Old 03-03-2007, 09:21 PM   #331
I Has a Turbo Timer
Fav Mod: Every single one!
Trader Rating: (23)
Intake rattle and shifter rattle is covered by me bro. Kiwi Ian and I will get those things checked out and fixed. As for the warm start issue......I will have Ian check the fuel lines to make sure they aren't cinked, and check the injectors to make sure they are seated properly...if not, check the tune I guess.
Old 03-04-2007, 05:52 PM   #332
Car: 05 STi OBP
Fav Mod: All of them
My APS CAI rattled quite bit as well, I enlarged the opening with a dremel and then cut a hose and put it around the inside opening...did you already do this and you still have the rattle? Mine completley went away after the mod...
Black-STi is offline   Reply With Quote
Old 03-04-2007, 06:12 PM   #333
I Has a Turbo Timer
Trader Rating: (23)
Yah I did that already for him. The hose may of moved and thats what is causing the rattle or something.
Old 03-04-2007, 06:27 PM   #334
The hose appeared to be intact, but something must be off. The rattle is worse then ever, makes the car sound so damn tinny. Ugh! Can't wait to fix it.
On a side note I bought a 137 piece Craftsman mechanic tool set today at sears to use when I get back home!
Old 03-04-2007, 06:44 PM   #335
I Has a Turbo Timer
Trader Rating: (23)
^Congrats on the tools..thats like atleast half my collection ahhahaha. We will def be able to stop the rattling...
Old 03-14-2007, 07:31 PM   #336
DOMINATOR
Fav Mod: Strut Clunk
I have that exact same kit! Got in on sale at Sears.
Old 03-26-2007, 04:56 PM   #337
Here's some news guys....
APS SR375 TMIC for sale! http://www.iwsti.com/forums/showthre...69#post1203469
APS DR525 on the way....
Old 03-26-2007, 04:59 PM   #338
I Has a Turbo Timer
Trader Rating: (23)
WHATTTTTTTTTTTTTTTTTTTTTTTTT...I want details!
Old 03-26-2007, 07:27 PM   #339
Authorized Tuner
Fav Mod: My Laptop
Send a message via AIM to EFI Logics
Good man.
EFI Logics is offline   Reply With Quote
Old 04-08-2007, 08:12 AM   #340
APS DR525... Installed! I love it. Retune will be this Friday,the 13th...gonna need some luck on that day!
Chris at XXtuning will be taking care of the tune this time around. XX is nice and local to my college, so this couldn't be easier.
The car feels very good with the FMIC, I noticed some the lag between shifts, but I feel it's very easy to compensate with shifting slightly differently.
Hopefully I'll get some pics up soon. Had big help from Chris and Ian... we worked on the install for hours! Used weatherstripping to make the edges look flush and clean, NO gaps! A+ work.
Old 04-08-2007, 09:29 AM   #341
Trader Rating: (43)
Send a message via AIM to Z1 Performance
Z1 Performance is offline   Reply With Quote
Old 04-08-2007, 09:33 AM   #342
I Has a Turbo Timer
Trader Rating: (23)
Glad to hear you love the FMIC...sooo jealous! Good luck to you on your tune coming up!!! Can't wait to see the results!
Old 04-08-2007, 09:55 AM   #343
DOMINATOR
I too am interested to see the results. I'm on the fence right now with what I want to do and your switch should be a perfect example of the pros/cons of each setup.
Old 04-08-2007, 06:54 PM   #344
Originally Posted by Z1 Performance
Big thanks to you bud for sourcing the FMIC out for me!
Old 04-08-2007, 06:55 PM   #345
Definitely will keep you posted on this. Odd enough the car is running better right now then it did before.
