Old 06-10-2007, 05:27 PM   #181
Indiatr0n in yo IWDPL
Fav Mod: Brum Brum
2007 Postwhore King
Default Re: Fullerton's 05 Aspen White STi (PDE Camber/Caster Plates Installed)
No I meant comparing braking distance was more relevant than comparing rotor size.
Audi weighs 300+ more according to your post, that's no small amount
Old 06-10-2007, 05:34 PM   #182
abracious
Fav Mod: Track time
I realize that. I am saying that with the info I have at the moment, that was the best I could do.
I agree the distance is a better measure, but I bet the Audi wins b/c of the bigger rotors.
Old 06-10-2007, 05:35 PM   #183
abracious
Fav Mod: Track time
My major camber up front is not a good thing. I am losing traction up there now when I accelerate hard.
What is the happy medium? 2.5°?
Old 06-10-2007, 08:15 PM   #184
Fav Mod: Starving my STI
Trader Rating: (13)
how long did u have to wait for your PDE camber plates? Are they setup so that they gain BOTH castor and camber as they are moved inwards? The Whiteline REDUCE castor while INCREASING NEGATIVE camber and vice versa... not sure if that is the best... if there really any negative to running more castor for a given amount of camber? Assuming the tire doesn't rub the fenderwell trim.
Old 06-11-2007, 03:20 AM   #185
Wheel33tist Whore
Originally Posted by fullerton
Oh- 3.6° looks ridiculous on the car. It looks like there is something wrong, especially if you don't know what camber is about.
i've got a photo of me on course at the last subaru challenge and it looks my front wheel is busted
Old 06-11-2007, 03:24 AM   #186
Wheel33tist Whore
Initially fuller had the plates backwards, where he reduced caster but increased negative camber.
considering the Whitline plates are called Max C i'd assume they are designed to do both.
It depends on your situation, but 1 degree of caster doesn't = the same traction during compression as 1 degree of camber. (did that make sense?) i explained it to fuller somewhere, could've been in the PW thread.
anyway, Caster has it's benefits (look at the ALK, the key thing it does is give you MORE caster), but if you're autox'ing I personally wouldn't sacrifice camber for more caster, but from the looks of it Fuller was able to get plenty of camber and some added caster ~.6 degrees.
Fuller, each hole is worth .2 degrees i believe. (it is explained in those instructions you failed to read)
Old 06-11-2007, 03:41 AM   #187
abracious
Fav Mod: Track time
Actually, it added 1.6° od caster and 1° of camber by having them on correctly. Not bad at all. And as I said, 3.6° is too much IMHO, so I don't see a point in having them in the camber only position since all you'd do is add more.
Old 06-11-2007, 03:44 AM   #188
Wheel33tist Whore
the caster # i was referring to was the stock caster.
with them backwards you decreased caster from stock.
I really liked -1.7 for the street.
Old 06-11-2007, 04:00 AM   #189
abracious
Fav Mod: Track time
Well, if you are comparing to stock, don't read that much into the plates, as I also have the ALK, which adds caster.
Old 06-11-2007, 04:03 AM   #190
Wheel33tist Whore
hmm, interesting.
i wonder how much negative camber you gave up for the few points of caster.
Old 06-11-2007, 04:21 AM   #191
abracious
Fav Mod: Track time
But I don't think it matters. What would 4° of camber do for me? 3.6° is already too much.
Old 06-11-2007, 04:27 AM   #192
Wheel33tist Whore
It was more of a question of curiosity rather then a "you should have 4 degrees negative" question.
so you were able to unbolt the bearing, then unbolt the top hat itself and spin, then reassemble?
Old 06-11-2007, 05:25 AM   #193
abracious
Fav Mod: Track time
Yep. 6 fasteners and a rotation. Couldn't have been easier.
Old 06-11-2007, 07:33 AM   #194
Wheel33tist Whore
sweet.
i miss my PDE's
Old 06-16-2007, 04:55 PM   #195
abracious
Fav Mod: Track time
I "killed" my bobblehead today with a few heavy-duty sip ties:
How-to here.
