Old 10-01-2006, 08:16 AM   #1
Default TLP - **The car is gone again... FINAL trip to Rocket Rally** Post 1839
FACTORY ORDERED
1) SPT Short Shift Kit
Removed - see Drivetrain mod list
2) OEM Sub/Amp upgrade (bad call, I know...)
3) Auto-Dimming mirror w/ Homelink upgrade
EXTERIOR
1) Autospeed "STI" anodized black front licence plate filler
2) CF licence plate frame
3) 5-window tint
4) V-Limited Replica Lip
REMOVED: RavSpec CF Lip
5) '04/05Tails
REMOVED: 07 Tailights; 06 Tailights
6) KS Tech Hood Scoop delete
REMOVED: SWP Paint matched ARC hood scoop
REMOVED: Kakumei CF Vortex Generator
7) RavSpec CF exhaust shield (06/07 specific)
INTERIOR
1) Pioneer Avic-Z1 Head unit
1b) iPod Adapter
REMOVED: Z1 Bluetooth Adapter (can't hear anything anyway )
2) Valentine 1 Radar Detector
3) LED Map and Dome lights
4) Autospeed Deadpedal
5) Fastcb modified HVAC, Cig lighter, Key ring, Window switches
6) Bride Ergo II driver seat in all black leather
7) Bride XAX II Passenger Seat in all black leather
REMOVED: OEM STI Limited heated seats
8) OEM shift knob
REMOVED:Spec C replica shift knob
SUSPENSION
1) Q-Rack quick steering rack: 11.5:1 ratio
2) Ohlins Flag Series Coilovers
3) Whiteline 27-29mm Adjustable FSB; Whiteline 24mm RSB
4) Cobb Endlinks
5) Group-A Subframe locking bolts
REMOVED: BC Racing Type BR Coilovers
REMOVED: Ohlins Fixed Perch Struts; RCE V2 Yellow springs; Whiteline camber plates; Group-N rear strup top mounts
WHEELS/TIRES
Winter:
1) Stock Enkei Wheels w/ Michelin Pilot Alpin 235/45/17Summer:
1) 18x8 BBS RE's, +51mm w/ Falken RT615 235/40/18
Track:
1) 18x8.5 Gram Light 57F's (powdercoated flat black), +45mm w/ Falken RT615 245/40/18 tires (soon to be upgraded to 235/40/18 R888's)
REMOVED: 18x8 Volk GT-V w/ Falken Azeni RT615's 235/40/18
DRIVETRAIN
1) ACPT CarbonFiber Driveshaft
2) Cobb dual-adjustable STI short shifter
3a) Kartboy Front shifter bushings
3b) Kartboy Rear shifter stay bushings
3c) Kartboy shifter pivot bushings
3d) Kartboy shifter linkage bushings
4) TiC Tranny Crossmember bushings
5) Group-A engine pitch stop mount
Complete set
6) Group-N "Performance" hardened engine mounts
7) Group-N "Performance" hardened transmission mounts
8 )Rocket Rally tuned Custom P-n-P DCCD controller *very cool*
BRAKING
BBK:
Front: Stoptech 335mm 6-Pot BBK
- SS lines
- 6-pot calipers
- Stoptech street pads
Rear: OEM STI Brembo 2-pots
REMOVED: OEM STI Limited black Brembo front calipers
PADS:
Street:
1) Front - Stoptech 6-pot street pads
2) Rear - Hawk HPS
Track:
1) Front - Hawk DTC70
2) Rear - Hawk DTC60
Fluid:
1) ATE Super Blue
Brake Lines:
Tecnafit stainless steel braided brake lines
ENGINE/EXHAUST/TURBO/FUEL/INTERCOOLER
Engine components:
Heads/Cams -
1) Cosworth Big Valve, ported performance cylinder heads
- CNC Ported - New OE Castings
- Hand blended finish work
- Intake: 14.63% Increased Flow (average)
- Exhaust: 30.56% Increased Flow (average)
- 4-angle Inlet Valve job
- 3-angle & radiused Exhaust Valve job
- Valves are lapped
- Back-Cut Inlet Valves
- Heads are Ultra Sonic cleaned prior to assembly
- Heads are Serialized and sport a machined Cosworth logo
- +1mm Stainless Steel Intake Valves (1800 degrees max.)
- +1mm Inconel Exhaust Valves (2400 degrees max.)
