Go Back   IWSTI.com: Subaru STI Forums > STi Owners' Lounge > Members' Journals
Old 03-27-2007, 10:05 AM   #1
Teh Other White Meat
Trader Rating: (21)
Default Snorky's 2005 OBP STi*Predator* New protune (#205)
32J GDFDYEH (Obsidian Black Pearl 2005 STi)
Birthdate: 01/2005
Purchased: 04/04/2005
Engine / Intake:
  • APS 70mm Intake
  • APS Turbo Inlet Pipe
  • STi 1.3 Bar Radiator Cap
  • Zero/Sports 71* Celsius Thermostat
  • GT Spec Gray Radiator Shroud
  • Prodrive Gold Oil Cap
  • Forge Compressor Anti-Surge Valve
  • Beatrush Pulley Cover
  • Carbing Dual Catch Cans
  • Fumoto Valve
Turbocharger & Induction:
  • Prodrive Boost Solenoid
  • Ported and Polished Intercooler Y Pipe
  • Ported and Polished Throttle Body w/ Knife Edged Throttle Plate (Done correctly. Idles buttery smooth.)
Exhaust:
  • APS R1 3" Turbo Back Exhaust with Ported Turbo Outlet Housing
  • SPT Heat Shield
  • High Temperature Silicone Coated, Hacked Stock Heat Shield
  • DEI Thermal Wrapped and High Temperature Silicone Coated Downpipe
ECU Tuning / Fuel:
  • Cobb AcessPort v.2 Stage 2 (protuned)
  • Walbro 255 LPH Fuel Pump
  • Deatschwerks 740cc Injectors
Drivetrain:
  • Cusco Engine and Trans Mounts
  • Beatrush Propeller Shaft Mounts
  • Kartboy Short Shifter
  • TiC Pivot Bushings
  • TiC Shift Linkage Bushings
  • Kartboy Rear Shifter Stay
  • Beatrush Front Shifter Bushing
  • Kartboy Pitch Mount
  • Snorky's Comfy, Bony Rear End Kit (see post #55)
  • Whiteline Steering Rack Bushings
  • TiC Transmission Cross Member Bushings
  • STi Stainless Steel Clutch Line
  • Motul 90PA LSD Fluid
  • Motul Gear 300 75w90 Transmission Fluid
  • Motul Dexron III Synthetic in Power Steering System
Suspension:
  • Stock Springs
  • Stock Struts Properly Repacked with Valvoline Syn Power Synthetic Grease
  • Whiteline 27mm Adjustable Front Swaybar
  • Whiteline 24mm Adjustable Rear Swaybar
  • Whiteline Front and Rear Adjustable Endlinks
  • Whiteline Heavy Duty Rear Sway Bar Brackets
  • Whiteline Roll Center Adjuster Kit
  • Whiteline Race Anti-Lift Kit
  • Whiteline Subframe Lock Bolts
  • Whiteline Max-C Race Front Camber/Caster Plates
  • Group N Rear Strut Mounts
  • Group N Front Trailing Arm Bushings
  • Group N Rear Trailing Arm Bushings
  • Group N Front Inner Lateral Link Bushings
  • Group N Rear Inner Lateral Link Bushings
  • Group N Outer Lateral Link Bushings
  • TiC Giuyngmyo Fender Cowl Braces
  • Carbing Front Strut Bar with Brake Master Cylinder Brace
  • Cusco Rear Strut Brace
Brakes:
  • Ferodo DS2500 Pads
  • Carbotech XP12-front XP10-rear Pads for Track
  • Stoptech SS Brake Lines
  • Motul RBF 600
Wheels & Tires:
  • Solar Black Flat Stock BBSs for Track and AutoX
  • Mcgard Spline Drive Black Lugs
  • Prodrive Valve Stem Caps
  • ADVAN RGIIs 18x8.5 in Gold
  • Falken RT-615 235/40R18
  • KICS Project R26 NEO Chrono Lug Nuts
Interior:
  • S204 Interior
  • Spec C Type RA-R Duracon Shift Knob
  • Legacy Black DIN Pocket with Covert Defi Control Module and iPod Hookup
  • Scroth Quickfit Rallye 4 asm Harness w/Pads
  • Valentine 1 Hardwired
  • Red Light Modded Interior (with LEDs. Custom by me.)
