Go Back   IWSTI.com: Subaru STI Forums > STi Owners' Lounge > Members' Journals
Old 01-28-2007, 10:51 AM   #181
Send a message via AIM to nice-rice
Looks good man. I have a e.l. header too, and Im in the market for a quieter cat-back as well. I like the look of your Greddy. Is it full 3 inch? A sound clip would be awesome.
nice-rice is offline   Reply With Quote
Old 01-29-2007, 09:04 AM   #182
Fav Mod: Do Luck CF
It is a full 3". The welds are beautiful - look like a stack of nickels! I need to fix my exhaust leak (header related) one way or another and I will get some clips after.
Old 01-29-2007, 03:13 PM   #183
^^Cool thanks.
Old 02-13-2007, 04:13 PM   #184
Fav Mod: Do Luck CF
I received my TiTek UP today. It's really a great looking piece. Clean welds, great flange to pipe transitions, and its really shiney. It also has been elected as the most well packaged item that I have ever received. It seems to be a very simple install, just time consuming according to the people I've talked to. As always, I'm sure I'll update once I get it installed or something. For now - some pics:
Oh yeah... If any of you get one of these, don't get new gaskets or studs because it comes with them...
Old 02-13-2007, 04:31 PM   #185
Nice looking peice.
Old 02-21-2007, 05:08 PM   #186
Fav Mod: Do Luck CF
I installed my up pipe today. Contrary to all of the information I found on the installation, it wasn't all that bad. Just like everything else it just took a little time. Nothing was brain throbbingly hard at all. I can hear a huge difference in sound and I like it! More turbo spool noses... mmmm. The TiTek piece has a larger inner diameter by far than the stock piece and should make a small difference in overall output.
Flange comparison
Side by side
My feelings about the stock up pipe
And now for the thing that took the longest time of all... In their infinite knowledge, TiTek decided to weld a M12 x 1.25 bung on the up pipe for those with EGT sensors. This is all fine and dandy, but if they are going to sell them to STi owners as well as WRX owners, they need to include some sort of plug since the STi does not have an EGT probe in that location like the WRX does. I drove all over town for literally 90 minutes trying to find something to plug it up with. After exhausting all but 1 option, I finally went to O'Rielly Auto Parts. They had a bolt luckily that fit the hole so I picked it up. I threaded it as far as I could with some red Locktite on the threads and let that be it. It doesn't touch anything in the engine bay and so far it is not leaking - only time will tell. TiTek should include a $.79 plug for the STi folks who purchase their up pipe. Here's a pic of my solution. Ugly I know, but it should solve the problem.
And finally, an installed picture. Thigs are tight around this area, but it fit just right - no complaints there.
Well, after all that gooey goodness, I discovered something not so good. My pitch mount has snapped at one time or another. This isn't that hard of a thing to replace, but I'm sure you guys know just as well as I do that the stock TMIC is no fun to take off and put back on. Wonder how hard it would be to have this replaced under warranty?
Old 04-01-2007, 09:18 AM   #187
Fav Mod: Do Luck CF
I finally got my brake pads on Friday, 3/30/07. After watching the HSPN video series on brake maintenance I knew installing them was no task that I couldn't tackle on my own. The stock pads were stuck in the caliper pretty snug so I had to coerce them out with a pry bar at first, but once they broke free, they slid out pretty easily. It's a good thing I ordered new pads when I did... my stock ones were almost down to the backing plates in the front. Here are a few comparison and installed shots of my Project Mu pads.
Front:
Rear:
Front installed:
I bedded them in using Stoptech's procedure and they feel great. for Project Mu NS pads!
Old 04-01-2007, 09:30 AM   #188
Brake pads look great. How much did they run you if you don't mind me asking. How do you feel about the up pipe now that you have had it on for a while? Great modding.
IWantAnSTi is offline   Reply With Quote
Old 04-01-2007, 10:37 AM   #189
Fav Mod: Do Luck CF
I got a good deal on the pads and I'm not so sure I should broadcast the price. I will tell you to contact Jonathan @ WorldOne and tell him that John Walker sent you - he should hook you up nicely. I like the up pipe a lot actually. I no longer have any annoying exhaust leaks and I hear a lot of extra turbo noise - thats never a bad thing!
You can contact Jonathan via AIM using screen name "Worldonejonathan" or simply call them at 206.938.7974.
Old 04-01-2007, 04:10 PM   #190
Wheel33tist Whore
Why did you chose the lowest level Mu pad?
you don't track your car with those hopefully.
<--owner of two sets of Mu Pads j/ curious why you chose the NS.
Old 04-01-2007, 06:31 PM   #191
Fav Mod: Do Luck CF
They were inexpensive, plus I trust who I bought them from. Based on his recommendations and my reading, the NS pads are just fine for my use (street).
Old 04-01-2007, 06:33 PM   #192
Wheel33tist Whore
not saying they are bad.
I personally run the B-Force pads on the street.
were the NS's an upgrade from the stock Brembo pads?
Old 04-01-2007, 06:55 PM   #193
Fav Mod: Do Luck CF
Yes, they are an upgrade. They have higher friction rates and higher heat resistances than the stock pads. They also don't dust as much. They feel good to me so far - only time will tell how satisfied with them I will end up being. I would like to upgrade my lines and fluid when funds allow as well.
Old 04-01-2007, 09:06 PM   #194
Welcome to The Board
Car: 06 WRB STI
Fav Mod: Advan RS
Send a message via ICQ to Ikon Send a message via AIM to Ikon Send a message via Yahoo to Ikon
looks good
Old 04-20-2007, 02:47 PM   #195
Fav Mod: Do Luck CF
Default Re: JPWEraser's Vanilla Deliciousness**Updated 4/1/07** Project Mu NS Pads
Finally got my pitch mount today. I'll have to say that I'm not totally disappointed with the product .
It even came with some JDM zip ties.
Will post some installed pics once I get it on. Let's see this b!#$h break
