Go Back   IWSTI.com: Subaru STI Forums > STi Owners' Lounge > Members' Journals
Old 06-16-2007, 05:01 PM   #196
Moderator
Default Re: Fullerton's 05 Aspen White STi (PDE Camber/Caster Plates Installed)
ben did you ever re-install those camber plates the right way?
MKTURBO is offline   Reply With Quote
Old 06-16-2007, 05:58 PM   #197
Orwell was an optimist.
Fav Mod: Track time
yeah, i did it last weekend. just need to take new shots. read back a few posts for the story.
Old 06-16-2007, 06:12 PM   #198
Indiatr0n in yo IWDPL
Fav Mod: Brum Brum
2007 Postwhore King
Interesting... I'm gonna wait to hear your long-term results before I try it out.
Old 06-24-2007, 06:16 PM   #199
Fav Mod: Track time
Default Re: Fullerton's 05 Aspen White STi (Whiteline Roll Center Adjusters (BJE's) Installed)
I installed my Whiteline Roll Center Adjusters (aka Ball Joint Extenders) this weekend. Sorry, no picts.
I would rate the install a 7/10 for difficulty. The driver's side ball joint came out easily, while the passenger side required myself and a friend to both use a breaker bar to pry the thing out. This is after being soaked in PB blaster two times in two weeks prior and several hours of multiple soaks that day.
The tie rod ends were very easy to remove with the help of a ball joint remover. Wish the thing worked on the main ball joint. I highly recommend picking up a cheap remover if you try this yourself. It also helped me get the conical "washer" off the old ball join to move to the new ball joint.
I was unable to get re-aligned Saturday, so I missed an Auto-X, but I did get in in on Sunday. I asked for -1.75° on each side, but got -1.55°. Oh well. I'm not going to argue since I have been highly abusing the lifetime alignment deal as of late. I can still get the added camber I want for the track b/c of my PDE Plates.
As for the feel, it is a bit hard to compare. My last alignment was used to see what the max on the plates would be, which was -3.6° on each side. Since I dropped 2° of camber, but picked up a better camber curve, the car definitely feels different. It actually feels quicker responding. Probably a placebo effect, but I do like the way she turns better.
With the -3.6° and no RCAs, she would start turning somewhat slowly, then after a certain loading of the wheel, it would almost "snap" steer and really turn HARD. I didn't like how unpredictable it felt. I have a feeling this is a combination of flattening of the tire at a certain suspension compression and me suddenly hitting the bump stops.
Now, with the -1.55° and the RCAs, she IMMEDIATELY turns upon input. Much quicker and more responsive. I like this a lot more. I will post up when I hit the track on the 2nd and give her a workout.
Overall, after a limited amount of driving, I am very happy.
Old 06-25-2007, 05:53 AM   #200
Fav Mod: Track time
A tip for the install of any new ball joint: use anti-seize on the joint. The stock one was definitely rusted in place. Hopefully, if I even need to replace these joints, they'll pop right out for me because of the anti-seize.
Old 06-30-2007, 05:42 PM   #201
Car: 04 ASPEN WHITE STI
Fav Mod: ALL
Originally Posted by fullerton
so, most of the parts above are on the car.
i just had her aligned and threw in another set of horns, this time the Hella Twin Tone Horns. Much cheaper at $25, compared to my SuperTones.
you'll notice i have not connected the strut tower bar mounts. I need to repaint the mounts before i do so.
i'll get some picts of the stance soon enough. also have to show off the wingless look.
here are some picts of the work:
my engine bay.
Hellas
If you guys don"t mind me asking what are the red things behind the grill
BILLY K is offline   Reply With Quote
Old 06-30-2007, 05:54 PM   #202
Fav Mod: Track time
LOUD horns. Hella Supertones. 118db loud.
Old 06-30-2007, 06:11 PM   #203
Fav Mod: ALL
were can they be purchased from?
Old 07-01-2007, 04:57 AM   #204
Fav Mod: Track time
I guess I'll google it for you:
http://safedrives.com/proddetail.asp...3399801&cat=60
Old 07-01-2007, 11:38 AM   #205
Fav Mod: Track time
Oil changed. Tires rotated. Air filter cleaned and oiled. MAF cleaned.
I'm ready for tomorrow's HPDE!
I will be brining pads and all necessary tools in case I kill the stockers this time. I have a tiny bit more than the thickness of the backing plate left, so I'll give them a try. I can always change them during lunch if I eat through them quickly.
Old 07-01-2007, 03:51 PM   #206
Moderator
good luck tomowrow with the track event tomowrow!
Old 07-07-2007, 11:50 AM   #207
Fav Mod: Track time
Few shots from the track day:
Old 07-07-2007, 12:14 PM   #208
Fav Mod: Brum Brum
2007 Postwhore King
That white/gold car would look better if it was OBP.
IB"At least I track my car"
Old 07-17-2007, 10:49 AM   #209
Fav Mod: Track time
Default Re: Fullerton's 05 Aspen White STi (Öhlins Flag Series Coilovers Ordered!)
Well, I just gave the credit card a major workout. Ordered a set of Öhlins Flag Series Coilovers:
Öhlins Racing AB also manufactures shock absorbers for road going performance cars. We have developed a shock absorber kit for a variety of sporty cars, including BMW, Audi, Mitsubishi and Porsche, and are in the process of producing shock absorbers for many more.
This product range for street cars dramatically improves traction, handling and at the same time the comfort of the car. The shock absorbers are produced in Sweden and Japan with the specifications, and above all, the development made in Sweden.
All shock absorbers are individually tuned for each model and its specific characteristics. We test ourselves by fitting shock absorbers to each vehicle and conducting thorough tests. As usual, we believe in trying to combine the hard-to-define ‘feeling’ of our experienced drivers with measurement data obtained from our advanced equipment.
Subaru FLAG Series Features
1. 25 clicks of rebound adjustment
2. 20 clicks of compression adjustment
3. Adjustable front camber plates
4. Inverted front and rear strut design
5. Includes main springs
• Front rate- 450lb/in.
• Rear rate- 335lb/in.
These are not my shots:
Old 07-17-2007, 10:52 AM   #210
Fav Mod: Brum Brum
2007 Postwhore King
Ben: I'm going to steal your coilovers. kthx.
