Go Back   IWSTI.com: Subaru STI Forums > STi Owners' Lounge > Members' Journals
View Poll Results: What should i get next???
V-Limited Lip 21 28.77%
Cobb AP V2 52 71.23%
Voters: 73. You may not vote on this poll
Old 12-03-2006, 03:44 PM   #226
Car: 07 WRX STI Limited
Fav Mod: Bone stock....for now.
Where does the cone for the CAI go? Im guessing somewhere in the wheel well... Is it hard to get to to clean?
moe182 is offline   Reply With Quote
Old 12-03-2006, 06:33 PM   #227
I Has a Turbo Timer
Fav Mod: Every single one!
Trader Rating: (19)
Nice Reek.....wondering....does the intake squeak, cause it looks like there is some metal to metal contact. Also, you may wany to redirect the coolant lines under the intake, to take them away from the MAF Sensor.
Old 12-03-2006, 07:11 PM   #228
Car: 07 SWP Regular STi
Originally Posted by reeksti
protuned at xx......5th gears pull and made about 314whp and 362 trq
mods:
cobb stge2
Invidia g200+v2 catless dp
walbro 255
NGK one step colder SP
APS CAI 70mm
Those are some awesome numbers on the stock turbo!
STiJunki is offline   Reply With Quote
Old 12-03-2006, 08:22 PM   #229
Friendlys Suby
Fav Mod: M&J Modified
acutally the intake doesnt squeak, its doesnt move at all. i will move the lines underneath the intake
Old 12-03-2006, 08:24 PM   #230
Fav Mod: Twinscroll...Very Soon!
Send a message via AIM to Mac323
Reek, awsome numbers! I really cant wait to get my parts installed and get the car up to chris now!
Possibly said above, but how many pounds of boost is your car running?
Mac323 is offline   Reply With Quote
Old 12-03-2006, 08:36 PM   #231
Friendlys Suby
Old 12-03-2006, 10:12 PM   #232
Welcome to The Board
Car: 06 WRB STI
Fav Mod: Advan RS
Send a message via ICQ to Ikon Send a message via AIM to Ikon Send a message via Yahoo to Ikon
nice... i need a aps intake
Old 12-03-2006, 10:37 PM   #233
Car: 06 STi Aspen Wht/blk
Fav Mod: Meth
Nice #'s!!! Your car must pull really hard. Friday is my turn.
swiftwrx1 is offline   Reply With Quote
Old 12-04-2006, 06:29 AM   #234
I Has a Turbo Timer
Trader Rating: (19)
Looks pretty smooth Reek...congrats again. BTW, you can re-use that bracket holding the coolant lines......I did the same on Mark's. Just unscrew it off and reverse it to aim down, then undo on of the clamps to get the hoses to be under the intake, and just connect everything back up and pop the coolant lines back onto the bracket that should be facing down and your set.
Old 12-04-2006, 11:52 AM   #235
Friendlys Suby
ok thanks man, i will do it in a little bit.....
Old 12-05-2006, 07:23 PM   #236
Friendlys Suby
some new pads
Old 12-05-2006, 08:36 PM   #237
Fav Mod: Stereo
what made you choose those specific pads?
Otter is online now   Reply With Quote
Old 12-06-2006, 03:16 AM   #238
I Has a Turbo Timer
Trader Rating: (19)
Nice, may want to get SS Brake Lines and some good brake fluid like Motul RBF600 or ATE Blue....you will love how they feel. Just remember how to set the pads in when you first start driving them. Its something like go up to 15mph and hit the brakes to 5mph, then up to 30mph down to 5-10mph, and higher and higher.....this get the pads set in the caliper.
Old 12-06-2006, 06:30 AM   #239
Car: 06 Aspen White w. Go
Fav Mod: teH Muff
Yeah Hawk lists it on the inside of the box, the proper way to brake the pads in. If you aren't installing these yourself, I doubt the installer will do it for you so make sure the pads are properly broken in or you will get unecessary noise/wear.
uncle lewie is online now   Reply With Quote
Old 12-06-2006, 06:44 AM   #240
I Has a Turbo Timer
Trader Rating: (19)
Yup.....just as Jordan said....properly breaking in the pads is very important, you get the best results...otherwise you will get the annoying squeal/wear...I have none