  • Defi Gauge Pod
  • Defi Link BF: Boost, EGT, Oil Temp, Oil Pressure
  • JDM Auto Intercooler Sprayer- Boost Activated
  • Autospeed Dead Pedal
  • RAM Mount Camera Mount
  • Redline Accessories Perforated Leather w/ Red Stitching Shift Boot, E-Brake Boot, and Armrest Cover
Exterior:
  • Lightwerkz Custom Retrofitted Headlights
  • JDM Rear Spats
  • Debadged Trunk
  • Hella Supertones 118db (Flat Blacked)
  • Ebay V-Limited Lip
  • Pink Pleiades Front Emblem
  • Black STi Front Bumper Trim
  • 15% Tints
  • SCCA Window Sticker
Weight reduction & transfer:
  • Deka ETX14 Battery
  • Freddie's Battery Mount
V-Limited Lip:
My Defi Gauge Setup with Control Module and iPod in Legacy DIN:
Most recent engine bay shot:
Old 03-27-2007, 10:10 AM   #2
I Has a Turbo Timer
Fav Mod: Every single one!
Trader Rating: (20)
Looking nice....any more mods on the way??!?
Who did the porting and the rest of the work on the Throttle Body?
Old 03-27-2007, 10:12 AM   #3
Trader Rating: (21)
It got lost in a mess of useless/misplaced posts so here is a link to my how to if anyone wants to read it, comment: Porting TB and IC Piping, and Coolant Bypass
Old 03-27-2007, 10:21 AM   #4
Car: 2007 STi OBP w/ Silv
Fav Mod: mudflaps
Send a message via AIM to rb_STI
why did u take vlimited spoiler off? u sellin??
rb_STI is offline   Reply With Quote
Old 03-27-2007, 10:27 AM   #5
Trader Rating: (21)
Thanks. I did the porting myself, see above post.
i've got the tgv deletes, APS hard inlet pipe, and Walbro fuel pump waiting and plan on purchasing a Prodrive boost solenoid, Deatschwerks 740cc injectors, and APS Equal Length Headers for an eventual 20G (this winter most likely).
Old 03-27-2007, 10:30 AM   #6
Car: 05 OBP/Gold STi
get tires! i want to see advans on OBP
habitat is offline   Reply With Quote
Old 03-27-2007, 10:30 AM   #7
Trader Rating: (21)
It was too close for comfort. I couldn't pull into my driveway for fear of scraping my brand new lip. I haven't decided if i'm going to sell it yet but it is in brand new condition. I'm going with RCE springs in a couple weeks. They supposedly aren't as low as the COBBs. we'll see...
Old 03-27-2007, 10:31 AM   #8
Send a message via AIM to straightouttajersey
if im not mistaken he couldn't get into his driveway with the combination of the lip and the springs.
Anyway, clean car man. Get those advans on and get some pics up!
straightouttajersey is offline   Reply With Quote
Old 03-27-2007, 10:52 AM   #9
Trader Rating: (21)
^^true. Straightouttajersey, great avatar, Bayside is one of my favorite bands. i've seen them twice in chicago.
Old 03-27-2007, 10:56 AM   #10
Trader Rating: (21)
Still waiting on my tax return for some tires. Some pics of my RGIIs and Kics Project Lug Nuts. I am still up in the air on the NEO CHRONO Lug nuts. A little too JDM bling maybe, not sure. Some days i love them some days they look meh. For what i paid, i should love them all the time! Let me know what you think.
Old 03-27-2007, 10:59 AM   #11
don't even get me started on bayside....I have an unhealthy obsession with their music...saw them a few days after The Walking Wounded was released, they played a release show in Long Island....best Bayside show I've ever seen, and I've seen them far too many times to count...always put on a great live show though. Glad to see a fellow bayside fan and STi owner!
Old 03-27-2007, 11:03 AM   #12
Car: 05 Aspen White/Gold
Fav Mod: Öhlins FP
Props to some nice wheels. I wish I could afford Project Kics lug nuts for my wheels, but the wifey wont have any of that.
Bayside rocks! I went to a Aiden/HH/Silverstein concert two years ago and Bayside had that horrible accident. They weren't able to make it because of that accident but the other bands kept on in their tribute.
alphaSTI is offline   Reply With Quote
Old 03-27-2007, 11:11 AM   #13
Trader Rating: (21)
thanks man.
When john died?
Old 03-27-2007, 11:14 AM   #14
Trader Rating: (21)
as do i. but i didn't want to come off like a nerd.
i'm pretty sure i was at the concert where they played don't call me peanut for their live cd. atleast i tell myself to make myself feel cool.
Old 03-27-2007, 11:28 AM   #15
Trader Rating: (21)
A couple pics of the TGV Deletes that i sent into Jesse at pnpheads(kinger). He did a great job on the porting and filling. plus he cleaned them up.
Before:
