Go Back   IWSTI.com: Subaru WRX STI Forums > IWSTI Featured Members > Members' Journals
Below is the permanent link ('permalink') to this member journal:
If you would like to share this member journal with friends copy and paste the permalink into your emails, blogs, forum posts, signatures, myspace, facebook, instant messenger, etc. (DO NOT use the browser URL because it changes):
http://www.iwsti.com/forums/showthread.php?t=23326
Old 09-13-2005, 10:51 PM   #226
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
IWSTI Addict since: Jul 2004
uh oh steve, who's not the newb anymore??!
Old 09-13-2005, 10:55 PM   #227
retired mod
Car: 99 WRX STi V5
Fav Mod: JDM Air Freshener
IWSTI Addict since: Apr 2003
Send a message via AIM to eatV8 Send a message via MSN to eatV8
It's all you MAC owners fault. You should all buy a real computer
I am always on AIM, MSN etc. My contacts are under my profile, I can personally send you guys the video or if anyone has somewhere to host them?
eatV8 is offline   Reply With Quote
Old 09-14-2005, 10:25 AM   #228
GT R US
IWSTI Addict since: Dec 2003
i couldn't get to the shop early enough today. i went right to work trimming back the tip of each radiator fan blade ever so slightly so as not to send the unit out of balance. i then gave it a good bath and some zaino detailer and immediately took it out and set the rings. so far so good on the trimming. i had the oil changed for the first time with about 30 total miles on the build and installed the fugimoto oil drain.
the suspension and motor seem in perfect harmony. i am having the time of my life wringing it out. the e-boost2 will remain at it's default setting for the time being.
donmei is flying in to a local airstrip in his homebuilt airplane. i be picking him up at 2:30. it looks like he will be the first to take a ride in it besides me.
8:30pm - don was indeed the first passenger {{applauding}}.
that's some plane he built!
Old 09-14-2005, 10:34 AM   #229
retired mod
Car: 99 WRX STi V5
I think you should bring him for a drive to NJ just to make sure everything is running good
Old 09-14-2005, 04:45 PM   #230
Car: 2005 Silver WRX STi
IWSTI Addict since: Jun 2004
Bruce how does it feel?
speedsnice is offline   Reply With Quote
Old 09-14-2005, 05:05 PM   #231
IWSTI Addict since: May 2004
bruce just picked me up at my store and took me for a ride.
it pulls real hard for only 14psi. peaked at 15.4 or so on his digital gauge. install looks super nice, clean and profesh.
cant wait to go for a ride when its tuned and running 23 or so psi.
it should be insane.
congratulations bruce!
watch out for those troopers.
peace -jed
statik is offline   Reply With Quote
Old 09-14-2005, 06:21 PM   #232
Car: 04 WRB STi
Fav Mod: Trailer Hitch
IWSTI Addict since: Feb 2004
Well, I went for a ride in Bruces car today. I'm really impressed with how sorted it is considering that its only been running for a day. It started fine, after normal hydra cranking, idled great and pulled like crazy. Like statik said, all on less than stock boost.
This thing is going to be a bear once he opens up the tap.
Another thing that really impressed me was the suspension setup in Bruces car. It rides much smoother than stock, but corners better. Hmm. None of that STi "jiggly baby" bouncing. Just nice firm, well damped, and almost fluid.
My plan is to take another ride up once the car has been tuned and broken in. Bruce said something about 30 psi !!!
Bruce - thanks again, it was great to meet you. And keep working on that clutch and its 1/8" engagement band.
Don
donmei is offline   Reply With Quote
Old 09-14-2005, 09:44 PM   #233
IWSTI Addict since: Mar 2004
Congrats Bruce. I have been following this thread since the beginning.. you have my best wishes.
javasti is offline   Reply With Quote
Old 09-15-2005, 12:06 AM   #234
Car: 2007 M coupe
Fav Mod: Bondurant Racing School
IWSTI Addict since: Jun 2005
Send a message via AIM to Rosspbig Send a message via Yahoo to Rosspbig
What suspension are you running Bruce?
Rosspbig is offline   Reply With Quote
Old 09-15-2005, 09:13 AM   #235
IWSTI Addict since: Apr 2004
Look under his sig.
Old 09-15-2005, 03:32 PM   #236
GT R US
i can add a little more to the info that's in the signature:
the kw variant3 coilovers and group n hardened tops currently have bump and rebound set in the middle range for now. camber is set -2.5 in the front and -2.0 back on stock tires and rims. the ride height is lowered but will be raised for the winter with a fresh set of blizzak lm-22's (although i hear there's a lm-25?. it's almost time to think about it). i'll grab a set of camber plates from myles when we change over for the winter. the cobb rear sway is set on soft with hotchkis endlinks all around. i'll probably wait until the spring to experiment with the sway bar setting but a driver school and some track time at limerock could change that.
the biggest improvement in handling (from this current round of mods) is the addition of the gt spec subframe braces and ladder brace. the entire front of the car seems 100% locked in rock solid. a 6 point roll bar will add to that. it's hard to believe it could get better. i looked at the do luck brace but it did not look like it offered anywhere near the structural support of the more angular gt spec units.
i was hoping that the higher hp wouldn't overwhelm the suspension and it does seem completely balanced at the current power level. of course, i'm running about 50% less boost than i will be in a couple weeks from now.
Old 09-15-2005, 03:37 PM   #237
GT R US
i was in bumper to bumper traffic for 10 miles on the taconic to westchester this morning. i've had all the practice i feel like having (today)
Old 09-15-2005, 03:45 PM   #238
wdb
dances with roads
IWSTI Addict since: Apr 2005
Originally Posted by BruceChapman
... a fresh set of blizzak lm-22's ...
Tirerack still has a special running on the 235/45HR17 size. I've got mine, and the wheels too. We'll have to get together for some snow play.
Oh, and PLEASE let me know when you are heading to Lime Rock. HPDE is on my list, and I can't think of a better place to get ejimacated than Lime Rock. Except maybe Watkins Glen.
Old 09-15-2005, 03:51 PM   #239
GT R US
i contacted a bmw club in ny. they are happy to have me join. they have a driver school scheduled for saturday, oct. 29th at limerock. i have an application if you want it. just pm me, wdb.
Old 09-15-2005, 04:30 PM   #240
...camber is set -2.5 in the front and -2.0 back...
How're you getting that much without the camber plates? Or am I missing something?
...i contacted a bmw club in ny. they are happy to have me join....
Oh yeah, sure. Our local bimmer club was not very pleased when the PDXTuning boys buried every M-Series bimmer on the circuit around PIR. I imagine your local club will be completely *ecstatic* after they see you run. Just remember to be courteous: make sure to wave when you pass.
