Go Back   IWSTI.com: Subaru STI Forums > STi Owners' Lounge > Members' Journals
View Poll Results: What should i get next???
V-Limited Lip 21 28.77%
Cobb AP V2 52 71.23%
Voters: 73. You may not vote on this poll
Old 11-20-2006, 12:34 PM   #166
Friendlys Suby
Fav Mod: M&J Modified
Originally Posted by sebtarta
thanks
Old 11-20-2006, 05:31 PM   #167
Car: 05 Subaru WRX STi
Fav Mod: RCE T2 Coilovers
Trader Rating: (21)
Send a message via AIM to AndrewSS
Originally Posted by reeksti
im want to get sway bars, but im just confused. i've searched and seen all bars are great. COBB, cusco, whiteline. i just dont know what to choose, im getting tein flexs. i just want to pick the right ones to have a good set-up with the flexs, help me out guys thanks
I say whiteline bars. You want a big one up front for sure. If you are set on the tein flexes (one of the perfect examples of a coilover that doesnt droop travel much at all). You are going to get into some major rear inside lift problems, a larger RSB shouldnt help much. And besides, you can adjust with rates and whatnot to get rotation, so you may not want much bar in the back.
For some relevant information, Brandon Burkhart won STU @ nationals in 05 and 06 on Tein Flex coilovers, granted I believe hes a good driver and whatnot, in 07 I think we will see STU really move into a very competitive class nationally (now its officially recognized and etc). Anyway with that said Brandon is getting ZZYZX coilovers (basically droop travel like stock).
Ok, bottom line is, if you are looking for a go fast setup with the flexes maybe look to Brandon's setup - which to my knowledge is off the shelf valved flexes, 12k springs front & rear! Thats a lot of spring, like 670lbs!
He also has the strano FSB (big ole 32mm FSB, I used to have it, I dont recommend it because it not a whole lot stiffer than the WL to warrant the benefit over the risk of breaking your control arm, I DID!) and he had stock RSB.
I am not him, so I dont know exactly why he did what he did, nor am I much of a suspension tuner/guru... however I think he made the point that he didnt experience a whole lot of inside rear lifting with his setup even though he had the really droop travel limited Tein's - I believe this is because of the 12k springs out back and somewhat because of the stock bar. And the front of the car is stiff so weight transfer is more proportionate. For example, people with mild bars in the front and mild/aggressive rear bars appear to get lotsa rear inside lift. (a buddy of mine we got pix of my car and his car in the same corner at about the same place and time with him lifting his inside rear significantly and me not lifting at all, we both have stock struts (I believe I just got the RCE's if that makes a whole lotta diff), but he has the cobb bars f&r and I have the WL bars (29set front and 24set rear). So take that FWIW.
I hope I made sense and my ideas were correct, heh.
My opinion is get the Whiteline FSB and maybe keep the stock rear bar if you get the flex coilovers. However my opinion and what i have outlined I should be taken FWIW, I am applying it to sort of autox primarily and what I have shown is biased, basically your applications/goals might not be the same..... However, methinks the stock strut and RCE springs plus camber plates will make you purty happy...
hope that helps
AndrewSS is offline   Reply With Quote
Old 11-21-2006, 10:55 AM   #168
Friendlys Suby
thanks to Adam at z1 for the GIGA
Zaino
Old 11-21-2006, 11:04 AM   #169
Car: 06 STi/00 L
Fav Mod: trunk monkey
hehehe a air freshener1?!?! you really do post pics of EVERYTHING i had to go to Z1 just to figure out what the "giga" was
kessler89 is offline   Reply With Quote
Old 11-21-2006, 11:08 AM   #170
I Has a Turbo Timer
Fav Mod: Every single one!
Trader Rating: (19)
Wow...congrats on the fresh smell you soon will have....what Invidia does make anything else for your car...Ohh, get the headers . , so whats next?
Old 11-21-2006, 12:07 PM   #171
Friendlys Suby
yeah i like to take pics of everything i get.....and mmmmmm the GIGA smells good as hell
Old 11-21-2006, 12:09 PM   #172
Friendlys Suby
yeah i want to start upgrading my suspension, and then start gathering up a list for my new turbo set-up...
Old 11-21-2006, 06:57 PM   #173
I Has a Turbo Timer
Trader Rating: (19)
New Turbo?! Do tell...I have one in the works as well.
Old 11-21-2006, 07:14 PM   #174
Car: 07 WRX STI OBP
Fav Mod: KW
Send a message via AIM to STinsane Send a message via MSN to STinsane
wish i had time to actually clean my car...
STinsane is offline   Reply With Quote
Old 11-21-2006, 08:26 PM   #175
Friendlys Suby
im still debating.....its the 20g or fp green. i cant really pick what i want....but sooner or later its going to happen.
BTW chris, why not go with the sz55??
Old 11-21-2006, 08:28 PM   #176
STI Master
Car: E46 M3
Fav Mod: ZCP Wheels
Trader Rating: (75)
Chris is anti sz55....
Old 11-21-2006, 08:56 PM   #177
Friendlys Suby
Old 11-22-2006, 03:26 AM   #178
I Has a Turbo Timer
Trader Rating: (19)
Reason:
SZ49 with the 3" Inlet, Ported Outlet, Fatboy Turbine Wheel upgrade, and the 8CM housing upgrade will spool up faster than the 3" Inlet SZ55 by 300-500 rpm, and be about 20'ish whp less than the SZ55. Plus I feel the SZ55 is basically pushing the limits of the stock internals....especially since I am on Meth. I just think the SZ55 would be too laggy for when I auto-x (eventually!), and go to Limerock and such.
Hmmm 20G or FP Green? Hmmm, why not the FP Green on Meth!!!
Old 11-22-2006, 04:45 PM   #179
Friendlys Suby
Reason:
i was acutally considering fp green on meth. i dunno if i wanna run AP on that set-up. i really wanted to go hydra, but we'll see.
BTW chris: for the APS CAI, how much trimming do i have to do to make the tube fit?
Old 11-22-2006, 05:00 PM   #180
Car: 05 STI
Fav Mod: Twinscroll GT37R
Send a message via AIM to ITSASTI
Zaino is sooooo good!!
ITSASTI is offline   Reply With Quote
