Go Back   IWSTI.com: Subaru WRX STI Forums > IWSTI Featured Members > Members' Journals
Below is the permanent link ('permalink') to this member journal:
If you would like to share this member journal with friends copy and paste the permalink into your emails, blogs, forum posts, signatures, myspace, facebook, instant messenger, etc. (DO NOT use the browser URL because it changes):
http://www.iwsti.com/forums/showthread.php?t=42763
Old 06-05-2006, 11:49 PM   #76
Fav Mod: BMW #400
IWSTI Addict since: Nov 2003
Send a message via ICQ to trey2s Send a message via AIM to trey2s
Beautiful car!
trey2s is offline   Reply With Quote
Old 07-01-2006, 07:46 AM   #77
Fav Mod: The Newest One!
IWSTI Addict since: Sep 2005
Installed my Replica of a Chargespeed CF Type-2 lip about a month ago and finally got around to taking some pics. Picked it up from <a href="https://cvrmotorsports.com/model.php?mod_id=291">CVR Motorsports</a> for about $250 shipped. Fitment was "B" and took some tugging and pulling to get it to line up right, but I like it now that it is on. I just couldnt justify spending $500-600 for a V-Limited, so I went with this.
Also added the Home Depot Racing lower rubber lip. It has already saved me a could of times from scratching the crap out of the lip.
<a href="http://i50.photobucket.com/albums/f312/fourseasonsandles/100_0837.jpg"><img src="http://i50.photobucket.com/albums/f312/fourseasonsandles/100_0837.jpg"></a>
Old 09-03-2006, 01:08 PM   #78
Default Problem with the intake..
I have run into a problem. I have never had any issues with my custom made "Ram Air" CAI. None with rain or water in anyway. I have checked it numerous times when it was raining and never any water in the intake. That is until I met with a large puddle.
I was coming out of a gas station in a downpour last night and hit a large puddle and thought nothing of it. I hit the gas when I got on the road, turbo spooled and then I got a jitter from the engine and the CEL turned on as well as the blinking Cruise Control. I didn’t panic and got off at the next gas station.
I check the oil, it was fine. Then pulled off the air box cover and filter. The filter was damp for the first time and there were droplets of water in the air box. I think started checking out he sensors. They were damp as well. I must have gone deep enough into the puddle or threw enough water up for it to get sucked into the intake. I dried everything off and got to my parents house. I checked the air box again when I got home and everything was still dry so I knew it wasn’t being caused by the rain.
My father has an OBP II "reader?" I guess you would call it. I used it to check the codes and sure enough I pulled a "P0103 Mass air flow sensor circuit high input." I made sure veering was dry on the intake and reset the code and haven’t had a problem yet.
Now I do plan on revising my CAI tomorrow when it is dry out tomorrow and I suppose I am writing this as a warning to those of you that make an intake like this. I already had to modify in the intake for the upcoming winter and I figured now is as good as time as ever.
I plan to cut the intake "Dryer" tubing as follows on the red line. The tube will no longer be directly connected to the fog lamp bezel. I did not plan on having an opening there for the winter either, so this will allow me to easily swap out the fog lamp bezel for the original fog lamp cover each season.
I will then reshape the tube so it is more of an vertical shape like this.. I apologize for my crude drawing..I can build things, but cannot draw with paint
In the spring/summer seasons the "new" hanging tube design will still get plenty of air into the car from the fender well as air is still being fed into the fender well by the fog lamp bezel, but there is no direct intake for the water to travel into.
I also will be putting mesh across the fog lamp bezel like the picture below to keep out leaves, rocks etc. Also any water that travels into the bezel will simply drain out of the bottom and never have a chance to get to the revised intake tube.
Once all construction is complete, I will post pics of the final product to give a better illustration of the new intake and hopefully a safer one for my engine.
Thoughts or comments? Improvements? I plan on working on this tomorrow.
Old 09-09-2006, 05:24 PM   #79
Default Updated from the post above and problem solved
Well here it is. I got around to pulling the inner fender apart to redo the intake and keep the water from getting into the filter anymore. I wont do much explaining since I posted that above. I'll let the pics do all the explaining.
