Go Back   IWSTI.com: Subaru WRX STI Forums > IWSTI Featured Members > Members' Journals
Below is the permanent link ('permalink') to this member journal:
If you would like to share this member journal with friends copy and paste the permalink into your emails, blogs, forum posts, signatures, myspace, facebook, instant messenger, etc. (DO NOT use the browser URL because it changes):
http://www.iwsti.com/forums/showthread.php?t=23326
Old 09-13-2006, 06:22 PM   #1561
GT R US
IWSTI Addict since: Dec 2003
valve timing update:
we finally got down to it tonight. everything in front of the timing cover came out, and then the timing cover itself. we found the belt and gears were all lined up on their marks and everything in order. the belt and tensioners came off and the intake cam gears were removed. once the passenger side cam end was exposed we removed the valve cover, allowing us to drop light into the hole at the end of the cam to confirm that the oil passage and relief hole needed to operate the avcs was present and accounted for. much to my surprize, the holes seem to be correct and it is not the oil passage problem that has recently surfaced over on nasioc on another set of kelford's. although we only removed the passenger side timing cover, we can confirm that the oil hole itself is in the drivers side intake cam. we'll remove the cover tomorrow to make sure the relief hole is there, too, but it seems unlikely it isn't.
so, now what? we might run the intake cam gears down to colonial subaru to see if they can see anything wrong with them, so we haven't ruled them out as the problem. meanwhile, we'll do a compression and leakdown test to rule out a more significant cam timing issue or defect or some other explanation.
at the moment i am relieved that the oil passage situation has been ruled out but perplexed as what it will turn out to be. depending on the results of the leakdown test, we may be able to avoid pulling the motor.
Old 09-13-2006, 06:50 PM   #1562
I Has a Turbo Timer
Fav Mod: Every single one!
IWSTI Addict since: Jun 2005
Trader Rating: (30)
Good news Bruce, but it sucks you don't know what the problem is. Good luck buddy!!
Old 09-13-2006, 07:24 PM   #1563
GT R US
i was sure we were going to find non avcs cams sitting in there, chris. the leakdown test should tell the story. if the cam timing is so far off that we're seeing a 50% power loss, we'll hear it coming out the exhaust. pray for quiet.
Old 09-13-2006, 07:35 PM   #1564
520
STi > EVO... Wait what???
Car: 03 EVO
Fav Mod: stock :(
IWSTI Addict since: Oct 2005
Send a message via AIM to 520
*crosses fingers*
Old 09-13-2006, 07:57 PM   #1565
IWSTI Addict since: Jul 2004
good luck bruce!
Old 09-13-2006, 08:46 PM   #1566
Car: www.dcawd.com
Fav Mod: Hydra
IWSTI Addict since: Oct 2003
Good luck Bruce! Your car came up at the DCAWD meet tonight We're all pulling for ya.
SabreOfSD is offline   Reply With Quote
Old 09-13-2006, 10:14 PM   #1567
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
hmmm, like you said im glad it's not the cams, but now your left with a pretty big field of reasons why it's not making power. def keep us updated
oh, and i saw this and immediately thought of you
http://news.yahoo.com/s/ap/20060913/...NlYwN5bmNhdA--
Old 09-14-2006, 07:23 AM   #1568
A.X.D.
Car: 2004 STi
IWSTI Addict since: Apr 2004
good luck Bruce!
Old 09-14-2006, 08:16 AM   #1569
Jeeze, eliminate one variable and end up with 3. Do you ever feel like you're trying to climb in scree?
Old 09-14-2006, 08:24 AM   #1570
GT R US
there are a couple of great geico commercials featuring neanderthals. we're "in", baby.
Old 09-15-2006, 12:58 PM   #1571
Car: 04 WRB STi
Fav Mod: Trailer Hitch
IWSTI Addict since: Feb 2004
I don't remember the details, but what was your egt during the dyno pulls? Was it low?
Also assuming A:F ratios and boost levels were more or less normal.
Don
donmei is offline   Reply With Quote
Old 09-19-2006, 11:33 AM   #1572
GT R US
breaking news:
automaster of westchester is taking over the mechanical work on the cutn edg project. i have no other details to share just yet. i am on my way to meet the flatbed.
Old 09-19-2006, 11:40 AM   #1573
Car: www.dcawd.com
Fav Mod: Hydra
Oh WOW, so I guess little Ricky is out... that sucks, sounded like a good guy. Good luck with everything as always Bruce!
Old 09-19-2006, 11:41 AM   #1574
Poor Speed Racer
Car: 96 328
IWSTI Addict since: Mar 2005
Well i guess thats a step in the right direction. But you will have to explain why later.
good luck!
Old 09-19-2006, 11:58 AM   #1575
Fav Mod: Pro-Tune
IWSTI Addict since: Apr 2005
Trader Rating: (17)
Your fired!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Poor old Subie on a flatbed......
CB
