Old 07-02-2008, 11:24 AM   #136
Car: OBP 05 WRX STi
Fav Mod: $6 red cold cathodes under dash
Default Re: Clean STi- coolblue05's project 05 sti widebody- Post #120- Entire car in primer.
Very nice work!
When I came across this journal, I was interested in the painting process, as I will be re-painting my second car myself. Would you mind listing the steps you took, if you got a sec? This is what I got so far:
1. sand car/bondo with 100 grit
2. spray rust inhibiting primer
3. sand, 150 grit?
4. spray urethane primer
5. sit in sun to bake 2 days
6. sand 240 grit
7. sit in sun 1 day
8. wetsand 600 grit
9. paint, several coats?
10. polish or clear coat?
thundercamel is offline   Reply With Quote
Old 07-02-2008, 06:43 PM   #137
Send a message via MSN to RFFG
Damn, sick
RFFG is offline   Reply With Quote
Old 07-06-2008, 08:37 AM   #138
Car: 05 sti widebody
Thanks, I will see if I can get the exact method from the guy who is doing all the work.
coolblue05 is offline   Reply With Quote
Old 07-06-2008, 04:57 PM   #139
Originally Posted by thundercamel View Post
Very nice work!
3. sand, 150 grit?
6. sand 240 grit
7. sit in sun 1 day
8. wetsand 600 grit
1. Sand any surface that needs body filler with 80 grit.
2. Sand filler with 150 grit finishing off with 240
3. Skim coat(metalglaze putty) over body filler, sand with 240(fills in any deep sand scratches and imperfections from filler)
4. Sand the rest of the panel with 320 grit and wipe down with wax and grease remover.
5. Spray 3-4 wet coats of urethane primer
6. Sand primer with 400 grit wet and make sure everything is nice and smooth and there arent any primer lines.
7. Wipe with wax and grease remover and then a static control cloth.
8. Spray 1 medium wet coat of sealer
9. Spray 2 medium coats of base, let flash then sand out any dirt nibs or imperfections with 1000 lightly, wipe panel with tack cloth and spray 3rd wet coat.
10. 2 wet coats of clear and let bake/dry
11. Wet sand entire panels lightly with 1500 grit and also sand out and tiny dirt nibs in the clear.
12. Rub with rubbing compound and buffing wheel, followed by a medium grit compound then polish and wax.
Its not as simple as it seems and i really dont reccomend doing it yourself if you dont have much experience. Especially if you want quality.
mccready6569 is offline   Reply With Quote
Old 07-06-2008, 09:05 PM   #140
Car: 07 STi Blue (SOON)
Send a message via AIM to FLOW
Very sick. Hope everything goes out well as planned.
FLOW is offline   Reply With Quote
Old 07-07-2008, 09:57 AM   #141
The process we are using is more involved than that list. I will try to post up all the details when I have them.
Old 07-07-2008, 10:16 AM   #142
oh there is no doubt at all that its more involved then that, which is why i stated its not as simple as it seems, also with painting and body work there are numerous ways of doing it.
Old 07-07-2008, 10:27 AM   #143
Car: 05 WRX (STi Clone)
Fav Mod: JDM Fogs
Yep, definitely subscribing to this one.
Phame is offline   Reply With Quote
Old 07-07-2008, 11:37 AM   #144
Car: OBP 05 WRX STi
Awesome, and thanks! I've done a tiny bit of body work and painting once before on the car, and learned then that it's not simple. It's my "beater" car, 99 tiburon, that got totaled from a deer last year, so I don't expect it to look like showroom quality. I'm doing it myself to save money, and to learn.
Old 07-08-2008, 05:37 AM   #145
Paint has begun.... The steel blue mica looks awesome in person. The color looks like a gunmetal with a hint of blue. The color varies dramatically depending on the angle and lighting conditions. Here are a few different pictures of the hood scoop taken in different lighting conditions...
(BTW- this hood scoop has yet to be wetsanded/ buffed and polished)
Old 07-08-2008, 05:40 AM   #146
I Has a Turbo Timer
Fav Mod: Every single one!
Trader Rating: (23)
Default Re: Clean STi- coolblue05's project 05 sti widebody- Post #145 Custom Paint has begun
Awesome.......the car will totally be one hell of an eye catcher!!! Great choice on the color!!
Old 07-08-2008, 06:54 AM   #147
All day everyday
Fav Mod: Debt
Trader Rating: (15)
Send a message via AIM to DjChieNa
that paint color is badass!
DjChieNa is offline   Reply With Quote
Old 07-08-2008, 07:43 AM   #148
Fav Mod: Volk Ray's CE28N's Satin Black
Send a message via MSN to East Bay STi
Wow I like that a lot!!! Can't wait to the rest of the car, y0!
-Gio
East Bay STi is offline   Reply With Quote
Old 07-08-2008, 09:43 AM   #149
Thanks guys!
Old 07-08-2008, 11:49 AM   #150
Young and restless
Car: 2005 Aspen White STI
Fav Mod: Torque
Send a message via AIM to MikeO Send a message via MSN to MikeO
That's a very nice color. I'm excited to see the end result. When do you think it will be done?
MikeO is offline   Reply With Quote
