Old 10-09-2007, 10:12 AM   #331
NIИja
Default Re: LaMer's S204/RB320/2006 STI: New pics
Originally Posted by fullerton View Post
fix your dent you lazy fool!
Sad, but true. I don't want to see the invoice
Old 10-09-2007, 10:56 AM   #332
Trader Rating: (25)
Send a message via AIM to GarageSpec.com
the car looks great..
GarageSpec.com is offline   Reply With Quote
Old 12-18-2007, 07:03 AM   #333
NIИja
Went to the track recently.
Pics:
Old 12-18-2007, 07:06 AM   #334
Wheel33tist Whore
Default Re: LaMer's S204/RB320/2006 STI - Third track day (pics)!
how'd the rb320 setup do?
Old 12-18-2007, 07:23 AM   #335
NIИja
It did pretty well.
I wanted to go with the 'true' RB320 setup, so I picked up a 21/22/23 (IIRC) Cusco RSB. I had it on the stiffest setting. I also went with their recommended alignment settings: -1.4 Camber in the front, and -1.1 in the rear. It wasn't enough.
In the morning it was great! The car felt neutral, and would actually turn when I turned the steering wheel. Coming from OE suspension this is huge. NO understeer. I was loving it. I was driving the car hard, so I thought I'd close the first session early.
As the day got warmer things got worse. I think in the morning during the first session, when the track was cool, the outside shoulders of the tire (because it was rolling into +camber) were able to hold the car just enough; as the day got warmer the shoulders just couldn't take the heat from the corners or the track. I felt like I was on a layer of grease. It was equally greasy front and rear.
I recommend camber plates, and a slightly larger front sway (I'll probably go with Cusco's FSB).
Old 12-18-2007, 07:29 AM   #336
Indiatr0n in yo IWDPL
Fav Mod: Brum Brum
2007 Postwhore King
I know that greasy understeer feeling (on the street, no less ). I'm going to step my front sway up a tick to see if it helps in the spring.
Old 12-18-2007, 07:30 AM   #337
NIИja
But like I said it was equally 'greasy'. It wasn't necessarily understeering. "It was equally greasy front and rear."
Old 12-18-2007, 07:36 AM   #338
NIИja
Old 12-18-2007, 07:37 AM   #339
Wheel33tist Whore
camber is your friend.
Old 12-18-2007, 07:39 AM   #340
Wheel33tist Whore
front sways help maintain camber.
get a big one if you plan on staying on springs/struts.
Old 12-18-2007, 07:40 AM   #341
Fav Mod: Brum Brum
2007 Postwhore King
Oh...weird... so the tires were also part of the problem (in addition to your camber)? Did the 615s feel better on the track?
Mine is definitely the fronts scrubbing like they are greasy (my sways are set equal to 24F/24R right now).
Old 12-18-2007, 07:45 AM   #342
NIИja
The tires were part of the problem only because they were rolling over into +camber. If I had enough -camber dialed in it would have been a BIG difference in handling (a lot better).
Ya, the 615s had the same feeling, but because it was on OE suspension it was strictly greasy up front (understeer). In this case (with the RBs on 01r 245s) I was able to get the whole car to wiggle once the tires were heated and running on the outside shoulder do to the +camber rollover.
As far as the sways, I definitely need one up front to maintain the -camber under load (as Clap said). I wonder now what would have happened had I set the RSB to a softer setting? I'm thinking I'd get more dynamic +camber in the rear, and as you can see in the last pic, I DON'T need more +camber in the rear . What I'm wondering is how the softer RSB setting would effect the front?
Old 12-18-2007, 08:03 AM   #343
Fav Mod: HKS Kansai Diffuser
Send a message via AIM to TIMELESS
Are you on the stock RE070s? Those tires get greasy when track temps are high. They are good for a good number of laps and have great sidewalls but don't hold up in the long run. Nice shots BTW!
TIMELESS is offline   Reply With Quote
Old 12-18-2007, 08:06 AM   #344
Poor Speed Racer
Car: 96 328
agreed!
another rule of thumb for our cars is have a degree stagger b/t the front and rear wheels like -2 front and -1 rear. That worked the best for me.
Also nice pics.. i envy you!!!
Old 12-18-2007, 08:07 AM   #345
Fav Mod: Brum Brum
2007 Postwhore King
That gets into weight transfer and rotation and all of that is over my head
