| | Thread Tools |
| | #1291 |
| Spec C Club
Car: 07 STI LTD/08 STI Fav Mod: APS/Crawford/Cosworth/Aquamist Location: E-town, AB Posts: 2,380
IWSTI Addict since: Apr 2005 Trader Rating: (5) | Should be fine. I've read a bunch of posts on guys in -20*F weather turning over their built motors no problem - a lot of ugly piston slap, and ugly noises, but they were fine. That would suck like nothing else though. "How'd you blow your motor?" "Cold start in -40." This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #1292 |
| Wheel33tist Whore
Car: Aspen White GDF-D Fav Mod: Pastelito Racing / SFSOC Location: 0R!4ND0 Posts: 21,493
IWSTI Addict since: Dec 2004 Trader Rating: (7) | -40!? WTF. you actually try to go somewhere when it's that cold? most people down here don't leave their house if it's below 50. |
| | #1293 |
| Spec C Club
IWSTI Addict since: Apr 2005 Trader Rating: (5) | Another update: 1/29/07 1 - APS R1 (3" TBE) is coming off and the APS R5 (angled 3.5" TBE) is going on at time of install. 2 - STI heads/cams are coming off, Cosworth Big Valve Cylinder heads and S2 cams are going on. ![]() 3 - Based on my emails with one of APS' engineers, I'm going to stick with the so-called restrictive 0.82A/R turbine housing. I'll run a lower boost level (anything up to 24PSI keeps the turbine back pressure happy at ~4 PSI greater than boost pressure, whereas anything beyond 24PSI sees the back pressure start to skyrocket). The 1.06A/R housing would likely ruin the street driveability of my car due to lag, lack of low end response, and broken axles and driveshafts. ![]() 4 - I bought a Koyo Race Rad off eBay for way cheaper than anything I've seen posted here. Should see it in a week.5 - I installed the Innovate LC-1 wideband w/ the Autometer dual gauge cluster bezel (did I post this already? seems like I have). The other pod will house the Aquamist DDS3 gauge. 6 - It's likely I'll be using an Autronic SM4 standalone ECU with the wiring and cam sensor method in prototype phase. 7 - April is looking like a realistic tune/install time. edit: Forgot to add some stuff lol. Last edited by TheLimitedProject; 01-29-2008 at 02:29 PM. |
| | #1294 |
| Spec C Club
IWSTI Addict since: Apr 2005 Trader Rating: (5) | |
| | #1295 |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | |
| | #1296 |
| Silver Member
Car: 2006 OBP STi Fav Mod: Snow Location: Alberta Posts: 1,486
IWSTI Addict since: Sep 2006 Trader Rating: (7) | |
| | #1297 |
| Spec C Club
| | #1298 |
| Spec C Club
| | #1299 |
| Is Scared Of Kevin...
Car: 2007 WRX STI Limited Fav Mod: APS Catless R1 TurboBack Exhaust Posts: 3,031
IWSTI Addict since: Nov 2006 Trader Rating: (5) | matt I'm offically jealous of your R5!!!!!! |
| | #1300 |
| Spec C Club
IWSTI Addict since: Apr 2005 Trader Rating: (5) | Exhaust System Back Pressure (psi) at Nominated Engine Horsepower Level Noise as tested to J1169 225hp 325hp 425hp 525hp 625hp 725hp APSWRX-HOE/R1 without Cat 0.5 1.0 1.5 2.5 3.5 5.0 95 dB APSWRX-HOE/R5without Cat - - - 0.5 0.75 1.0 100 dB Might wake the neighbours, 6 floors up from an underground parkade. |
| | #1301 |
IWSTI Addict since: Nov 2006 Trader Rating: (5) | the funny thing is that in chicago, they couldn't give a **** about pulling you over for loud exhaust, they'll just pull you over for tinted windows..... |
| | #1302 |
IWSTI Addict since: Nov 2006 Trader Rating: (5) | i might actually do the same thing as you.......its not my top priority though |
| | #1303 |
| Spec C Club
IWSTI Addict since: Apr 2005 Trader Rating: (5) | ^I'm going to the R5 for functional purposes though, not for a bling angled cannister. The .82A/R turbine will cause a decent amount of backpressure, so going with practically a straight 3.5" exhaust should help reduce that a fair bit. The R1 is already loud enough... this is going to scream now, especially with the EWG dump lol. |
| | #1304 |
IWSTI Addict since: Nov 2006 Trader Rating: (5) | yeah i just love the sound of the r1 and i bet the r5 is even better |
| | #1305 |
| Spec C Club
Car: 04 Crawford STi Fav Mod: CP35r 440whp Posts: 2,052
IWSTI Addict since: Jun 2006 Trader Rating: (3) | The backpressure the .82 housing that you are concerned with is pre-turbine housing. Not post turbine housing. While this 3.5" exhaust may help a little, I honestly believe it's less than what they say. anything above 2psi is what is considered restrictive. We start replacing catalytic convertors on stock systems above 2psi and WOT. FWIW. This ad is not endorsed by this member. Please register or login to hide this ad. |
