Old 06-21-2008, 09:59 AM   #526
Car: '05 Aspen White STi
Fav Mod: EQ Tuning tune
Default Re: Fullerton's 05FTW AW STi - New Turbo Time
Originally Posted by MorePSiTehBett4 View Post
rotate your vf series...ftl
Actually, it makes sense. That way he could have a straighter intake tract that doesn't go over the hot ass engine, the only thing is, he would have to redo the dp and get the flange on the rotated uppipe to match the turbo...
Old 06-21-2008, 01:26 PM   #527
abracious
Fav Mod: Track time
So, in addition to the master cylinder brace I installed, Snorky came over and we used his tool to remove the lower trailing arm bushings and replace them with a poly set from SuperPro.
The swap went pretty well, with the first one taking about twice as long as the other.
For about 10 minutes we attempted to remove the long bolt through the knuckle so we could put on my whiteline lateral links. That bolt has rusted itself in there. After removing the nut, the bolt would still not turn.
We gave up, leaving them for another day or person.
Old 06-21-2008, 01:32 PM   #528
Old 06-21-2008, 02:08 PM   #529
Teh Other White Meat
Trader Rating: (22)
Default Re: Fullerton's 05FTW AW STi - New Turbo Time - Cooments on Parts List Requested
now i'm nervous to do mine. we'll see tomorrow.
Old 06-21-2008, 03:44 PM   #530
Is Scared Of Kevin...
OK, I've done some thinking and I'm going to do a VF48 to replace my cracked VF34. I just don't want to spend the cash to go rotated right now.
Plus, after a few engine scares, I've found I am too afraid to beat her too much. But, I have passed compression, leakdown and oil analysis tests. My engine is nice and healthy for all the abuse I've put her through.
Plus, since I am saving some cash, I can happily run 100 octane regularly.
So, here's what I am getting, let me know what you guys think:
VF48- Great choice on turbo....thiers nothing more reliable than a Vf series turbo....
Samco Inlet- perfect! i seriously dont know why more people dont use it!
Samco AftaMaf- Yep....if you run the samco inlet, and aps 70mm you need this to connect them...
DW 850 Injectors- For a stock series "sized" turbo i dont know if you need that big of injectors...
Fuel Pump-not really necassary, however since its cheap it wouldnt hurt....
TGVs (worth the hassle?)- If your installing any type of aftermarket inlet pipe your going to have to remove the manifold unless you have 07.....so even though it sometime cause poor starting in the winter....it may be worth it
3mm phenolic spacers- Great!
Race Pipe/Mid Pipe (Get rid of my catted mid pipe)-get rid of them stupid cats...
engine pulley (worth it?)-not worth it or proven unless its the ar fab engine damper.......
screw clamps on all connections- not screw....t-bolt
Jorge tune-great!
I already have P&P'd headers and a x-pipe. UP- After doing a cost analysis, you should sell your headers and x-pipe.....and buy a header....pm me if you want more details...
MK
Comments?
COOL?
MKTURBO is offline   Reply With Quote
Old 06-21-2008, 05:53 PM   #531
abracious
Fav Mod: Track time
Thanks Matt.
I like the P&P stock header idea. I think it will perform quite well.
i thought the cold start thing with TGVs was a myth... Japanese cars experience cold, too.
Old 06-21-2008, 05:54 PM   #532
abracious
Fav Mod: Track time
I spoke with clint from TiC and he said he simply cut the bolt ends off, punched it out and used a fresh one. Wanna order 4 and we'll do it some weekend at your place?
Old 06-21-2008, 06:08 PM   #533
Trader Rating: (22)
Sounds good. I'll call my guy at subaru on monday and order them. my next weekend off is in two weeks
Old 06-23-2008, 08:17 AM   #534
Indiatr0n in yo IWDPL
Fav Mod: Brum Brum
2007 Postwhore King
Guess I won't be around to see the progress with the car Ben
Old 06-23-2008, 08:42 AM   #535
nan i got to give you a ride in mine before you leave
Old 06-23-2008, 09:05 AM   #536
Trader Rating: (22)
Originally Posted by MKTURBO View Post
nan i got to ride you in mine before you leave
uncalled for
Old 06-23-2008, 10:37 AM   #537
abracious
Fav Mod: Track time
Well... maybe you can do yours on your own and we'll figure out when to do mine. I may be a dad in two weeks and I am definitely not going hours away from Jennifer if I am not.
Old 06-23-2008, 11:08 AM   #538
abracious
Fav Mod: Track time
So, after a bit of daily driving with the Cusco Master Cylinder Brace and SuperPro Rear Trailing Arm Bushings, I have decided that they both make their systems faster and more direct.
The MCB gets rid of the softness at the last 20% of the brake pedal's path. You can feel a difference on the street when coming to slightly hard stops. This will probably be very noticeable at the track.
The LTABs seem to remove some lag I experienced when telling the car to turn. It just feels a bit tighter I guess. More immediate. I think they're worth the install time and few bucks. I can't wait to throw new lateral links on with their stiff bushings.
Old 06-23-2008, 11:11 AM   #539
Trader Rating: (22)
dealerhsip has them in stock, I'm off tomorrow, I may do them tomorrow.
Old 06-24-2008, 12:25 PM   #540
abracious
Fav Mod: Track time
so...
jorge just talked me out of "going big" on my VF48.
I'm thinking (thanks to him):
VF48
1000cc Injectors (thinking ahead to 30r)
Fuel Pump
I already have headers & an x-pipe, so that'll go on. I might get a turbo inlet... matters what condition mine is in.
What kind of race shop talks you out of spending money? !
