Old 05-23-2007, 04:30 AM   #136
Poor Speed Racer
Car: 96 328
Default Re: Fullerton's 05 Aspen White STi (Engine mounts in)
Originally Posted by fullerton
I'm officially a TiC whore now.
ah, well I'm illiterate
those are nice looking and cheaper than the 6gun ones.
Old 05-23-2007, 05:20 AM   #137
Reasonable
Fav Mod: correct grammar
yep, and they did a great job. not much left unfortunately.
i want to see if the dealer will replace them under warranty though. who knows. it's worth a try.
How many miles did you have on your pads before you hit the track?
Old 05-23-2007, 05:28 AM   #138
abracious
Fav Mod: Track time
33k
Trying to decide between getting the Stoptech-Centric Street Only Pads and some track only pad or the HP+ for everything.
I am not sure how the stoptechs perform, and I don't think it's worth saving a few bucks if the pads fail to stop me to avoid an accident. It would be nice to have track only pads, though.
I want to hear more about the stoptechs before I make a decision.
Old 05-23-2007, 05:30 AM   #139
Poor Speed Racer
Car: 96 328
Default Re: Fullerton's 05 Aspen White STi (Autobahn Track Day Picts)
Really you will want 2 sets of pads, one for the track, and one for the street (if you track a lot). I'm a BIG fun of pagid blues for track pads and the HPS for street pads.
Some people run the DS2500 all the time, but i think the weight of the car will make the hp+ overheat.
Old 05-23-2007, 05:32 AM   #140
Reasonable
Pad swapping at the track, eh? Yuck.
Old 05-23-2007, 05:38 AM   #141
abracious
Fav Mod: Track time
you're saying that the HP+ are not enough for the track?
Old 05-23-2007, 10:43 AM   #142
Car: 05 Subaru WRX STi
Fav Mod: RCE T2 Coilovers
Trader Rating: (21)
Send a message via AIM to AndrewSS
I've been there and done that... I used to have HPS and swap to PFC 01 full race pads. Its not bad, swapping pads is easy and fast, I did it at events sometimes. However, bedding in and re swapping, etc etc gets old... rotors cant enjoy it either.
I now run the HP+ I like it better for autox, they squeel quite a bit around town though. I am sure they will perform well at mid-ohio when I get there a few times this season. Not as good as the full race pads.... but shouldnt be bad. If you run in shorter sessions it will be coool (like 20-25min) and depending on track and the way you drive.
AndrewSS is offline   Reply With Quote
Old 05-23-2007, 10:49 AM   #143
Poor Speed Racer
Car: 96 328
it might, but then again you could easily over heat them and if they glaze over, then you need a new set of pads anyway. Talk to wrxbrakes (vendor) and he'll give you the skinny on pads and what not.
Old 05-23-2007, 12:37 PM   #144
Wheel33tist Whore
project Mu!
B-Force for the street
LM900i for the track/autox
Old 05-26-2007, 04:39 AM   #145
abracious
Fav Mod: Track time
ordered a set of DS2500s. we'll see how they handle light track duty.
Old 06-02-2007, 07:17 PM   #146
abracious
Fav Mod: Track time
think i am going to get a new x-pipe and Coat, P&P the cast exhaust manifolds.
Old 06-03-2007, 10:30 AM   #147
Indiatr0n in yo IWDPL
Fav Mod: Brum Brum
2007 Postwhore King
Still not enough power huh?
Old 06-03-2007, 12:26 PM   #148
abracious
Fav Mod: Track time
Well, for less than $200 I can add 15hp.. Still thinking about it.
Old 06-03-2007, 12:29 PM   #149
abracious
Fav Mod: Track time
Just got back from alignment. Here are my specs:
Left Front:
Camber: -2.6
Caster: 4.1
Toe: .02
SAI: 15.3
Right Front:
Camber: -2.6
Caster: 4.0
Toe: -.03
SAI: 16
Total Front:
Cross Camber: 0
Cross Caster: .01
Total Toe: -.01
Left Rear:
Camber: -1.3
Toe: -.07
Right Rear:
Camber: -1.4
Toe: .1
Total Rear:
Total Toe: .17
Thrust Angle: -.01
What do you all think?
Toe is bad out back, that's for sure. In two weeks I'll get that fixed.
Old 06-03-2007, 01:22 PM   #150
abracious
Fav Mod: Track time
PDE v2 Camber Plates
-2.6° Camber
