Old 04-12-2007, 12:31 PM   #481
Car: 06 Subaru WRX
Fav Mod: winshield washer fluid
Send a message via AIM to trnkmnky
Because in a bad crash they can kill you.
trnkmnky is offline   Reply With Quote
Old 04-12-2007, 12:49 PM   #482
Fav Mod: Dyslexia
Trader Rating: (13)
Originally Posted by uncle lewie
It is DOT approved but it still isn't safe.
This has been debated to death on here & Nasioc.
After reading thru A LOT of those threads, I personally have come to the conclusion that a 5 point harness would be extremely unsafe because it does not let your body slouch in the event of roof cave in, but some of the four point setups are better than the stock seat belts, this would include the VERY fine Shroth setup. I'm sure there will be some who disagree....but this is MY OPINION.
Old 04-12-2007, 12:59 PM   #483
Car: 06 Subaru WRX
Well it really has more to do with the mounting points of the actual harness. When you mount the harness in the back you are either mounting it to the back seat area, or to the bottom of the drivers seat. You now just changed I guess what I would call a pivot point. When you in a front end collision you body is going to want to go forward. Also if its severe enought the stock seat is probably going to want to break. Anyway the stock seatbelt will prevent you from moving forward. Its like someone holding a hand in front of you because the seatbelt is mounted on the top pillar. Now when you have the harness and your in an accident the harness is going to want to pull you down instead of preventing you from moving forward. So now you have pressure on your shoulders pushing down on your body which if severe enough could break your back.
Now if the harness is mounted up high like on a harness bar or roll cage thats a different story. Its when you bolt it down to the seat or the back seats that it becomes more dangrous.
Old 04-12-2007, 01:36 PM   #484
I Has a Turbo Timer
Fav Mod: Every single one!
Trader Rating: (27)
I have to agree with you Al, they are better/safer than the stockers.
Old 04-12-2007, 11:43 PM   #485
I has BOOST!
Fav Mod: LightWerkz Projector Retrofit
Trader Rating: (12)
Send a message via AIM to MacSTi
I think the major issue is that if they are used in professional cars going 200MPH, I think they can be used in Daily Drivers....I feel it is safe, but I am going back and forth with them to see which i like more.
MacSTi is offline   Reply With Quote
Old 04-13-2007, 10:31 AM   #486
Car: 06 Subaru WRX
why do you think it feels safe, because you cant move around freely when its on?? Do you not understand physics? Whatever floats your boat, just be carefull.
Here check this out for info on safety belts
http://www.trackpedia.com/wiki/Safet...rack#Harnesses
Old 04-13-2007, 11:47 AM   #487
I always thought the issue with 4 points or more was in cars without cages. If you roll the 3 point would allow your body to move to the side somewhat, where the 4 point would not. But I might just be talking nonsense.
Dark_Helmet is offline   Reply With Quote
Old 04-23-2007, 05:40 PM   #488
Default Re: MacSTi's 2005 Aspen White STi--**MORE Carbon Fiber and MORE!!..NEW PICS.....Page 24**
Any luck fixing the downpipe fitment issues?
Old 04-23-2007, 06:28 PM   #489
I has BOOST!
Trader Rating: (12)
Not yet, but should once Ian gets the welder in....new bracket coming
Old 04-23-2007, 06:48 PM   #490
You should consider flipping the racepipe around like you said Steve!
Old 04-23-2007, 06:55 PM   #491
I has BOOST!
Trader Rating: (12)
I will once I get it onto the lift...that is step 1....
Old 04-23-2007, 07:06 PM   #492
I has BOOST!
Trader Rating: (12)
I got the rainguards on the car.......looks hottttt
Old 04-24-2007, 03:36 AM   #493
I Has a Turbo Timer
Trader Rating: (27)
Rainguards do look hot!!!! Funny it only took me <10mins on your car since I did mine first......lucky, took me 20mins for one side then 8 for the other on my car.....Any wind noise on the highways yet Steve?
Old 04-24-2007, 04:55 PM   #494
I has BOOST!
Trader Rating: (12)
I got Freddie's Plumbing Kit put in tonight, great fitment and great vendor...
Old 04-24-2007, 05:02 PM   #495
Car: 06 Subaru STI
Fav Mod: purple wheels
Send a message via AIM to stealthsti06
looks good
stealthsti06 is offline   Reply With Quote
