| | #151 |
| Grassroots STI Racer
Car: 2004.3 PSM STi Fav Mod: JDM STi Performance Muffler Location: NJ Posts: 567
IWSTI Addict since: Mar 2004 Trader Rating: (0) | This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #153 | |
IWSTI Addict since: Mar 2004 Trader Rating: (0) | Quote:
They may look lighter because I used the flash in 90% of the pics. I'll see if I can get some decent shots without the flash and in direct sunlight. | |
| | #155 |
| Wheel33tist Whore
Car: Aspen White GDF-D Fav Mod: Pastelito Racing / SFSOC Location: 0R!4ND0 Posts: 21,493
IWSTI Addict since: Dec 2004 Trader Rating: (7) | do you have camber bolts in the rear? it's interesting you're having rubbing issues in the back like that. is anything bent back there? |
| | #156 | |
I also was thinking that somthing may be bent, I'm going to try fitting it to the other side and see what happens. I'll report back with the findings. Thanks again. | |
| | #157 |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | your rears should be at -1.5 or so with the Pinks. keep me posted how things turn out. |
| | #158 |
| Indiatr0n in yo IWDPL
Car: 05FTW OBP STi Fav Mod: Brum Brum Location: downtown Chicago Posts: 48,820
IWSTI Addict since: Jun 2004 Trader Rating: (11) | My **** alignment (the rears weren't even touched) resulted in -1.3 and -1.8 in the rear, FWIW. JDM Pinks... |
| | #159 |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | |
| | #160 | |
Wheel resting against the strut ![]() A different angle ![]() Rough estimate of how big of a spacer I need ![]() 18x8.5 +44 CE28N clearance. (Its about a 1 finger length gap between the strut and tire) ![]() This is strange as I've seen 05+ STi's and WRX's fit these wheels in the back without any issues. I've even seen a few 03 WRX's with wheels with the same size/offset and also did not need spacers. However all those cars had coilovers and I'm still on the stock struts. I thought it may have something to do with the 04 STi's narrower rear track but I feel that may be a moot point. Hopefully this situation will change after I pick up some coilovers. I'm leaning towards some TiC's or Zzyzx's (more rear clearance Yay!). Anyways thanks in advance for the help Clap, you'll probably be hearing from me again when its time to buy tires. | |
| | #161 |
IWSTI Addict since: Jun 2004 Trader Rating: (11) | |
| | #162 | |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | Quote:
mount up your stock wheels, i'm curious how close that is to the strut with the 225. the TiC's are not clearance friendly. most coilovers are wider than the stock struts in the front and rear. the rear you can do the camber bolt/plate trick and gain some clearance (and still get your "total" camber you're looking for). another thing to do would be to find a WRX owner or another STi owner willing to test. slap on the BBS's i'm curious on the clearance with those. also what is your clearance to your trailing arm? | |
| | #163 |
| S204 Racer
Car: 04 STi, 06 Altima Fav Mod: jailbreak Location: SOsocal Posts: 3,066
IWSTI Addict since: Aug 2003 Trader Rating: (2) | nojeebs on nasioc has these wheels, should hit him up. (05 tho)a few 04's just got the sizing.. caltri-boost i think to... my 17x9 +39 effective (rear) have no issues with 255's, but i did use a 5mm spacer since i had to run a 10mm in front . you should check out stance coilovers, they are good and are good for clearence. (f/r camber plates) in any case...17x9 ftw the gunmetal is so nice. i love how mine look in different lights |
| | #164 | |||
| | #165 |
| Junior STI Driver Car: Car Builder Fav Mod: Boost Location: Seattle, WA Posts: 199
IWSTI Addict since: Feb 2006 Trader Rating: (0) | If your looking at quality coil overs like you mentioned before Look at the V3's and the T2's along with the ZZyzx's and get them with rear plates. This ad is not endorsed by this member. Please register or login to hide this ad. |
