Go Back   IWSTI.com: Subaru WRX STI Forums > IWSTI Featured Members > Members' Journals
Below is the permanent link ('permalink') to this member journal:
If you would like to share this member journal with friends copy and paste the permalink into your emails, blogs, forum posts, signatures, myspace, facebook, instant messenger, etc. (DO NOT use the browser URL because it changes):
http://www.iwsti.com/forums/showthread.php?t=23326
Old 05-17-2008, 08:31 PM   #3826
Car: Slow 05 STi
Fav Mod: Loping Idle
IWSTI Addict since: Mar 2005
Trader Rating: (12)
Default Re: CUTN EDG: summit point trackdaze update - last page
You probably have air in your cooling system. It happens all the time, if you don't spend the proper 30min-1hour burping/filling new coolant in, or you have a leak in one of your coolant caps (seals/gaskets). That could cause you high oil temps as well.
Old 05-17-2008, 08:37 PM   #3827
GT R US
IWSTI Addict since: Dec 2003
damn youre good
Old 05-17-2008, 09:13 PM   #3828
GT R US
in fact, it makes so much sense, i'm going to bag the first session tomorrow. sears is open at 8am. i'll be there when the doors open and do a flush and fill with water to get me through tomorrow. if i'm as lucky as i've been so far this trip, i'll make the 2nd session. i'll top it off with water wetter if the performance shop is open at summit.
Old 05-18-2008, 06:31 AM   #3829
GT R US
in the "best laid plans" category:
sears isn't open til 10am. i'll be there when the doors open and then try to salvage the last two sessions. there is weather moving into frederick. i'll check the doppler radar at summit point before leaving.
Old 05-18-2008, 07:31 AM   #3830
I Has a Turbo Timer
Fav Mod: Every single one!
IWSTI Addict since: Jun 2005
Trader Rating: (30)
Yup, I agree. Bruce I had the same problem last time I went to Limerock. My car started to heat up as well. It was an air blockage in the upper radiator hose. I had to massage it out while the res tank cap was open. You could see the bubbles come out. Then I kept refilling it up, starting it, massage it again. After awhile, the temp gauge on the stock gauge cluster was back in normal position! Good luck!!
Old 05-18-2008, 09:32 AM   #3831
GT R US
thanks, chris.
they flushed the radiator and started the car. the temp went up to 190 - without the fckn fan coming on. all the connectors are plugged in. i'm betting there is a short from all the times the radiator and fan assembly have been removed and reinstalled from the engine swaps and most lately from the oil pump swap.
all i missed today (my birthday btw) was one session in the am. the weather is crapping out here and the hoff reports a light rain there about an hour ago with a forecast of violent thunderstorms in the area this afternoon. i'll be checking in with him again as soon as i know what's up here.
c16 update:
no one has c16 in the dc/gaithersburg area. actually, edwin at andrewtech was able to come with some last time, so i'm calling andrew first thing in the morning tomorrow.
meanwhile, a pm'd howard at ar fab because i know he's in the area and boostjunkie thought he'd have some and he does. he's open at 9:30 tomorrow but get this; he's willing to open early to accomodate me. how freakin cool is that.
so, here i sit, waiting for a sear's tech to fix the fan so i can continue on my odyssey tomorrow. if i head to over to howard it's an hour to get there and then another hour to phil's. i just have to show up with a car that won't overheat and some c16 by noon. what could be so hard, right?
thank god i'm a neanderthal with a gentle grade for a forehead.
Old 05-18-2008, 10:48 AM   #3832
Fav Mod: Dom 3r
IWSTI Addict since: Apr 2006
Happy bday man. Good luck with the fan. Glad to see everything is working out for the most part.
If your going to try and get back to Phil's with c16 does that mean your going to get your full tune?
meffie is offline   Reply With Quote
Old 05-18-2008, 11:20 AM   #3833
Car: 02 WRX
Fav Mod: 4 5500cc Injectors / Aluminum Rods
IWSTI Addict since: Jan 2006
Bruce...If your at Summit point you are only 15-20mins away from us...
Howard
AR Fab is offline   Reply With Quote
Old 05-18-2008, 11:53 AM   #3834
Car: Gt35R STi
Fav Mod: JrTuned FTW Bro
IWSTI Addict since: Dec 2005
Send a message via AIM to boostedrex05
Still waiting for that ride
boostedrex05 is offline   Reply With Quote
Old 05-18-2008, 03:20 PM   #3835
GT R US
update:
the fans are coming on. the temp is staying around 175 in normal driving and climbing to 185+ when it is idling. there's no way of knowing what will happen during a prolonged high speed jaunt (or the dyno) but i'll have no trouble making it to howard in the morning. if nothing else, we'll pull the thermostat and i'll head over to phil's w the c16 in hand. i also need to check in with andrew if there is time to adj the rev lockout cable. ideally, i hit him before i get to phil but i have a pretty crowded itinerary in the am.
Old 05-18-2008, 03:21 PM   #3836
GT R US
a quick drive down to dc should solve that problem, billy. of course you could wait until i get back there (isfh)
Old 05-18-2008, 06:20 PM   #3837
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
IWSTI Addict since: Jul 2004
Default Re: CUTN EDG: howard (ar fab) to the rescue - c16 and more - last page
unfortunately i couldn't snap any pictures of bruce on the track (i was on track at the same time). Here are some of the ones i did take though.
Old 05-18-2008, 06:33 PM   #3838
Iron Fisted
Car: '05 STi
Fav Mod: Sparco seat
IWSTI Addict since: Sep 2006
Happy birthday Bruce! Car's looking good. Good luck with your schedule tomorrow - sounds like you have quite the day planned.
Old 05-18-2008, 06:34 PM   #3839
I Has a Turbo Timer
Trader Rating: (30)
AWESOME!!!!!!!!!!!!!!!!!! Its really great to see her running again, and getting track time!! So, MacSTi is sitting here looking at the thread with me and has to say, "After all this time and mods, you didn't upgrade the steering wheel"??!?!? .
*Looks at the trunk pic again* Hmmmmm, I see NOS tank, battery, Fuel pump assembly, and meth injection kit. Damn thats like an atomic bomb's potential there!!
HAPPY BIRTHDAY!
Old 05-18-2008, 07:40 PM   #3840
Car: Gt35R STi
Lol I can wait
