
Old 01-27-2008, 07:59 AM   #48
Send a message via AIM to nice-rice
That paint looks good, should look really nice on a wrb car.
nice-rice is offline   Reply With Quote
Old 01-27-2008, 12:33 PM   #49
Welcome to The Board
Car: 06 WRB STI
Fav Mod: Advan RS
Send a message via ICQ to Ikon Send a message via AIM to Ikon Send a message via Yahoo to Ikon
calipiers looks good
Old 01-27-2008, 12:42 PM   #50
wow, excellent job on the painting.
How many coats did you do and what technique did you use?
illt3ck is offline   Reply With Quote
Old 01-27-2008, 01:06 PM   #51
Fav Mod: sz55 external wastegate
Thanks for the compliments guys : ) For the technique I used : After stripping and cleaning the hell out of them I masked off the cylinder bores and primed the insides with a high heat primer using 3 coats. Then let them sit over night and painted the insides using 3 coats with 20 min of flashtime in between, at a room temperature of 75*F. I let them cure over night and then baked them in the oven for an hour at 200*F. After they cooled I installed new seals lubed with brakefluid and installed the dustboots onto the pistons one at time using brake lube in the recess of the piston and bore. I returned all the pistons to there bores after lubing them with some brakefluid and then masked off the insides of the calipers and proceeded to bolt the 2 halfs back together using anti sieze on the bolts. I then primed the entire outer surface and painted it using the same technique as the inside. Thats pretty much it, I'll post a how to once I finish the other caliper and have some more pics of the process.
Mycues1982 is offline   Reply With Quote
Old 01-27-2008, 05:52 PM   #52
Fav Mod: GST Protune, less boost more power
Send a message via AIM to MorePSiTehBett4
im excited to see how the car will look!
MorePSiTehBett4 is offline   Reply With Quote
Old 01-28-2008, 06:07 AM   #53
Car: jdm sti 2004
i guess you'll do your back calipers too right???
those look very nice mate!
just a question, do you have a link to the company that makes high temp vinyl?? are you gona put a clear coat on the decal???
Japan STI is offline   Reply With Quote
Old 01-28-2008, 08:46 AM   #54
you can actually just put a sticker on there...it won't melt off or anything
glilly on nasioc sells them, i don't know if he's a vendor on here...but that could save you some time mcues1982
Old 02-29-2008, 04:41 AM   #55
Yea I got them from xenonmods.com, hes a cool guy and easy to deal with. Yea I plan on spraying a High temp clear coat over them afterwards.
Old 02-29-2008, 04:46 AM   #56
I'm gonna finish my front calipers up this weekend and wanted to ask you guys what decal color I should go with, I was going to do black but it looks to dark against the blue so I'm leaning towards gray.
Old 03-02-2008, 06:49 AM   #57
Default Re: (My 2005) 1/24 - Brembo Refinishing Progress Pics, Vote on a decal color Please
need some more votes, cmon guys
Old 03-02-2008, 06:51 AM   #58
STI Guru
Fav Mod: grip.
voted for brushed aluminum
Old 03-02-2008, 06:58 AM   #59
Thanks for the vote, its hard to tell from the pic I already posted but the brushed aluminum has somewhat of a reflection to it. It might be abit to flashy for my taste but idk it might look really cool on the road. Heres another pic.
Old 03-02-2008, 06:59 AM   #60
STI Guru
Fav Mod: grip.
the white might also look good.
