Go Back   IWSTI.com: Subaru WRX STI Forums > IWSTI Featured Members > Members' Journals
Below is the permanent link ('permalink') to this member journal:
If you would like to share this member journal with friends copy and paste the permalink into your emails, blogs, forum posts, signatures, myspace, facebook, instant messenger, etc. (DO NOT use the browser URL because it changes):
http://www.iwsti.com/forums/showthread.php?t=23326
Old 05-22-2008, 07:06 AM   #3901
Fav Mod: Stripped Style
IWSTI Addict since: May 2008
Send a message via Yahoo to Brandi@ARFab
Default Re: CUTN EDG: oh no!...cross drilled and cranky - out comes the motor
Originally Posted by BenW View Post
Man, I was hoping to see this thing pound out the rest of the season without any more crap. But I guess that's the price you pay for absurdly complex and badass parts.
What about the rest of us?
edit: f***, beaten
Let's be perfectly honest...if we are here, we are open! And we are usually here until 8-9p.m. every night and almost all day Saturday... Sunday is strictly race-car day..but we are willing to help out a Suby owner in need!
Brandi
Brandi@ARFab is offline   Reply With Quote
Old 05-22-2008, 08:27 AM   #3902
Fav Mod: Dyslexia
IWSTI Addict since: Oct 2004
Trader Rating: (13)
Man, some things never change. Sorry to hear you gotta tear it down once again.
On a brighter note, i'm lovin those wheels!
Old 05-22-2008, 05:28 PM   #3903
Car: 08 STI,sr20det 510
Fav Mod: boob job for wife
IWSTI Addict since: Sep 2004
That really stinks to have to go through all this again. I remember years ago I was welding in a baffel into an oil pan. I put the motor togather put it in the car and hooked everything up. The very last thing I did was put the dipstick in and it hit the baffel. I forgot to drill a hole for it to go all the way down into the oil pan. After all that work it had to come out again. I have been there before and you seem to be handeling this very well.
Old 05-22-2008, 05:44 PM   #3904
GT R US
IWSTI Addict since: Dec 2003
no brain no pain mofo (isfh)
Old 05-23-2008, 07:48 AM   #3905
Fav Mod: CP35r 440whp
IWSTI Addict since: Jun 2006
from your tuner himself:
Originally Posted by Element Tuning View Post
I'm not even sure Subaru still uses the cross drilled crank anymore in the new JDM motors. Also keep in mind that reving an EJ257 at 8k rpm results in much higher piston speeds and stress than the EJ207 due to the longer stroke (due to crank 79mm stroke vs. 75mm). Also the longer stroke puts more angle on the rod and therefore is tougher on the rod, crank, and bearings.
Ultimately it still boils down to oil pressure and for whatever reason the JDM cross drilled cranks can hold high oil pressure but the modified EJ257 cranks can barely hold 60 psi with the biggest pumps available.
Thanks,
Phil
Element - Detecting Flash
Old 05-23-2008, 09:26 AM   #3906
Car: Gt35R STi
Fav Mod: JrTuned FTW Bro
IWSTI Addict since: Dec 2005
Send a message via AIM to boostedrex05
I take it you don't feel like trying the cross drilled crank again with drilling smaller wholes this time.
boostedrex05 is offline   Reply With Quote
Old 05-23-2008, 10:55 AM   #3907
Community Consultant
Car: 2005 OBP STi
Fav Mod: Learning
IWSTI Addict since: Aug 2005
Send a message via AIM to CicioSTi
Sorry to hear you have to pull the motor,
But it sounds like you looking it as an opportunity to "clean things up"
Seems to me its not all bad.
Best wishes!
P.S. I agree Howard and Brandi are nothing but top notch in my book!!
CicioSTi is offline   Reply With Quote
Old 05-23-2008, 02:33 PM   #3908
GT R US
correct.
Old 05-23-2008, 02:58 PM   #3909
Car: 07 OBP
IWSTI Addict since: Aug 2007
Send a message via AIM to The Black Beauty
are you going to run an aftermarket oil pan?
The Black Beauty is offline   Reply With Quote
Old 05-23-2008, 03:03 PM   #3910
GT R US
i am looking at the cosworth pan and baffle.
Old 05-23-2008, 03:10 PM   #3911
Car: 07 OBP
Yea I cant decide between the cosworth oil pan or the Moroso one.
Old 05-23-2008, 03:13 PM   #3912
GT R US
yeah, i am checking out the moroso, as well. i am discussing it with howard.
Old 05-23-2008, 03:16 PM   #3913
Car: '06 WRX STi CGM
Send a message via AIM to tripod
Haven't read all the threads, but any though of going dry sump?
Pretty sure you can set up whatever pressure you want with the proper pump, and a seperator tank to pull out the froth.
Here is a pretty good discussion on a similar problem
Engine & fuel engineering - GEROTOR pump, dry sump engine pressure problem
tripod is offline   Reply With Quote
Old 05-23-2008, 03:16 PM   #3914
Car: 07 OBP
Maybe the moroso pan with the cosworth baffle? or maybe that is just overkill..
Old 05-23-2008, 03:23 PM   #3915
GT R US
Originally Posted by tripod View Post
Havvn't read all the threads, but any though of going dry sump?
yeah, that was the first thing i thought of but from a cost and, especially, a time standpoint, our current plan is cheaper and faster and probably smarter for a dd. there is only one other dry sump setup that i am aware of and i have no interest in getting any more experimental than the project is already...at least for the time being (isfh).
black beauty: i'm not sure what we are doing for certain until we crack the motor and have a look. i have a number of components under consideration along with the 3 liter accusump. whatever the best combination of parts is for the overall effort we will do.