Cut the pipe
Pipe is re-routed to be above the foglight bezel
Redid the bezel with a wire mesh
Other side
Completed on the inside
Completed on the front bumper (played with the brightness on this one to show the wire mesh better.)
Front of the car
After all is said and done I can now replace the bezel with the original foglight cover when the snow hits.
Old 09-09-2006, 08:58 PM   #80
Welcome to The Board
Car: 06 WRB STI
Fav Mod: Advan RS
IWSTI Addict since: Mar 2006
Trader Rating: (15)
Send a message via AIM to Ikon
lookin good
Old 10-10-2006, 07:55 PM   #81
Default New Shoes
I would like to thank the Subydude for some help in ordering my combo, but still need to yell at him for putting almost identical rims on his own STI. I ordered mine before he put his on..just to set the record straight!
The original plan: Help me choose...They have been chosen!
I took the car out and flogged it pretty well after I had everything installed. Some things I noticed right away were: The tire noise is much less, The car rides smoother and can hear the engine better because of it. The Proxes obviously don’t stick like the RE070s, but they grip better than I thought they would. There is more noticeable tire squeal when pushed hard and a quick stop from 40mph will engage the ABS where the stock tires would not. Overall I am quite happy with my selection and they met my expectations. Now... pics!
18" Rota Tarmac 3 w/ Toyo Proxes 4
I like presents!
Gorilla Lugs with Toyo Proxes 4
Tire comparo- 235/40 18 Proxes 4
Out with the old and in with the new
The first one mounted. I love how well they show the calipers
I wish this pic came out a little better
Gorilla Lugs
New front view
New booty shot
Teh Hotness
Some valuable info for anyone looking to get new wheels/tires
http://forums.nasioc.com/forums/show....php?t=1115749
Old 10-10-2006, 07:59 PM   #82
Car: 06 white w/gold STi
Fav Mod: gt40r
IWSTI Addict since: Apr 2005
Send a message via AIM to Blaiser
NICE! they loook hoottttt. i want rims...
Blaiser is offline   Reply With Quote
Old 10-10-2006, 08:05 PM   #83
STI Master
Car: E46 M3
Fav Mod: ZCP Wheels
IWSTI Addict since: Aug 2005
Trader Rating: (77)
Wow those look amazing, how much did they run ya?
Old 10-10-2006, 08:14 PM   #84
Thanks!
They're Rota Tarmac 3s. Picked up the set and tires for $1400 from Subydude.
Old 10-10-2006, 08:20 PM   #85
STI Master
Car: E46 M3
Fav Mod: ZCP Wheels
Trader Rating: (77)
They look so damn good....I wonder how much w/o tires...
Old 10-10-2006, 08:24 PM   #86
Car: 2006 Kawasaki Ninja
Fav Mod: Power Sliding doors on my Minivan beotch
IWSTI Addict since: Jun 2005
I really love your rims but that lip is a little big on the sides.
evodon84 is offline   Reply With Quote
Old 10-11-2006, 12:19 AM   #87
Car: 05STi
IWSTI Addict since: May 2006
Those rims look hot indeed!
fuzz is offline   Reply With Quote
Old 10-11-2006, 08:04 AM   #88
Indiatr0n in yo IWDPL
Fav Mod: Brum Brum
IWSTI Addict since: Jun 2004
2007 Postwhore King
Wow, they are a good Volk CE28n or Prodrive GC-010G replica
Old 10-11-2006, 10:26 AM   #89
Car: Subaru, Subaru stuff
Fav Mod: Parts Whore
IWSTI Addict since: Oct 2003
$750 shipped
SubyDude.com is offline   Reply With Quote
Old 10-11-2006, 10:45 AM   #90
Sold My Soul For Mods
Car: '05 CGM STi
Fav Mod: Track Time
Trader Rating: (14)
Looks great! I'd be hard pressed to tell those apart from my Prodrives, even the color looks the same.