- Performance Valve Springs
- Titanium Retainers
- Hardened Steel Spring Platforms
Bottom end -
2) Crawford S3L-i
- New 2.5-Liter Semi-Closed Turbo Block
- New Subaru STI Forged Crank
- New STI High Performance High Mileage Piston Rings
- CP-Designed Forged and Strengthened Long Rods
- CP-Designed Forged Pistons
- CP-Designed Case Hardened and Heat Treated Wrist Pins
- Professionally Balanced and Assembled
Engine Management:
1) Autronic SM4
- SM4
- ETC
- Prototype DBW harness
2) Rocket Rally tune
REMOVED: '07 Cobb AP V2
Turbo:
1) APS TSR70 w/ 1.06A/R back housing (HPC 1600*F coating)
REMOVED: VF43
REMOVED: Element Tuning GT52
Exhaust:
1) APS R5 (3.5") TBE
2) APS Twinscroll Exhaust Manifold
3) APS Twsincroll Up-Pipe w/ Tial 44mm WG
REMOVED: Cobb catted TBE
REMOVED: APS R1 3" non-catted TBE
REMOVED: Perrin EL Headers w/ ceramic coating and heat wrap
Intake:
1) APS TSR70 specific 80mm CAI
REMOVED: APS 70mm CAI
REMOVED: APS 65mm CAI
Inlet:
REMOVED:APS 2.4" Turbo Inlet
REMOVED: Perrin 2.4" Turbo Inlet
Intercooler:
1) APS DR725 FMIC
REMOVED: WBR Black FMIC
Radiator:
1) Koyo Racing Radiator
2) Samco Radiator hoses (black)
Meth kit:
1) Aquamist HFS-5
REMOVED: Perrin PWI-1 Injection kit
BPV:
1) BOV block off plate (no BOV)
REMOVED: OEM BPV
REMOVED: Forge Diverter Valve
Fuel Management:
1) Deatschwerks/Denso 850cc injectors
2) Walbro Fuel Pump
Other:
1) Crawford A/O Separator
Gauges:
1) Defi BF Amber 60mm gauges
- Oil Pressure
- Boost
- EGT
2) Defi clock pod, paint and texture matched
3) Innovate LC-1 WB02 + DB Gauge (red)
4) Aquamist DDS3 Water injection gauge
REMOVED: Prosport 52mm "Premium" Gauges
MISCELLANEOUS
1) HJC Helmet
2) GrimmSpeed hood dampers
3) Custom made (by me) camera mount
The following quotes are from my original Journal posts - quoted for posterity:
Originally Posted by WhyteSTI, October 1, 2006
En route is a Satin White Pearl STI Limited. I officially haven't started my project since my car is still floating across the Pacific. But, that hasn't held me back from ordering all sorts of little goodies for it
One of my previous cars was a 2004 WRX STi. The extend of modding on that car was tint and GF210 lowering springs ( harsh harsh harsh). I intend to make up for that lack of modding with the Ltd.
I think I've finally found the perfect balance between semi-luxury and a raw driving experience in the STI Ltd. A sleeper is in the making...
Anyway, I figured I would start my journal now, while all my parts roll in. My plans are in no way as large as some of the amazing STI's guys have put together here, but I intend to put together a very capable streetable and auto-x'able STI.
Originally Posted by WhyteSTI, October '06
My mods point to this car being a beast low down in RPM range - I don't plan on needing huge amounts of Horsepower and Torque high in the RPM range (ie. Bigger Turbo upgrade) so I kept it down to the 575CFM EVOIII 16g. I considered the 18g @610CFM but the 16g was recommended as it'll supposedly make the same power but spool quicker = perfect
edit: Disregard the above bull isht After researching the different turbo setups, "lag" time for the 20g is still substantial power when comparing it to full boost on a 16g. 20g all the way... glad I made that decision. Coupled with a WBR Intercooler, high flowing fuel injectors and fuel pump, and a CAI, this bad boy is going to pullllll
I'm retardedly excited to start this project. I think my friends/fam/gf are ready to kill me... it's all I talk about
More pics to come as more parts roll in. And the car rolls in.
ETD for the car is 3rd week of October
Thanks for looking guys, and I'm always open to suggestions and help from experienced STI modders.
Matt
Old 10-01-2006, 08:21 AM   #2
Fav Mod: 05 Tails, Protune
Send a message via AIM to Pastapuck
Can't wait to see some pictures....haven't seen any of the white Limited.
