Old 07-22-2007, 06:47 PM   #256
Car: 07 WRX STI OBP
Fav Mod: KW
Send a message via AIM to STinsane Send a message via MSN to STinsane
Default Re: Fullerton's 05 Aspen White STi (Öhlins Flag Series Coilovers Installed!)
Picsorban!
STinsane is offline   Reply With Quote
Old 07-22-2007, 07:04 PM   #257
abracious
Fav Mod: Track time
Too dark. Soon.
Old 07-22-2007, 07:22 PM   #258
Indiatr0n in yo IWDPL
Fav Mod: Brum Brum
2007 Postwhore King
Originally Posted by nandanrp
Ben, I don't get it, you have (had) two x-braces? One installed, and the other was in a box which you sold to boony?
You didn't answer this part ???
Old 07-22-2007, 07:27 PM   #259
abracious
Fav Mod: Track time
Originally Posted by Andy STI
What ride height are you at? I don't know what RainMaker had them set at.
What ride height are YOU at? I want to go as low as I safely can without rubbing. Then, I can raise it as I please from there.
Old 07-22-2007, 07:35 PM   #260
Car: '05 STi
Fav Mod: Britax Roundabout
I just increased the front to 14 inches tonight. I found that one side had somehow lowered on it's own. I was a 13.75 all around and this fit my 8.5 inch wheels (et 48) with 255 RA1s. Sucks that I have to take some extreme angles to get onto my driveway without scraping my V-limited.
Andy STI is offline   Reply With Quote
Old 07-22-2007, 07:36 PM   #261
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
i'm at just about 14'' front 13.5'' rear with my Sportlines(i say just about because the corner balance changed the ride height a bit). On the street i was happy with it since i had a little more height than i did with the whitelines.
On the track though i still got tire rubbing inside the fender wall (it sheared off a good portion of that plastic fender liner). I'm on stock wheels and tires, so i don't know what happened. I've heard other people have had good luck with that height though so you might want to try it.
Old 07-22-2007, 07:54 PM   #262
abracious
Fav Mod: Track time
Without me going outside with a measuring tape, how many fingers is that evil/andy?
Old 07-22-2007, 10:22 PM   #263
Car: 05 WRB/Gold
well, i don't quite remember and my car is in the states (i'm down under right now) but my guess is 2, close to 3 finger front and about 1 in the back.
Old 07-23-2007, 03:47 AM   #264
Wheel33tist Whore
what wheels and tires are you running these days fuller?
stock wheels and big tires don't go well with a "dumped" car.
14" and 13.75" isn't a bad setting.
if you're looking to run bigger wheels/tires you're going to need to be at 14.25" front and 14" rear.
and remember Toe changes with camber and ride height, so find the right height before you get aligned/corner weighted.
T3h_Clap is online now   Reply With Quote
Old 07-23-2007, 04:04 AM   #265
abracious
Fav Mod: Track time
stock wheels/tires here for the foreseeable future.
i know toe will change. right now i have no idea where i am camber wise, but I was sure to set the eccentric bolts the same on each side.
Old 07-23-2007, 04:09 AM   #266
Fav Mod: jailbreak
align those bad boys damn supa baller status !
Old 07-23-2007, 10:42 AM   #267
abracious
Fav Mod: Track time
Preliminary ride height.
Old 07-24-2007, 01:19 AM   #268
394/600
w00t!
ok THAT is low.
skubv8 is offline   Reply With Quote
Old 07-24-2007, 03:34 AM   #269
abracious
Fav Mod: Track time
Think I may lower the front by a thread or two. Need to break out my measuring tape and see where I am at.
I ordered a 12" digital caliper, so I can accurately set ride height and spring tension. Counting threads and eyeing with a measuring tape is not very accurate.
Old 07-24-2007, 10:38 AM   #270
abracious
Fav Mod: Track time
go well, as in looks?
i would agree, but for some reason my mod budget has gotten pretty small as of late.
