| | #346 |
| Wheel33tist Whore
Car: Aspen White GDF-D Fav Mod: Pastelito Racing / SFSOC Location: 0R!4ND0 Posts: 21,523
IWSTI Addict since: Dec 2004 Trader Rating: (7) | This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #347 | |
| NIИja | Quote:
![]() Tires are 245 RE01Rs so I would imagine they are pretty similar in terms of rubber compound. Thanks, congrats on your new racecar! | |
| | #348 |
| NIИja | |
| | #350 |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | technically speaking a bigger front bar reduces front grip as well. but the maintained camber is > weight transfer. just don't go too big. I'm very happy with my 24/26 whiteline. (Front 26/Rear 24 (when i was on springs)). i like having over -1.5 rear camber. I'd suggest -1.5 all around for the street and then -2.5 or so for the front at the track. |
| | #351 |
| Platinum Member Car: 06 Subaru imprezaSTi Fav Mod: Prodrive Location: Southern California Posts: 545
IWSTI Addict since: Nov 2007 Trader Rating: (1) | nice car i really like how you did the trunk and the wing very classy |
| | #352 |
| Halliburton Mercenary | lamer- you need to buy a non-touch ir thermometer. that way you can actually tell if you are overheating the outsides of your tires, rather than just "think". i was able to discover i had TOO MUCH camber at the track when things got greasy b/c the inside of the wheel was 20°+ hotter than the outside. |
| | #353 | |||
| NIИja | Quote:
| | #354 | |
| Poor Speed Racer Car: 96 328 Fav Mod: Tightening the nut behind the wheel! Location: Northern VA Posts: 8,446
IWSTI Addict since: Mar 2005 Trader Rating: (8) | Quote:
![]() She is so hot... hmmmm *emo tear* Clap, Try driving one of our cars with even camber on all corners... I bet you'll get nothing but plow... "dumps like a truck" ![]() seriously though for a "street car" on the track -2 -1 is fine. then run -1 -1 on the street and have great tire wear. | |
| | #355 |
| STI Driver Car: '06 Aspen White STi Fav Mod: Myself Location: SoCal Posts: 200
IWSTI Addict since: Jul 2005 Trader Rating: (0) | that looks like streets of willow... was this with redline this past friday? if so I was there too... *edit* nevermind, we ran counter clockwise on friday... and i see people in shorts and tees. it was cold as hell that day too */edit* |
| | #356 |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | cusco has a 21mm and 22mm bar. with just springs you really want more than 22mm bar, especially since we're camber challenged. are you thinking of doing a Ball Joint Extender? |
| | #357 | |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | Quote:
the rear camber isn't easily adjustable. finding a happy middle ground of street/track is key. remember no plates on STi Pinks yeilds at max -1 front and -1.5 rear. the car didn't do too bad, just required some tire pressure manipulation. | |
| | #358 | |
| NIИja | Quote:
Yep Streets on Nov. 14th. It was 85F that day! | |
| | #359 | |
Trust me, camber is really your friend, with my setup i could get on the throttle SO early it was insane. | |
| | #360 |
| Halliburton Mercenary | This ad is not endorsed by this member. Please register or login to hide this ad. |