Pastapuck is offline   Reply With Quote
Old 10-01-2006, 08:59 AM   #3
Car: 2006 WW Evolution IX
Fav Mod: Turbo > N/A
Send a message via AIM to Projekt_STI
Projekt_STI is offline   Reply With Quote
Old 10-01-2006, 09:42 AM   #4
Car: 05 WRB STi and 06 Spec B
Fav Mod: Seb's Stromung!
Can't wait to see the car, hope its in soon!
I'd like to see some dyno comparisons btwn. the 16g and 18g turbo's on an STi. I am having a very difficult time believing that they would make the same numbers up top and that the 18g wouldn't spool quick enough for you. Whatever turbo you decide on I look forward to seeing the results!
Edit: Great mod list btw.
EROCK11 is offline   Reply With Quote
Old 10-01-2006, 09:48 AM   #5
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
Nicccce!
Old 10-01-2006, 09:49 AM   #6
Car: 05 WRX STi Blue/gold
Fav Mod: my NawWS!
Send a message via AIM to NJSTi05
wow man, you really dont mess around w/ the mods.
that sounds like a freakin dream!! hahaha. good luck man! cant wait to see this!
also i must agree w/ you, the GF210's are pretty harsh.
NJSTi05 is offline   Reply With Quote
Old 10-01-2006, 09:50 AM   #7
Car: 06 Galaxy Gray RX-8
Send a message via AIM to scubynewbie
Wow...lucky, haha. Man, get some pics up as soon as it gets to yah. Good luck on your project!
scubynewbie is offline   Reply With Quote
Old 10-01-2006, 10:32 AM   #8
I agree 100% that there's no way a lower flowing turbo will produce the same top end as a smaller turbo with the same supporting mods. But, the vendors and tuners that I spoke to all recommended the EVOIII 16g over the 18g. Note though, that this is the EvoIII 16g. There's a small 16g, a big 16g (550 CFM) and then the Evo III (575CFM). They all noted that even though the flow is less, and that top end won't be quite the same, the peak power/torque achieved should be the same and the spool quicker.
I guess I won't know until I get it on the car, get some dyno results, and compare those to an 18g on the same dyno.
Ps. The Mustang dyno here is known for very low numbers. A protuned, Cobb Stg 2 '06 STI w/ K&N drop-in filter and lightweight pulley only made ~260 WHP. Stock for the same car was 220WHP.
Even though other protuned St 2 cars are making 300+WHP, it's no comparison.
Old 10-01-2006, 10:33 AM   #9
Thanks everyone else for the comments. I'm so excited to get this project underway... the days are being ticked off the calendar!
Ps. No GF210's for this car
Old 10-01-2006, 10:34 AM   #10
Friendlys Suby
Fav Mod: M&J Modified
very nice mod list
Old 10-01-2006, 10:37 AM   #11
^^ Thanks man... the Vent boost gauge is coming
Old 10-01-2006, 11:44 AM   #12
Welcome to The Board
Car: 06 WRB STI
Fav Mod: Advan RS
Send a message via ICQ to Ikon Send a message via AIM to Ikon Send a message via Yahoo to Ikon
damn alof of goodes
Old 10-01-2006, 12:02 PM   #13
Sold My Soul For Mods
Car: '05 CGM STi
Fav Mod: Track Time
Trader Rating: (12)
Sounds like a VERY tasteful mod list! I agree that you should consider a TD06H-18G. It should give you very similar spool to stock with a TMIC but make more power up top than a 16G. Either way, I can't wait to see pics! Do you plan on tracking it or is it mainly just a daily driver?
Old 10-01-2006, 12:31 PM   #14
^ Thanks a lot! I honestly can't wait to have a car in front of me to take pictures of!
It's going to primarily be a street set up, but I do have plans of hitting the track, drag strip (for fun...) and auto-x. I think the way I have things planned, my car is going to shine in auto-x and be just pretty decent on the track. I don't have a big enough turbo to make that crazy top end power.
But, in regards to the 16g vs 18g, I'm going to talk to FP tomorrow and get their take on it. My original inclination was to go with the 18g, but based on others' recommendations, I went with the big 16g. My biggest qualm about going bigger turbo was lag. I want full boost to come on early, not have a coffee break and then Mach 3
The 16g and 18g are the same price too... I'll have to speak to someone to get a better idea of where these turbos shine.
Old 10-01-2006, 01:15 PM   #15
Send a message via AIM to nice-rice
Congrats on the car, a great choice. Good luck with whichever route you decide to go with on the turbo.
nice-rice is offline   Reply With Quote
