Go Back   IWSTI.com: Subaru STI Forums > STi Owners' Lounge > Members' Journals
Old 09-05-2007, 07:06 AM   #166
Wheel33tist Whore
Default Re: Chaos's 05 STi: Garage Organization is FTW.
you do know that alcohol has a lower latent heat capacity then water and therefore is less efficient at removing heat.....
EDIT: forgot one of those guys.
Old 09-05-2007, 07:17 AM   #167
oMgWTFpewpew
Fav Mod: grip.
Send a message via AIM to chaos311clarity
well in the trunk its not going to evaporate much if at all... plus the near instant evaporation helps with heat dissipation on the intercooler IIRC.
Old 09-05-2007, 07:21 AM   #168
Wheel33tist Whore
it's good to keep the water from freezing.
but it is dissipates less heat then if you were using straight water.
Old 09-05-2007, 07:22 AM   #169
Indiatr0n in yo IWDPL
Fav Mod: Brum Brum
2007 Postwhore King
He's saying the alcy can "hold" less heat than water, so when it evaporates, it is actually cooling less...
Old 09-05-2007, 07:26 AM   #170
oMgWTFpewpew
Fav Mod: grip.
hmmm well the water alky mix is ok then in my book... all year round... regardless of evaporation ... cause its gonna start getting cold here.. FAST.
Old 09-05-2007, 09:01 AM   #171
Car: JBP 04 WRX STi
Very nice and clean car, cool garage and house! Very jealous, you seem pretty young to have such a nice car and a nice house and location.
drfrink24 is offline   Reply With Quote
Old 09-05-2007, 09:52 AM   #172
oMgWTFpewpew
Fav Mod: grip.
haha its not my house... or garage... but i do live there...
thanks for the compliments!
Old 09-05-2007, 01:54 PM   #173
oMgWTFpewpew
Fav Mod: grip.
ok so i just got back in from checking the speakers.. they appear to be stock contrary to how they sound lol...
anyway heres a little walkthru on how to pull them off.. there are slight variations because i only did one but its pretty much the same all around
ok so heres the door panel normally:
there are 2 screws covered with small black covers
and
you can pop those out easily with a flathead
then unscrew the phillips
you are then ready to pull things apart.... pull up on the button panel and itll just pop out... and then pull out on trim ring around the tweeter...it will also pop out... you then want to work ur hand in somewhere on the edge of the door... i usually start on the bottom... and then start pulling out on the door... the clips will pop and you will be ready to lift the door off the top edge...
you then need to take out whatever clips are attached to the panel... they can be a PITA
set the panel aside and check out the door, some clips may hae popped out of the panel.. just work them out of the door and then slide them back into the panel.
to get them back on, reverse this process... i did this, but ran into an issue... the cup behind the door handle had popped out of the door, there are 3 clips on the back of it that slide into the door... i found this out because i had everything back together and the tweeter trim peice wouldnt sit flush...anyway from pounding on it i bent the metal slightly ... so i took a set of plyers and bent it back... and then it slid right into place.. and everything was cool...
heres the clips..
and here was the result of this.... what appear to be stock speakers..
Old 09-05-2007, 01:58 PM   #174
Fav Mod: Brum Brum
2007 Postwhore King
Hmm, so you pulled your door skins off to check if your speakers are stock?
Old 09-05-2007, 02:01 PM   #175
oMgWTFpewpew
Fav Mod: grip.
yea pretty much, i bought the car used with some goodies on it.. ie the genome, tint, flaps, and sti clutch line... and i had always thought the speakers were pretty damn good... and others chimed in and said they didnt sound like they were stock... so i checked. ... and they are lol
Old 09-05-2007, 02:03 PM   #176
Fav Mod: Brum Brum
2007 Postwhore King
Well everything is better on/in the 05FTW
Old 09-05-2007, 02:04 PM   #177
oMgWTFpewpew
Fav Mod: grip.
ftw.
i think its just the "premium" speaker option.
Old 09-05-2007, 02:04 PM   #178
oMgWTFpewpew
Fav Mod: grip.
btw it looks like the retail on ur car went up a bit lolz
Old 09-05-2007, 02:06 PM   #179
Fav Mod: Brum Brum
2007 Postwhore King
ftw.
I didn't know there was such a thing... I know there was the optional sub, but that's it.
I bought mine off the lot new.
Werd... STFU
Old 09-05-2007, 02:16 PM   #180
oMgWTFpewpew
Fav Mod: grip.
https://www.subarugenuineparts.com/i...hp?cPath=33_46
thats where im getting my info :shrug:
