Go Back   IWSTI.com: Subaru STI Forums > STi Owners' Lounge > Members' Journals
Old 05-16-2008, 01:25 PM   #16
Car: Where Real Power is
Fav Mod: Tuning & Performance
Default Updates!
Guys,
We started working on this bad boy. We ripped down the motor and the vehicle to the bare minimum. And threw in some extras. The pictures explain it all.
PICS:
-Rob
automasteramr.com
AutoMaster is offline   Reply With Quote
Old 05-16-2008, 05:56 PM   #17
Fav Mod: CP35r 440whp
Default Re: AMR Build: Performance Chemicals, LLC. 2006 Subaru STi - 800+whp - MONSTER BUILD!
what do you do to the exedy clutch that's already balanced at 13,000 rpms?
Can you flip those pistons upside down and take a pic? (new vs. old) I'd like to see the webbing difference.
Old 05-16-2008, 06:40 PM   #18
Car: Slow 05 STi
Fav Mod: Loping Idle
And why are you tearing apart a sleeved built motor with a billet crank?
Old 05-16-2008, 07:10 PM   #19
Fav Mod: AMR GT35R and E-CUT Exhaust
Send a message via AIM to Subi4Lyf
They rebalance the clutch so that it will work correctly with the counter weight on a crankshaft, rods and pistons design and harmonic balancer. It is the first start of a blueprint job.
In other words if your really making high horsepower numbers and dont do this, i guarentee you a rod and main bearing failure. You will be surprised at the performance difference!!!
I made sure when AMR put my clutch in my STi that they rebalanced the clutch to my engine design so I would have no failures.
Ask ROB at Auto Master if im wrong.. Im sure he will agree with me!!!
Subi4Lyf is online now   Reply With Quote
Old 05-16-2008, 07:33 PM   #20
I thought that was only for externally balanced engines?
Old 05-17-2008, 06:40 AM   #21
Just because a motor is sleeved and equipped with a billet crank does not mean it was assembled properly. It takes alot of machining to to make 1000hp not just a billet crank and sleeved block
-Rob
Sure. I will snap some shots this week for you.
-Rob
You nailed it right on the head
-Rob
Old 05-17-2008, 10:55 AM   #22
Car: Slow 05 STi
That still doesn't answer my question. What was the reason for the teardown? What more "machine" work is necessary unless the previous build was using improper clearances for designed purposes.
That piston looks oversized? Is it a 102mm? By the looks of the old piston, it had some pretty loose piston to sidewall clearances.
Old 05-17-2008, 11:29 AM   #23
As you can see from the pictures above. The vehicle had blow-by due to improper tuning along with some other mechanical problems. Clearences were also off which is why we are re-machining the block.
As far as the pistons go. They are not oversized. The old piston has some shrinking.
-Rob
automasteramr.com
Old 05-19-2008, 04:50 AM   #24
Car: BLACK 06 STI
Fav Mod: 50+PSI
The motor in the last running state was JUNK. Not clearenced, just slapped together and SO LOOSE! Had less than 100 miles and was JUNK from the dyno tuning..... It was to be a Brian Crower 2.71 liter, with a 102 mm bore..... But not sure what had happened?
The car upon startup poured raw fuel out the exhaust! (Drivability was SO bad it was fix it or junk it! Reminded me of old school mustangs with HUGE injectors and high fuel pressure! Cars that followed would exclaim that the car REAKED of raw fuel!)
Engine was from a "reputable shop" in North Western, PA that specializes in Evos...... Took almost a YEAR for the motor to be sent back..... The sleeving was said to be the delay in completion....
Tuning was done in central NH, by a shop that no longer is in business.....
Very excited to see what happenes with this buildup! I have HIGH reguards for the crew at Automaster!
Mike
Last edited by MODDED 06 STI : 05-19-2008 at 06:04 AM. Reason: spelling error! + more info!
MODDED 06 STI is offline   Reply With Quote
Old 05-20-2008, 09:22 AM   #25
sounds like it was bore washed......
Old 05-20-2008, 10:03 AM   #26
Car: 2007 SWP STEE!
Fav Mod: Cusco Zero2E Coilovers
subscribed....AMR looking good
Johnny-J5 is offline   Reply With Quote
Old 06-09-2008, 10:23 AM   #27
Default Turbocharger PICS!
Guys,
Parts are slowly starting to trickle in. Seems the items we needed were on a little bit of a wait. But they are finally coming through the door.
The GT45R-C has come in! Here are some pics of it solo along with it next to a VF39 to give you guys an ideal of how big this beast is.
Pics:
Enjoy. More pics will be up when other items start to arrive.
-Rob
Old 06-09-2008, 10:32 AM   #28
count me in 2
BunaSTi is offline   Reply With Quote
Old 06-09-2008, 10:33 AM   #29
Car: BLACK 06 STI
Fav Mod: 50+PSI
Default Re: Turbocharger PICS!
Good LORD! That makes my day Rob! Thank God that does not have a belt driving it!
Estimated WHP still at 800+!?
Mike
Originally Posted by AutoMaster View Post
Guys,
Pics:
-Rob
Old 06-10-2008, 05:27 PM   #30
Car: 02 wrx bastard child
Fav Mod: 5x114.3 swap
Default Re: AMR Build: Performance Chemicals, LLC. 2006 Subaru STi - 800+whp - TURBO PICS!!!
I hope the pos magnus manifold will go in the garbage aswell.
scby rex is offline   Reply With Quote
